04-01-2024, 11:46 AM | #1 |
Rep 84
Ohlins -Mi01S1 (spring length)
So first a thank you to fe1rx and spidertri for the great writeup and analysis of the Ohlins and other great informative posts. Absolutely saved me tons of time! With that said my observations and some questions.
Context- 128i Track car build Assumptions/conclusions - hope to confirm. It would appear even with the new kit in order to run for example Apex 17x8.5 40 offset wheel with 235 tire (100 or 200 track tire) I still have to switch to a 7 inch spring for the front struts. It would also appear in order to get the most clearance from wheel/tire to strut and spring perches, I would need to use the shock spacers fe1rx has developed. I am referring to the spacer on the shock tube, not the wheel spacer. Are these available from fe1rx? Thanks again.
2011 128i
2011 Cayman 2007 Cayman S -Sold - no regrets 2007 Exige - Sold - Double Dang it!! 1990 M3 - Sold - Dang it! |
04-02-2024, 07:45 AM | #2 |
Rep 473
Drives: 11 128i 6MT Sport
Running a 17x8.5 et40 with a 235 shouldn't require any special parts for the ohlins. I ran 17x8.5 et40 with 245 initially and all I had to do was roll the rear fenders. I use those same wheels now as my street wheels w/ 225 tire and I just bolt them on and go between events.
When I moved to 17x9 et52 and a 255 tire, I needed a 15mm spacer in the front and 6in spring on the ohlins. The strut spacer from fe1rx just gave me the ride height that I wanted, and also increased clearance to the 255 tire.
11 128i slicktop
13 WK2 19 Alltrack S |
04-02-2024, 08:17 AM | #3 |
Rep 3,651
Keep in mind that spring rate is a factor with spring length. A stiff spring and a softer spring can be different lengths and ultimately give the same "height" since the car will compress them different amounts. You might need to also say what springs you plan to run.
04-02-2024, 09:03 AM | #4 |
1Addict
3245
Rep 7,913
Can you switch to the F8x front spindle and then use E9xM3 front dampers? They have an independent height adjuster allowing you to set height and preload separately and maximize clearance.
04-02-2024, 10:31 AM | #5 | |
Rep 84
Thanks much for the fyi
2011 128i
04-02-2024, 10:42 AM | #6 | |
Rep 84
2011 128i
04-02-2024, 10:44 AM | #7 | |
Rep 84
I researched this and it is a very high level of effort which I am not sure would meet my objectives for the car etc. Thank you for the input as always!
2011 128i
04-02-2024, 02:52 PM | #8 | |
1Addict
3245
Rep 7,913
I did use an adapter caliper bracket to use the front rotor from the E46M3CSL, but otherwise it's all E82/1M stuff.
rackhenry13.50 |
04-04-2024, 03:12 PM | #9 |
Rep 14
What is the benefit to using the F8X knuckle instead of the 1M/M3 version? Does the F8X use the same offset wheel as the 135i? I've done a rear conversion and will be doing a front at some point.
04-05-2024, 10:49 AM | #10 |
1Addict
3245
Rep 7,913
F8x offers a bit more static camber so don't need adjustable plates necessarily. If I recall it's also lighter and accepts E82 brakes.
04-05-2024, 10:51 AM | #11 |
Rep 3,651
04-05-2024, 11:23 AM | #12 | |
Rep 84
Hi Shock, I read your build thread man! pretty cool build!
2011 128i
04-05-2024, 03:13 PM | #13 |
1Addict
3245
Rep 7,913
Yep. M Camber arms M uprights slightly lowered and dinan fixed plates can get you to -3deg. No need for a adjustable plate that limits your alignment shop options and will require additional maintenance.
04-05-2024, 04:41 PM | #14 | |
Rep 84
Questions, when I looked up the price of the E46M3 CSL rotors they were 1k or so. Given its a track car, that's a consideration as I treat rotors as consumable items. Is there a less expensive place to source them or other brake rotor and caliper options? I really do like the idea of the F8X uprights vs camber plates if not needed.
2011 128i
04-09-2024, 03:51 PM | #15 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
04-09-2024, 04:19 PM | #16 |
Rep 84
Thanks Harold, (bad copy paste). I have determined that I need the 7 inch for the front . Will reach out when I am going to order the springs.
2011 128i
04-10-2024, 01:05 PM | #17 |
3893
Rep 54,605
Drives: F80 M3
05-23-2024, 07:03 AM | #18 |
Rep 45
I’m using a z65-152-090 with:
- 255/40/17 re71rs - 17x9+42 - 5mm spacer - M3 control arm - Vorshlag camber plates Very minimal tire-lower spring perch clearance, but enough that it doesn’t rub |
