      01-17-2014, 07:55 PM   #1
n54oner
Drives: '09 135i
"Pop" while taking off, power down
I took off from a light onto the freeway, and within a second or so I heard a "pop" noise from under the hood, and immediately had limited power. No warning lights or limited throttle, just less power. I pulled off as soon as I could, looked under the hood, and found this:
(DV has "popped" out of the pipe)
The car seems to drive fine, just with the aforementioned limited power (seems like a normal 6cyl now with no boost). So, my questions are:
1. How is this fixed? Do I just push it back in, or if this normally happens, something broke?
2. If something broke, I'm out of 50k warranty, but I do have CPO. Is this something warranty would cover, or, would it be better for me to just buy aftermarket?
3. If I buy aftermarket, is it something I could install myself with limited mechanical skills and tools?
4. Is it ok for me to be driving it as-is until I can get it fixed?
Thanks guys.
      01-17-2014, 11:11 PM   #2
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
This happened to me at about 20k miles. Dealer fixed it. They said it just popped off and the tech took it off and put it back on. I've removed them and put them back on quite a few times sense. Should be pretty easy to do. Just rotate that white coupler. Then it pulls out. Take it out and see if the diverter valve separated from that coupler and see if you can get it back on. Check with the dealer and see if it's covered. Doubt it though. I didn't drive mine until it was fixed. But I guess if you go super easy on the throttle it should get you around. As soon as you get it out you'll be able to tell how it works and if it's actually broken just by looking at it. No tools should be needed.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      01-18-2014, 10:57 AM   #3
n54oner
Drives: '09 135i
Thanks for the info. It was dark when it happened so I couldn't look around too much, but I went out this morning.. and the charge pipe cracked / blew into pieces. So, it looks like I'm going to have to replace the whole thing. On to the classifieds section..
      01-18-2014, 01:42 PM   #4
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
Good luck!
      01-19-2014, 12:53 PM   #5
w3rkn
Drives: BMW 135is
What is that crap all over your engine..?
      01-19-2014, 12:55 PM   #6
n54oner
Drives: '09 135i
Sand. Drove through the desert not too long ago, haha.
      01-19-2014, 09:50 PM   #7
dorkdog
Big Mouth No Filter
dorkdog's Avatar
Drives: 128i Montego Blue 6MT Sport
why wouldn't this be covered?
We do not inherit the Earth from our parents; we borrow it from our children
      01-19-2014, 09:53 PM   #8
n54oner
Drives: '09 135i
What do you mean?
      01-19-2014, 10:29 PM   #9
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
Originally Posted by mdewyer View Post
What do you mean?
Why wouldn't you use your CPO and get a replacement charge pipe?
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      01-19-2014, 10:34 PM   #10
n54oner
Drives: '09 135i
Yeah, I considered that at first, but from what I've been reading, since I'm running JB I'd run the risk of another oem one busting too. I just bit the bullet and got an aftermarket with a bov.
