      09-17-2014, 01:18 PM   #1
Arrow Wind noise above 180 kph...
A friend of mine(Florian) fixed a problem on his 135i taht I think we all have encountered: Wind noise at high speeds.
For Flo his wind noise starts around 180 kph and above. The fix was relatively cheap at 1,20€. You insert the fish tank hose - under the B-pillar gasket door seal. See pics. I think for anyone out of warranty, this is a GREAT tip/fix.
Use soapy water(mostly water with a few drops of dish washing soap) to make it easier to slide the green tube up inside the old B-pillar gasket. You only need ~50cm of tubing. Just enough for the vertical section of B-pillar.
13mm O.D fish tank hose. 1,20€ per meter
Name:  wind-noise through the windows 10647184_10152637748433567_7858891929981575154_n.jpg
You can use some soapy water as a lube on the hose to make it easier to slide up inside the old gasket/seal.
Name:  wind-noise through the windows 10603568_10152637748463567_396230730470598242_n.jpg
Name:  wind-noise through the windows 1524572_10152637748493567_1209142879534684952_n.jpg
Wind noise fixed!
Appreciate 12
      09-17-2014, 01:29 PM   #2
MightyMouseTech
MightyMouseTech's Avatar
4338
Awesome idea! I actually get wind noise in that exact spot at anything above 100 or so if there is a head or cross wind.
Thanks!!!!!
      09-18-2014, 02:48 AM   #3
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
Nice! I get the same noise and it drives me mad
      09-18-2014, 06:57 AM   #4
BBursey
Work hard, play harder
BBursey's Avatar
Drives: 2011 135i
2011 135i  [0.00]
I saw this as a fix on a TV show where they were fixing up and selling older cars. I hadn't yet looked at the 1er to figure out what kind of hose to get and where to buy it - thanks for saving me the trouble!
I'll be very happy if this fixes my wind noise issues...
Cheers,
Bryan
2011 135i M Sport | COBB V3 AP Stage 1+ | ER FMIC and CP | BMS OCC | Dinan Stage 3 Suspension | Dinan High Performance Bushing Kit | M3 Wishbones | Modified CDV | Clutch Stop | APEX EC-7 Wheels w/ Michelin PSS 235/40R18 265/35R18 Tires | Maddad Street Series Exhaust | BMW Performance Kidney Grills | LCI Blacklines | Armrest Delete | Spoiler Delete | 28% Tint
      03-20-2015, 09:37 AM   #5
thehalcyon
Drives: '12 135i MT LeMans
Wow , great thread and advice. Thanks... Seems there are a few of us with the same issue. Mine is exactly as MightyMouseTech describes..
Anything over 120km/h for me and again depending on windspeed/direction its more of a whistling sound right where the door lock thingy is, like there is a small gap to let wind in. Highly Annoying and just about gave up on a fix after many dealer visits.
Also noticed all our cars are lemans blue.. perhaps we are jinxed?
      03-20-2015, 05:48 PM   #6
The pics are from my buddy's blue 135i. My 135i is silver.
      03-31-2015, 11:33 PM   #7
Crazycarl
Drives: 08 135i
This worked perfectly for me. Thanks for posting, seriously saved me a lot of frustration.
      04-01-2015, 12:12 AM   #8
6MT_Addict
6MT_Addict's Avatar
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
Awesome, thanks Dack!
I get wind noise @ 80km/h+ with crosswinds, drives me nuts. Great solution, going to be trying this soon!
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      04-27-2015, 02:40 PM   #9
thetaobear
thetaobear's Avatar
47
Drives: 2009 135i Crimson Red
thank you- this worked nicely to reduce wind noise AND the squeak/rattling from my windows when driving across bumps.
Much appreciated!
      04-30-2015, 06:44 PM   #10
JTB
JTB's Avatar
18
Could this not also be done to the A pillar?
JTB
Spec Miata - 2nd SCCA RMDiv 2014
Spec Miata - 2nd SCCA RMDiv 2013
2009 135i - let the modding begin!
      06-14-2015, 04:00 PM   #11
eeghie
Kind of a big deal
300
Simple and effective DIY, thx.
Would expect less noise reduction as the glass at the upper edge and A pillar is fully enclosed whereas the window along the B pillar can bend outwards freely at speed
The hose reportedly fits the upper edge seal; In the German Forum equivalent thread by Dack's friend, some-one is testing the resulting noise reduction currently.
      06-20-2015, 11:31 AM   #12
AnShk
Drives: E70 X5 35d
here cops got grazy...no more than 150km/h
no noise
      07-14-2015, 10:30 AM   #13
pysik
Drives: 11' Le Mans Blue 135i
Ill have to look into this. I'm going to assume all fish tank hoses are the same size correct?
      07-14-2015, 10:39 AM   #14
Crazycarl
Drives: 08 135i
Nope, there are a variety of sizes. I just took a ruler into a fish store and measured. The people that worked there had no clue what hose was what size.
      07-14-2015, 03:38 PM   #15
You NEED... 13mm O.D (outer diameter) fish tank hose.
      07-14-2015, 06:11 PM   #16
swagon
swagon's Avatar
Drives: F80 6MT
Damn, this could be useful on our trip to Italy tomorrow... Dack, have you done it?
      07-14-2015, 06:53 PM   #17
No, but Flo B, with the blue 135i will be on our trip. Its his pics in this thread.
      07-25-2015, 02:14 PM   #18
AnShk
Drives: E70 X5 35d
here is cheaper solution
http://www.uline.com/Product/Detail/...Q&gclsrc=aw.ds
      08-03-2015, 03:06 PM   #19
cosmick
cosmick's Avatar
Drives: 1M, M5 E39, 535i E34
Originally Posted by AnShk View Post
      08-03-2015, 04:24 PM   #20
lowbudgethero
lowbudgethero's Avatar
125
2009 BMW 135i  [8.50]
I like this solution, a fix I've found is to use some silicone vacuum grease at the part of the seal where you think there is a leak. I'll try the tubing fix too.
      08-03-2015, 05:04 PM   #21
A better way is to use a special 3M made powder spray-on. You spray onto say the door gasket seal, close the door.... and then open it back up and LOOK at the tracing of white powder. IF you see any gaps... that's where your leak is at.
Mattos or any 3M supplier(body shop supplier) sells this stuff.
IF you have a "helper" you can also use a US dollar bill... put it half way between the window and have your assistant, move the dollar bill in a sawing motion all around the window seal. When there is less resistance... take a close look at the door gasket there.
      08-03-2015, 06:44 PM   #22
lowbudgethero
125
You can also see where the grease has made contact with the window as well (though the auto open of the window skews it a bit), I heard of that stuff you're talking about though but I figure most people have some grease lying around.
Dackelone10588.50
