      03-28-2009, 12:23 PM   #1
fmxomar
Drives: bmw 135i
cut/grinded fenders > rolled fenders
well i had my rear fenders cut/grinded last night. most importantly it gains more room than rolling, looks much cleaner than rolling, and no chance of cracking paint.
      03-28-2009, 12:32 PM   #2
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1253
Drives: pokingly flush
2009 135i  [8.26]
so hows the clearance now? no more rub??
      03-28-2009, 12:36 PM   #3
ki__
Drives: 19 M2C 6MT
did u do it yourself?
      03-28-2009, 12:42 PM   #4
fmxomar
Drives: bmw 135i
Definatly no rub hahah. im actaully gonna add spacers make it super flush(no i dont care about any of your opinions).. and eventually get wider wheels maybe 10.5 inch
Anyone in san diego or L.A. area that wants it done the guy is a pro and guarantees no rubbing. Hes super cool and you will be happy with the result for sure. the cost is 350-400$
he had some cut and widened 10.5 inch wide csl reps haha we test fitted them just for fun. would need some serious tire stretch to pull that off.. or more + offset
      03-28-2009, 01:09 PM   #5
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
dam i cant wait to see pictures with thoughs csl mounted
      03-28-2009, 01:21 PM   #6
Chewyjr15
1 addict and proud!
42
Drives: jb 135 on order
can you pm me the guy as i would like to do this so i can fit some fatter rubber under there.
Thanks
2009 135 in transit
jet black, coral red, 6mt. sports, hifi, ipod usb, idrive
parts sitting in garage: RR intake, plenum, ddv, cdv, catless dp's, o2 sim, catback, bmw performance shifter, m door sills, cf spoiler, cf mirror caps, cf grills, cf pedals.
      03-28-2009, 02:26 PM   #7
fmxomar
Drives: bmw 135i
Thanks
pm'ing right now
      03-28-2009, 02:57 PM   #8
ptack
ptack's Avatar
2008 135i  [6.50]
I wish BMW had just flared the wheel wells out a little father.
      03-28-2009, 03:05 PM   #9
fmxomar
Drives: bmw 135i
dont we all
      03-28-2009, 11:35 PM   #10
driftdriven
Drives: BMW 135i
ya but we would still try to fit wider wheels and tires even if it was wider......you know I'm right LOL
      04-15-2019, 07:13 PM   #11
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Back from the dead.
Thanks for sharing this information. Looking to get this done. Have you run into any issues with the the fender splitting where it meets the wheel well?
Do you remember what he used to do the cutting? Also, can you please tell me where he is located and his contact information?
      04-15-2019, 10:12 PM   #12
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Back from the dead.
Huge +1 on this. Will happily follow suit but need to know how to finish the job appropriately.
2010 135i 6MT Jet Black
houtan707.00
      04-16-2019, 06:58 AM   #13
low135
Drives: E88 135i
Might be the oldest necro I've ever seen lol 10+ years. That's impressive.
BTW I had to do this when I was going through some things with my air ride/spring/shock debacle. We took a cutoff wheel and just slowly worked our way around the fender at the edge. Finished off with a sander and some black roll on anti rust paint.
houtan707.00
      04-16-2019, 08:39 AM   #14
Soterios
BXR
575
Drives: 2012 135i
I just had my fenders rolled by a body shop. I threw some photos up of the lips and the fitment after.
I'm running Arc8's in their staggered set up, but with additional 10mm spacers in the rear. Currently on stock suspension.
They almost never rub unless I go over a significant dip at highway speeds.
houtan707.00
Matticus913474.50
      04-16-2019, 09:24 AM   #15
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I know right!
The problem is, I can find a bunch of posts on rolling or cutting, but nothing definitive on how to do either.
Do you recall how much you cut off? Is it the entire lip or just a few mm? The concern with cutting is the outer and inner fender will split. See this link for pictures at the bottom. I read that if you cut the lip but leave the spot welds holding the two pieces together, it should be fine. But I found posts saying the two fenders separated in this scenario as well.
https://www.e90post.com/forums/showt...=839461&page=3
      04-16-2019, 09:28 AM   #16
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks for your post. Do you know how they went about rolling your fender? Did they remove the sealer goop that is supposedly above the lip?
That amount of clearance would be perfect for me. I am also on ARC8s, et62, 275s in the rear. I have the slightest rubbing with 3mm spacers, only on my passenger side. It is rubbing on the fuel filler neck. I am going to investigate if pushing the wheel out another few mm will give me the inner clearance I need.
If not, I need to revert back to stock height upper shock bushings because I believe the issue will be that I have too much suspension travel with the TC DA shock and dinan upper shock mount.
      04-16-2019, 09:30 AM   #17
Soterios
BXR
575
Drives: 2012 135i
I'm not 100% sure, but he did mention removing that sealant (or some of it) before rolling.
houtan707.00
      04-16-2019, 09:38 AM   #18
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks. Did the fenders bow out at all or does it look stock from the outside?
Anyone know the best way to remove the sealant?
      04-16-2019, 09:58 AM   #19
Soterios
BXR
575
Drives: 2012 135i
It looks stock. I'm not sure there were any changes to the outside
houtan707.00
      04-16-2019, 11:52 AM   #20
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
houtan I'd just cut them. Rolling is a pain. Heat gun and sander wheel got rid of my goop but didn't gain much with the roll. Supposedly the apex +58 offset doesn't rub the filler.. dunno, I'm getting ready to fit 275 square so we'll see I guess.
I'm going to cut mine and see how it goes
Also I think it's Monroe that make the high density stock height RSMs, but I'm considering gettjng rid of my dinan upper bushes too.
houtan707.00
      04-16-2019, 12:30 PM   #21
Soterios
BXR
575
Drives: 2012 135i
The Apex wheels rubbed even with no spacers and stock suspension, which is what drove me to rolling. I'm +58 in the rear. If I lower the car, add a little camber, and the rubbing gets worse, I'll probably take it back in to have material removed.
      04-16-2019, 12:34 PM   #22
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks brother. I am good with cutting them if I can get confirmation the two fenders will not split like in the thread I posted earlier. That is the last thing I want to happen.
it seems like Soterios got a really good roll looking at his pictures. Is your roll like his? That would be plenty for me.
Totally agree dealing with that goop is a pain in the butt.
So I was running a 5mm spacer with my arc8s which puts the offset at 57, about 1.8 degrees camber, Sumitomo htr III 275s. Drivers side was good. Passenger side would catch on the fender lip closer to the front of the lip. I think I can take an angle grinder and shave down the passenger lip a tiny bit and be good. My car is on jack stands until I figure out how bad the tire is hitting by removing the spring and jacking up the suspension until the tire hits the filler.
I actually bought AKG black upper shock bushings. I believe they are stock height, stiff, and priced much better than powerflex. But, my preference would be to fix this without changing anything in the suspension. The extra travel from the shorter shock and dinan bushings is awesome and my car rides really really good.
