Closed Thread
      08-10-2011, 06:13 PM   #1
Cal@Sonic MS
Cal@Sonic MS's Avatar
Drives: bmw
♦ Sonic MS | First Look : Verstraβe Motorsport Weight Optimized Wheel Spacers
We at Sonic MS are proud to present an industry first - pentagon shaped wheel spacer that is now available to the BMW community.
Inspired by BMW Motorsport and precision milled in the United States out of T6061-T6 aircraft grade aluminum, Verstraβe (pronounced Verstrasse) weight optimized wheel spacers utilize an industry first pentagon shaped design in order to minimize weight without sacrificing the structural integrity of the spacer itself.
Verstraβe spacers are machined with surgical grade precision utilizing tolerances within 1/1000th of an inch, this guarantees a perfect fitting spacer that is hubcentric and virtually eliminates any risk of vibration issues. In addition, Finite Element Anaylsis (FEA) simulations are run to ensure the weight optimized design of the spacers does not sacrifice structural integrity.
Due to the unique pentagon shaped design, each spacer must be machined out of a rectangular block of solid aluminum, as shown below.
As a finishing touch, each Verstraβe weight optimized wheel spacer is anodized in a matte silver finish for additional strength and corrosion resistance.
Each Verstraβe Motorsport Technik Wheel Spacer set includes matching extended lug bolts which are dacromet coated in an OEM black finish for corrosion resistance.
These spacers will be available in 5mm, 10mm, 12mm and 15mm sizes.
Please let us know what you think.
Closed Thread
