      10-28-2012, 12:47 PM   #1
Artemis
Moderator
Artemis's Avatar
42597
Drives: BMW M2C - BMW X1
Exclamation "Engine coolant level too low" warning
Clocked almost 16K kms with my 1M. Never issues.
Upon starting the (cold) engine today the OBC immediately showed an "Engine coolant level too low" warning (see picture below; the engine icon also featured on my OBC where normally the time is indicated). Never experienced any such warning before. Also never got an engine warning light lighting up. My 1M is sheltered at night. Had been parked for at least 15 hours. It was a cold night but no freeze temps.
After a careful 100 meters drive I switched off the engine to check the manual (see pages 219-220 of the "BMW 128i/135i Owner's Manual 2012" (USA) pictured below - my 2011 European manual features a similar text on page 225). Upon restarting the engine, the warning had vanished. Rest of the day, for all drives: "OK" - "No Faults" when checking the "Vehicle Info"/"Vehicle Status" via the iDrive. So just a short-lived warning. Also nothing abnormal (oil temp remained normal). Got to wait for the engine to cool down to check the engine coolant level.
Just a false reading (glitch) or something to worry about ? Anyone experienced this yet ? Any recommendation regarding the appropriate type of engine coolant to be added (if required).
Excerpt of the "BMW 128i/135i Owner's Manual 2012" (USA) (made available in the Manuals sticky: http://www.1addicts.com/forums/showp...82&postcount=1)
///M is art Artemis
      10-28-2012, 12:54 PM   #2
MDORPHN
Drives: AW 1M
What was the level in the reservoir?
Neil
      10-28-2012, 01:14 PM   #3
You need to add some coolant, Luc.
Checking & adding engine coolant DIY
http://www.1addicts.com/forums/showthread.php?t=401672
      10-28-2012, 02:25 PM   #4
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Just stop by the dealer for a top off. I had to do that in the past myself.
      10-28-2012, 09:58 PM   #5
Maximus_Prime
Maximus_Prime's Avatar
29
Drives: '11 1M, '12 Q5 2.0T, '06 Miata
Same thing happened to me at around 16k miles. I took it straight to my local dealer for a quick top off and that took care of the message.
2011 1M | Valencia Orange | #655 of 740
BMW Performance CF Spoiler | BMW Performance Shadowline Grills | Gloss black iND side markers
      10-29-2012, 04:20 PM   #6
Artemis
Moderator
Artemis's Avatar
42597
Thanks guys. Can recommend Dackel's DIY thread (http://www.1addicts.com/forums/showthread.php?t=401672).
So I checked the engine coolant level (cold engine to avoid scalding/misreading). Definitely no false warning. The red floating dipstick was no longer floating between minimum and maximum level as it should. Worse, my first thought was "What the heck, where did the dipstick go ?". Then I looked inside the rabbit hole and saw it resting on the bottom of its pocket with zero coolant surrounding it. It had sunk to "Can't Go Deeper" level. Red or blue, it was desperately in need for a pill/fluid...
Quite puzzling that, once the 1M OBC/iDrive threw the warning at me upon cold start yesterday, that warning subsequently vanished for the rest of the day, as if it had been a faulty sensor reading (quod non). Furthermore, "Too Low" was quite an understatement. Dang, that sensor should be more vigilant to warn us ! Message to all: get a spare bottle of engine coolant (see last picture), just in case of need. Only EUR10.
For your info some BMW 1M values:
(source: http://www.automobile-catalog.com/oi...1_m_coupe.html) (probably equal values for the 135i: http://www.1addicts.com/forums/showthread.php?t=315057)
  • BMW 1M engine lubricant oil capacity: 6.5 liter | 6.9 U.S. qt | 5.7 imp. qt
  • BMW 1M engine coolant capacity: 10.4 liter | 11 U.S. qt | 9.2 imp. qt
  • BMW 1M fuel tank capacity: 53 liter | 14 U.S. gal | 11.6 imp. gal
  • blood in an average adult human body: 5 to 6 liter | 1.3 to 1.6 U.S. gal
It took 0.85 liter of BMW approved engine coolant to get the red floating dipstick hovering back to max level again (as shown on the diagram printed on the engine coolant reservoir: see penultimate picture). This means that ± 8.2% of the engine coolant has vanished (evaporated? leaking? bleeding?) in less than 16K kms (no track use). Uh, is that supposed to be normal ? Go see the dealer for a check-up ?
