      03-18-2013, 12:21 AM   #1
int2str
int2str's Avatar
Drives: 2008 135i
Exclamation Michelin Pilot Super Sport on the track
Don't...
(2 weeks old; ~500 easy street miles) 1 track weekend; -3 camber...)
      03-18-2013, 04:53 AM   #2
Evice
Evice's Avatar
208
Drives: E92M3
Is that inside or outside edge?
      03-18-2013, 05:04 AM   #3
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
Did you go off? I got several track days and autox's out of mine last year. Same -3 camber (front).
      03-18-2013, 05:38 AM   #4
syenisch
syenisch's Avatar
Drives: 2015 435i Gran Coupe
Working just fine for me right now with -1.8 camber.
      03-18-2013, 07:40 AM   #5
Focusedintntions
Drives: 2011 135i M-Sport :D
I never had any issues with the 3 sets of fronts i've used on the track with -2.5 of camber. Where you maybe over driving the tires?
      03-18-2013, 07:40 AM   #6
1&done
1&done's Avatar
Drives: 2011 VO 1M
....wow, can you return, I've heard some local guys have problems like this w/ there R888s. They where warranted.
///1M #643 of #740
      03-18-2013, 11:27 AM   #7
int2str
int2str's Avatar
Drives: 2008 135i
Outside.
Heh, no off-track excursions.
Good for you!
Great!
Again, good for you!
Well, technically of course I was over-driving the tire. Chunks off rubber like that don't fly off just for fun .
      03-18-2013, 12:35 PM   #8
RimasRS
RimasRS's Avatar
99
Drives: BMW X3 SD
You should try to go back to tire shop. It is a sport tire so they should do something about it.
      03-18-2013, 12:37 PM   #9
int2str
int2str's Avatar
Drives: 2008 135i
No warranty for track driving.
      03-18-2013, 01:02 PM   #10
RimasRS
RimasRS's Avatar
99
Drives: BMW X3 SD
Does that mean they just overheated and went of by peaces?
Are those fronts?
      03-18-2013, 02:29 PM   #11
IGoFast1589
IGoFast1589's Avatar
52
Drives: 08 135i
If you start driving like a sharp shooter right off the bat without bringing the tires progressively up to temp you can kill tires pretty easily. Or if the course you're running is very choppy, like the final turn on Sebring, and you find your car is "side stepping" over road imperfections a lot then the tires can rip up pretty fast as well.
How do the inside edges look? What are you running for suspension? What road course were you running?
      03-18-2013, 02:52 PM   #12
int2str
int2str's Avatar
Drives: 2008 135i
1) Fine
2) Coil overs, camber plates, FSB, M3 bits
3) Chuckwalla Valley Raceway
      03-18-2013, 03:06 PM   #13
MightyMouseTech
MightyMouseTech's Avatar
4379
Looks like the tires were being overdriven and overheated.
Did you change camber at the track? What are your toe settings?
      03-18-2013, 03:12 PM   #14
int2str
int2str's Avatar
Drives: 2008 135i
No, I run -3 all the time.
Toe is near neutral (0).
      03-18-2013, 03:48 PM   #15
IGoFast1589
52
Drives: 08 135i
Originally Posted by int2str View Post
1) Fine
Chucwalla isn't choppy. Were you hoppin' curbs? Do all 4 tires look like that on the outside edges? What were you tire pressures set to?
      03-18-2013, 04:02 PM   #16
int2str
int2str's Avatar
Drives: 2008 135i
Touching curbs here and there, but not excessively or in a way that upset the car.
Front two only. Rears look great.
Tried for 38 hot. Was hard to keep consistent. Rear seemed fine at 38, front wasn't happy. Tried 40 hot in front on later sessions.
      03-18-2013, 04:17 PM   #17
blutattoo
Drives: 2012 135i
2012 BMW 135i  [0.00]
Mine lasted a bit longer, but I had the same issue. A lot of speed combined with very soft shoulders causes the PSS's to wear very quickly on the front outer edges. I found 34 hot in the front seemed to be the happy spot. Still 500 miles is much quicker than would be expected. I got about 5k out of the fronts with multiple track days on them and I drive very aggressively so unless you are drifting corners or scalloping(rolling over) the tires then they were probably bad to begin with. If they won't replace them and you want to stick with them you could buy a used set of fronts on ebay that match the wear on the rears. Or try a different set altogether, RE-11's are my preference for a combo of track performance and tread wear, but there are tons of options and opinions on tires here.
      03-18-2013, 10:34 PM   #18
Evice
Evice's Avatar
208
Drives: E92M3
Post a video of a session, and it would be very easy to tell.
      03-19-2013, 12:06 AM   #19
int2str
int2str's Avatar
Drives: 2008 135i
Not the whole session, but quckest lap:
http://www.1addicts.com/forums/showthread.php?t=817396
      03-19-2013, 05:11 PM   #20
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1864
Drives: 2006 MZ4C, 2021 Tesla Model 3
If you're turning sub 2:10 laps on STREET TIRES you're definitely booking it big time. When I saw that on Youtube posted on the San Diego FB page, I thought...300 UTQG tires, it's probably the Pilot Super Sports. Then I thought, those tires can't possibly look THAT good after that lap...
Very fine driving. Very fine driving indeed. And no, no tire shop is going to "warranty" those tires.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      03-19-2013, 05:28 PM   #21
int2str
int2str's Avatar
Drives: 2008 135i
Technically HPDE's are not timed events.
If I had to *guess* I'd imagine that lap was around 2:07.669...
But again, just guessing here...
      03-19-2013, 06:30 PM   #22
Kgolf31
Kgolf31's Avatar
486
Drives: 2007 Z4MC, 2012 128i
I'd love to see a lap with ZII, Rivals or RS3s mounted
