Reply
      10-24-2011, 09:33 PM   #1
m3kerry
SCCA STU
m3kerry's Avatar
Drives: 335i Dinan stage 2 / 1 M
What is the max tire size anyone has fitted in the front?
I am going to try to run out to Dallas for the next bmwcca event to get some seat time on some borrowed r comps and need to figure out what size to run up front.
Thanks to: Hixson BMW, Race-Keeper, Koni, BimmerHaus, & Hoosier
2012 SUMMER NATIONALS SCCA PRO-SOLO BONUS CHALLENGE WINNER
2012 SUMMER NATIONALS SCCA PRO-SOLO A STOCK CHAMPION
2012 SCCA DIXIE A STOCK CHAMPION
www.facebook.com/thatsrightracing
m3kerry is offline   United_States
      10-24-2011, 10:54 PM   #2
M3 Adjuster
Drives: 1988 M3 gone .. 1M HERE!!
I am working on getting my car to Vorshlag this week sometime so we can hopefully find this out, as well as enable Terry to take measurements to see if they can make a camber plate for the stock springs.
Lone Star BMW CCA Chapter president, Chief Driving Instructor
M3 Adjuster is offline   Reply With Quote
      10-25-2011, 12:00 AM   #3
Wolfpack
Wolfpack's Avatar
Drives: Everything in my garage
Nice to know that someone is going to be looking at this sooner rather than later. Post up when you know more.
Wherever you go...there you are.
Wolfpack is offline   Reply With Quote
      10-25-2011, 01:11 AM   #4
Fundahl
Drives: VO 1M, 300zx TT
Interested in camber plate!
Fundahl is offline   United_States
      10-25-2011, 06:15 AM   #5
m3kerry
SCCA STU
m3kerry's Avatar
Ken o has 4 285's on 18's but I find a couple of 275's I think for the front.
      10-25-2011, 09:07 AM   #6
M3 Adjuster
Yup... Ken and I had planned to do the same.. but since Terry has zillions of spacers available and a lift....
      10-25-2011, 09:09 AM   #7
MusclezMarinara
Drives: VALNCYA
camber plates a friend of mine did it on the 1M looks sick!
MusclezMarinara is offline   United_States
      10-25-2011, 10:52 AM   #8
Fundahl
Do you know what brand and where to purchase? Is it 1M specific?
What do you guys think about 265/35R19 F and 285/30R19 R on stock rims?
      10-25-2011, 10:53 AM   #9
m3kerry
SCCA STU
m3kerry's Avatar
So you think the 285's will work with a spacer?
      11-07-2011, 02:59 PM   #10
M3 Adjuster
Ok.. Sorry for the delay on this... Still waiting for Terry to let me know when to show up for measurements on the camber plates.. I will ping him again..In the meantime.. went to my friend Ken O's house this past weekend with my BONE stock 1M. No camber plates..no suspension.. bone stock! We decided to test fit wheels and tires on my car... He has several sets of wheels.. All wheels are 18 x 10 APEX ARC-8. We test fit and dropped the car down..sorry... no rolling around... no driving..
First off.. we decided to go big.
285/30/18 Hoosier A6
the good.. Rear fits easy.. 305s anyone? Maybe even bigger on an 11" wheel if one wants to go crazy.. Front seems to fit fine with respect to the fender.. the tire does stick out 1" further than the body work. there appeared to be no issues contact with the spring/perch.
the bad... The front tire rubbed.. ever so slightly on the inside front wheel well as the wheel was turned towards full lock - The part of the innerwheelhouse that rubs is in the front bumper, right wherre there is a radiator/cooler...
left side..
right side..
the ugly.. - Dunno.. Oddly.. the panel where this radiator/cooler is in the wheelhouse is in a spot that seems to move naturally. Slight pressure on the panel allows it to move in away fom the tire. While the movement inward from the tire was minimal at rest.. this could ugly at speed at full lock.. Especially if one were attemping to autocross. Could one possibly use 5-10 mm spacers and have success? yes.. but the 285/18 tire on a 10" wheel is already outside the front fenders.. so would only look more odd in that regard.
they stick out a lot though...
rear
clearly one can go WAYYY wider in the rear..
Next up.. we went with a Street tire.
Hankook Ventus RS3 275/35/18
The Hankook is a very rounded street tire. In many ways it actually fit WORSE than the 285/30 Hoosiers.
-the good.. - well.. none.
-the bad... - this tire has shoulders on it due to it's being so round, and there was much less room at the spring perch... could poss rub... And turning the wheel..DEFINITE contact was made with the front inner fender wheelhouse with the the cooler in it.
