09-14-2017, 06:38 PM | #1 |
Rep 11
Drives: 2011 E82 135i M-Sport
Basic Bolt On Discussion
Hello again guys, the time is soon coming to throw some more parts at the E82. Pretty much going to get into the basics, Charge-Pipe, Downpipe, Intake, and cooling, Intercooler, inlets. Im wanting to start more or less a discussion of what everyone is running and experience with each, possibly to get a master thread for the best basic bolt ons.
Already looking into VSRF Downpipes and a few other options for Charge-Pipes. What are you guys running?! |
09-14-2017, 08:54 PM | #2 |
1Addict
3239
Rep 7,906
Current Modifications:
Engine/Exhaust/Cooling MadDad Whisper Exhaust BMS JB4 G5 ISO - 38% Ethanol/93 Mix, Map5 BMS/MHD E85 Backend Flash BMS 3" Downpipes BMS DCI (White S&B filters) CX Racing "Big Tom" FMIC Evolution Racewerks 50mm Charge Pipe - Anodized Black Finish TiAL Q 50mm BOV - Black Modified OEM BMW Clutch Delay Valve Spring Bolt Delete Suspension & Chassis TC Kline Single Adjustable Coilovers Koni Externally Adjustable dampers (TCKline spec) - front Bilstein HD monotube fixed rebound dampers - rear Swift Springs - 392lb (7k) Front Swift Springs - 672lb (12k) Rear Swift Thrust Sheets - 60mm front (x4), 65mm rear (x4) Fe1rx Rear Lower Spring Isolators HP Autowerks Adjustable Front Sway Bar Links Dinan Rear Upper Shock Mount Kit (Customized with 12mm TCK sleeve) Febi-Bilstein Rear Lower Shock Mounts H&R 27mm Front Sway Bar H&R 27mm Sway Bar Bushings Whiteline RSFB Inserts TRW OE M3 Front Control Arms TRW M3 Rear Wishbones TRW M3 Rear Guide Rods HP Autowerks Rear Toe Arms Rogue Engineering Transmission Mounts BMS Short Shift Kit 135droptop Differential Lock Down Brace Wheels & Tires Alufelgen SF-71 Titanium Gunmetal - 19x8 et 45 Front, 19x9 et 48 Rear" Michelin Pilot Super Sport tires 235-35-19 Front Michelin Pilot Super Sport tires 265-30-19 Rear Body & Cosmetic Rolled Fender Lips - Front & Rear OE BMW Performance Carbon Fiber spoiler - Painted Jet Black OE BMW LCI Black Line Tail Lights OE BMW E46 ZHP Shift Knob OE BMW 1M Floor Mats OE BMW Matte Black mud guards Front and Rear Redline Goods Italian Leather Shift & Brake Boots Matte Black custom mesh vented OEM diffuser Matte Black Kidney Grilles Matte Black CSR Eyebrows PIAA Plasma Ion Yellow 2500k H8 Bulbs DEPO Smoked Amber LED Sidemarkers Front Air Duct Mod Coded AE Max Voltage, Corners Off, Windows Up on Key, Folding Mirrors on Key Fluids Redline MTL transmission fluid German Castrol 0W40 BMW LL-01 engine oil
Justin_Gepner11.00 |
09-14-2017, 08:55 PM | #3 |
Rep 1,850
In decreasing order of importance, the best ways to get easy power on a N55 are:
MHD tune (custom dyno remap optional) catless downpipe intercooler / water meth e85 mix, but really if you have to mix gas every time you fill the car it's probably time for a turbo upgrade..see below. The stock air filter is pretty good and replacing it will make nearly no difference on a stock turbo and you will lose a lot of filtration which is bad for the engine. There is also a restriction in the charge piping and probably a muffler on the turbo inlet, but again, diminishing returns. The stock turbo is very small and you need to replace it to get a "serious" power increase. Pure Stage 2 is the easiest way to do that. |
09-15-2017, 12:46 PM | #4 | |
Rep 486
09-15-2017, 01:20 PM | #5 |
Rep 620
Drives: E90 335XI MSport, S2000
Biggest difference makers:
JB4 or Tuner Downpipes Intercooler Front sway bar M3 suspension / Proper suspension Rear subframe bushings LSD *washes hands* there we go. |
09-15-2017, 04:05 PM | #6 |
Rep 1,498
Drives: 2017 MB C63 S AMG Coupe
Mods in signature..suspension/diff will be installed in the early early spring. Wanted to get all the engine/basic cosmetic mods out of the way.