Time for some pictures:
Engine coolant dipstick resting on the bottom of its pocket with zero coolant surrounding it (instead of floating between minimum and maximum level):
Refilling:
Floating dipstick hovering back to 'max level':
Final result: 'max level':
BMW diagram (picture courtesy of Dackel):
BMW approved engine coolant and the quantity I used (850 centiliter):
(left picture courtesy of Dackel - right low quality picture is mine):
Size:  36.6 KBName:  Coolant_5a.jpg
///M is art Artemis
      10-29-2012, 04:47 PM   #7
^^Nice job - Luc!
      10-30-2012, 03:27 AM   #8
HERR FSTIR
HERR FSTIR's Avatar
Drives: LBB M2C, VO 1M, GSA 1200
I haven't had any coolant issues with my 1M, but when my 335 was new I had to refill the expansion tank at least once. Since then, it hasn't demonstrated any unusual consumption of coolant. I assumed the car was a bit under filled from the factory.
I would carefully inspect the coolant hoses and couplings for any signs of a leak. Specifically look for any coolant pooled on the splash shield beneath the radiator. If there is no sign of leak, then I would just wait and see if you continue to need additional coolant. The only other concern would be a leaking water jacket from a defective gasket or block which seems improbable given your relatively low mileage.
      11-02-2012, 03:41 PM   #9
jteef
Drives: m3
are you not supposed to mix coolant with distilled water 50/50 on these engines?
      11-05-2012, 07:07 PM   #10
671rover
Drives: '94 D90, '95 D90 SW, '11 VO 1M
That's what I was thinking when I saw Artemis pour coolant straight from the bottle unless he has mixed it already. I think the mix ratio depends on conditions which are stated in the bottle if I remember correctly.
      12-12-2012, 11:04 AM   #11
NORAGRETS
NORAGRETS's Avatar
813
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
just had the same issue with my 135i...coolant warning comes on, then after 1 or 2 minutes of driving, goes away...
going to top off right now!
Funny because if you get an SES or CEL light, it will STAY on until it is cleared or the issue is resolved...maybe a software glitch?
      12-12-2012, 11:12 AM   #12
Not always so. Some ECL(engine check light)'s are a "soft" code.. meaning after awhile of driving and so many start/stops... the fault will erase itself. Like IF you forget to put the gas cap back on... it will reset in 200 kms or after a few restarts. This is why with some faults... when the car goes to the dealer... the fault won't be there - saved. Only for major emissions stuff to the fault take a "hard" set/code.
      12-12-2012, 01:04 PM   #13
Papethova
Drives: '08 135/ '11 1M
My 135 had this in its first 10k miles and my 1M did too... the 1M needed almost a liter to top off.
Both cars asked for oil too. After 10k miles the 135 never was low on coolant or oil again (I sold it with almost 30k). Lets see what the M does (just passed 10k)
      12-13-2012, 05:03 AM   #14
Newby
1Mtech
Drives: BMW
I have found the coolant level to settle after some time on new vehicles, it is just air pockets working there way out. In theory it should be bled properly from the factory but this isn't always the case.
Most climates 50/50 mix of coolant/water is ideal. If you are doing a once only top up, water is fine.
      12-18-2012, 11:32 AM   #15
Artemis
Moderator
Artemis's Avatar
42597
Status update:
No warning anymore since topping off late October 2012.
Fifty days have lapsed so checked whether the coolant level had eventually dropped again.
Result: floating dipstick still at 'max level' (thus unchanged since refill - no drop).
Will check again later this Winter.
///M is art Artemis
      12-19-2012, 09:07 AM   #16
NORAGRETS
NORAGRETS's Avatar
813
Agreed, breaking the engine in from 0-8000k miles i added 3 liters of oil before it stabilized, 1 at about 1k and 2 at about 5k...
my guess is the coolant is the same and will stabilize as well...
anyways, my engine has been idling much better and havent had any more lights, codes, studders...amen
      11-22-2013, 12:47 AM   #17
Artemis
Moderator
Artemis's Avatar
42597
Just for the record:
  • those days (Oct 2012) (coolant refill): ± 16K kms.
  • now: over 32K and the phenomenon never reoccurred (so far).
Maybe the car was a bit low on coolant when delivered (Sep 2011) ?
///M is art Artemis
