      01-12-2013, 08:15 AM   #1
Simon930
Drives: FBO 135i Auto
19x8.5 et35 and 19x9.5 et35 on 135i??
I'm looking to get some wheels in 19x8.5 et35 and 19x9.5 et35 and will probably be running 225/35/19 front and 245/35/19 rear.
Do you think this will fit with rolling all 4 corners??
I am also running BC extreme Drop coilovers..
Post any comments or your inputs
Thanks..
      01-12-2013, 09:25 AM   #2
b1aze
Just one more taste...
b1aze's Avatar
Drives: 2013 128i 6MT MSport
Will not fit easily at all. Lots of front camber and a narrower tire in the rear and maybe they will fit without rubbing.
      01-12-2013, 09:46 AM   #3
Simon930
I would do go as low as 215/35/19 front and 235/35/19 rear and roll all 4 corners. Would that work ?
      01-12-2013, 10:04 AM   #4
cooler2442
Drives: 1/18 Monte Carlo Blue E92 M3
Depends how low you are. I'm running ET37 19x8.5 front and ET38 19x10.5 rear. I rub in the rear with 265/30's but no rubbing in the front with 215/35's. I had to raise my rear, add negative camber, and roll it. Still rubbing.
      01-12-2013, 10:31 AM   #5
Simon930
If your running 19x10.5 et38 rear with a 265 I don't see why I can't run a 19x9.5 et35 with a 245/35 or 235/35 . I'll probably go with 215/35 in the front.
What do you think?
Thanks for all the feedback
Really appreciate it
      01-12-2013, 10:53 AM   #6
cooler2442
What do you think?
All I have to say is good luck. Everyone's car is different. I sold some Forgestar rims that my car had with 265/35's on the rears and I didn't rub at all. Person who bought them rubbed and he was on stock suspension when I was lowered.
No one will be able to tell you 100% until you try it.
      01-12-2013, 10:54 AM   #7
Simon930
Alright thanks man
I think I'm going to go with 215/35 front and 235/35 rear
      01-12-2013, 08:10 PM   #8
PurpleHeart135
Drives: 2009 135i
You wouldn't happen to be looking at the SSR euro type-f's would you? I noticed that is the offset they offer in the 19's as well and was wondering the same.
I think, however, have someone make you a wheel is the best bet to get an aggressive look which is what I assume you're looking for on the bc's.
Let us now how the 35 offset works out, im curious.
      01-12-2013, 09:57 PM   #9
Simon930
I'm looking into a different set of wheels
I will definetly post pictures up after I'm done
      01-12-2013, 10:38 PM   #10
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
What is the point of "making it work" just to end up running such skinny tires?
Seems counter productive to performance.
      01-12-2013, 10:48 PM   #11
Simon930
I didn't ask about performance
I like aggressive wheel setups )
      01-16-2013, 08:47 AM   #12
Simon930
just put the wheels last night heres a couple pics:
photoshoot coming soon
      01-16-2013, 02:15 PM   #13
JuL'
JuL''s Avatar
France
Drives: 123d e82 upgrade
not ugly !!!
the tyre rubs in the wings ?
123D E82 Ecu remap, no dfp, intercooler, ///M3 e93 arms, recaro pole position, pro race 1.2 wheels, carbone fiber ...
      01-16-2013, 03:27 PM   #14
Simon930
Originally Posted by JuL' View Post
not ugly !!!
No rub
      01-16-2013, 03:54 PM   #15
135IS
Drives: 09 LMB 135I / AW 1M
2009 135i  [7.00]
more pictures? the rear wheel looks kinda akward
LMB 135i: Gone
AW 1M: Current #211 of 220
      01-16-2013, 04:16 PM   #16
b1aze
b1aze's Avatar
That's....ummm.... aggressive? I guess?
      01-19-2013, 06:32 PM   #17
b1aze
b1aze's Avatar
That's a tragedy...
      01-20-2013, 07:58 AM   #18
Simon930
Originally Posted by KartelForged View Post
Those are very nice fitments for the one. now is you go lower you are going to dial in camber i had a set of those on my 2011 135i and i was super slammed and i rubbed like hell in the rear with the same set up you had, maybe you remember seeing this car i had to dial in a few degrees of camber tho, to make this work ,
Looks awesome
What size,offsets,tires are you running and how much camber dialed ?
      01-20-2013, 12:52 PM   #19
MS135I
Drives: M-sport 328i
Looks good. Are the rear fenders rolled at all?
      01-20-2013, 12:57 PM   #20
Simon930
Yes they are rolled aggressively
      01-20-2013, 01:32 PM   #21
Stohlen
Drives: AW 135i
2008 BMW 135i  [5.66]
What is the purpose of going FBO and then putting this kind of a tire setup on the car?
      01-20-2013, 01:40 PM   #22
Simon930
This doesn't effect my performance in a str8 line