For the spring: Coilovers M control arms Trailing arms LSD Outlet pipe Port meth injection (have CP meth right now) Gtr hood 1M front fenders Carbon mirror caps Bbk??? (Still deciding on this) The car is immensely fun to drive...just need a custom tune to take advantage of everything. Also, need an lsd/stickier tires to put the power down.
2017 MB C63 S Coupe - DINAN | MODAL WORKS
retired: GranTurismo MC, Giulia Quadrifoglio, B8.5 RS5, Q60 RedSport, e82 135, F80, e92 M3, e90 M3, (2) e92 335, B8 S4, C209 CLK55 AMG, e46 330 |
09-18-2017, 09:13 AM | #7 |
Rep 750
Tires: Dunlop ZII, 255 square 10mm spacers to fit 4x rear 264 style rims
Suspension: Dinan e92 springs, BMW e92 Performance shocks, Dinan camber plates, TRW M3 control arms front and back, e93 front sway bar, poly RSB inserts Engine/Drivetrain Modifications: JZW Custom Tune, VSRF chargepipe, 550i clutch, custom clutch stop, CDV delete, BMS short shifter, m factory 3.46 LSD Exhaust: VK downpipes, golf tee mod On the to do list is intercooler and later maybe inlets. |
09-18-2017, 03:04 PM | #8 | |
Rep 545
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
09-18-2017, 04:44 PM | #9 | |
Joint Chiefs of Staff
24419
Rep 191,338
Also comes with a lifetime warranty. Their Downpipe and charge pipes are one of our most popular products.
09-22-2017, 04:32 PM | #10 |
Rep 750
09-24-2017, 10:02 AM | #11 |
Rep 7
Current setup:
Engine - Dinan stg 2 (came with the car) - VTT turbo's - BMS OCC - CDV delete Intake - BMS dci - VTT inlets Exhaust - Full berk race - VRSF downpipes Suspension - H&R front/rear sway bars Wheels - Apex EC7 18x8.5 front MPSS 235/40/18 - Apex EC7 18x9.5 rear MPSS 255/35/18 Haven't had any actual issues for the last year (roughly 30k miles) since I've owned it aside from regular maintenance. I use it all-year round, yes even in snow (different tire setup) and it's a great car in my experience. |
09-28-2017, 11:54 AM | #12 | |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
VRSF Downpipes ER Charge Pipe ETS Intercooler VRSF Inlets CSF Radiator |
10-01-2017, 06:41 PM | #13 |
C2H5OH
3930
Rep 2,146
2010 (N54) auto
RB relocate inlets VRSF 5" stepped intercooler CPE relocate charge pipe, Tial BOV N20 TMAP 1320 catless downpipes Berk resonated mid pipes fuel-it stg 2 pump, fuel line upgrade too BMS oil thermostat XHP stg 3 trans flash custom MHD tune (E-??, changes often) Whiteline rear subframe inserts E92 Koni FSD + Eibach pro kit springs If I where to do it all over (which I will eventually, - I would go with the 7" or bigger cooler right away - I would not relocate the intake. The heat soak in staging lanes is bad vs stock airbox. On track lapping there is no problems. Other than that I'm really happy with what I've bought and the returns I've got. 11's on minimal mods. Not gonna bitch about that. |
Tags |
chargepipe, downpipe, intake, intercooler |