-The ugly - Don't go there with this tire.. Or very likely you will cause damage to inner wheelhouse parts
275/35/18 Hoosier
While a set of these was mounted and available.. I feel confident that these should fit. Maybe not 100$ confidence.. but enough that this weekend we will go ahead and bolt a set of these on the car and see how they do at an autocross. If they do ok this weekend.. then I will pick up some Continental Tire/Grand Am cup takeoffs for DE use.
The rim width appears to play a clear factor in whether or not there is contact between the tire and the front inner wheelhouse. For those that want to maintain a staggerred setup.. 18 x 9.5 front and 18x 10.5 rear is the easy way to go to avoid issues. more tire on a 1/2" wider wheel. I personally am hoping to be able to rotate tires, as well as utilize several wheels of the same size.. so I am going to push forward with seeing what fits on 18x10 all around.
      11-07-2011, 05:31 PM   #11
BMW Gator
BMW Gator's Avatar
Drives: 1M/e90/GTS/Rubicon/FJ40/+
"What do you guys think about 265/35R19 F and 285/30R19 R on stock rims?"
BMW's MotoGP Safety Car is running 255/35 19F and 285/30 19R
BMW Gator is offline   Reply With Quote
      11-07-2011, 06:26 PM   #12
Wolfpack
Wolfpack's Avatar
That is my biggest hope also. I have tried the staggered route before and found the lack of being able to rotate a major cost and pain in the *** factor.
Keep us up to date on this. Thanks Mark.
      11-07-2011, 07:25 PM   #13
gobuffs
Drives: 88 M3.2
Are you ever going to learn?
gobuffs is offline   Reply With Quote
      11-07-2011, 07:29 PM   #14
M3 Adjuster
? umm... no? I'm too cool for school..
learn what? I will see if Ken's wheels with the 275/35s fit this weekend at an autocross.. if so.. then I'll be buying up as many takeoffs as I can stack in the garage.. lol. That will set me up for TWS.
Are you referring to the "false economy" of used tires? These are for DE.... and a set of takeoffs from TMS or Bimmerworld... at $350 set... vs... $350 APIECE.. Yeah.. I'm gonna go cheap for a bit..
      11-07-2011, 08:10 PM   #15
MusclezMarinara
Drives: VALNCYA
I think a 305 will fit on 19s no spacer
      11-07-2011, 11:54 PM   #16
HP Autowerks
HP Autowerks's Avatar
Drives: 2011 135i DCT & 2011 1M
Location: Santa Barbara, AST, Brembo, Eibach, H&R, GIAC, Koni, Quaife, Stoptech, Vorshlag,
It's about time Vorshlag is going through with this. I have been pushing them to get this ever since the E9x M3 came out in 2008.
265/35/18 will fit on the front, but most tires will rub on the inner fender liner on or near full steering lock. 275/35/18 will also fit with a little bit more rub. Every car is a little different so you may or may not rub on the liner with yours.
HP Autowerks is offline   United_States
      11-08-2011, 05:02 PM   #17
m3kerry
SCCA STU
m3kerry's Avatar
Thanks mark. Ken sent the photo of the front today. I am real hopeful for the 265 / 19's from Hoosier after seeing it.
      11-08-2011, 05:14 PM   #18
gotboost426
Drives: 2011 1M and 2004 M3
Yep, Bimmerworld and they are Ground Control
Thanks dude!
Would look sick!
gotboost426 is offline   Reply With Quote
      11-08-2011, 06:18 PM   #19
gobuffs
Drives: 88 M3.2
10 seconds per lap no grip scrubs. Remeber? Some scrubs can be good but in general not so much.
      11-21-2011, 02:57 PM   #20
M3 Adjuster
Thanks to Franklin for bringing his wheels and tires up to TWS on Saturday.
We were able to succesfully mount four 18 x 10 Apex ARC-8s with 275/35/18 Koni Challenge ( rebadged Hoosier) tires on my car. My car is bone stock... no spacers were needed.. I did two sessions on track with the tires.. no curb hopping as this track is not really conducive to that... after two sessions including some parking lot manuevers, I am happy to report no evidence of rubbing anywhere... even with the 10" rims up front.
      11-21-2011, 03:19 PM   #21
MDORPHN
Drives: AW 1M
That's great.
What offset?
Neil
MDORPHN is offline   Reply With Quote
      11-21-2011, 03:35 PM   #22
Franklin Joseph
Drives: X5 - MCS - M3
25 offset
Franklin Joseph is offline   Reply With Quote
Reply
Forum Jump
