| 04-21-2008, 11:15 PM | #1 |
Donkey Kong King
106
Rep 1,129
135i Oil/Filter Change video
| 04-22-2008, 01:05 AM | #6 |
![]() ![]() ![]() ![]() 54
Rep 799
Great vid John!!!! I learned a lot from that video...like the o-rings and washer come with the filter and there is a nice little trap door to drain the oil. I was worried you would have to remove a large section, plus it is easy to remove the filter and not have oil all over. There is no way I am paying $130 now when the parts are only like $60!!!
PS. You have to love the big bag of yellow Costco Micro towels!!! Thanks.
| 04-22-2008, 03:33 AM | #8 |
NRA Life Member, BMW CCA 30 year member
281
Rep 2,614
Good DIY, John. Thank you.
Resigned 1ADDICTS Moderator
![]() “To disarm the people is the best and most effective way to enslave them.” – George Mason |
| 04-22-2008, 09:51 AM | #9 |
![]() 62
Rep 1,015
Thanks for this ... Can you send me the movie so I can keep it to review?
Thanks, Crowley (kraventh1@tx.rr.com)
![]() The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
| 04-22-2008, 10:49 AM | #11 |
formerly izzo/comeback
369
Rep 3,380
great write up
! we should do this in at a local meet... and grill! i dont have any of that space or tools available in nyc 8(
BMW CCA # 418268
| 04-22-2008, 11:05 AM | #12 |
![]() 13
Rep 249
Great video...but did you just get underneath the car with just jacks supporting it? I didn't spot any jack stands. Just want to throw it out there but use some jack stands!! Don't want to see anyone here as another statistic :wink:
| 04-22-2008, 11:07 AM | #13 |
Donkey Kong King
106
Rep 1,129
No, I removed the drain plug and let the oil start to drain, then I moved up to the filter. I left the drain plug out during the filter change. After the new filter was installed, I replaced the drain plug with new crush washer.:biggrin:
| 04-22-2008, 11:15 AM | #15 | |
Donkey Kong King
106
Rep 1,129
However, it was not supporting the car...the car was lifted and held by two jacks. This was just a fast DIY, Safety is up to each person ![]() |
| 04-22-2008, 11:18 AM | #16 |
Donkey Kong King
106
Rep 1,129
I found on another forum to torque the drain plug to 25nm. Not sure if this is correct. When I removed the drain plug it came off very easy...surprisingly easy:biggrin:. I tightened it to a snug fit and just gave a little extra turn, this is how I've done all my cars for years, never had an issue.
| 04-22-2008, 02:19 PM | #19 | |
Rep 416
Nice one
I shall be changing my oil in another 5000 miles. Just a quick question about jacking up the car. I noticed that the hard-plastic jack points are pretty easy to damage if you try and use the trolley jack on them directly. Did you use an adaptor in between the jack and the car jack cup?? Just wondered as I plan to change the CDV next weekend. Cheers, Mad Chemist. |
| 04-22-2008, 03:12 PM | #20 | |
Donkey Kong King
106
Rep 1,129
I actually used an extra plastic floor tile between the jack and the plastic jack point on the car. After the job I actually had an impression on the plastic floor tile of the plastic jack point. However, I had no damage to the jack point on the car. I suppose using some wood would work also. The bad thing, is there is not a whole lot of clearance between the jack point on the car and the jack when its completly lowered. Cheers...:headbang: |
| 04-22-2008, 04:39 PM | #21 |
![]() 13
Rep 249
| Bookmarks |
