      09-07-2018, 06:47 PM   #1
135BANDIT
135BANDIT's Avatar
Drives: 135 BMT & X5 Msport
Battery pricing
Hi All,
I am about to replace the battery in our 2010 135 , I know it needs coding etc , but i was amazed at the price differential from the below.
  1. Mline bmw - $756
  2. GC bmw - $650
  3. Wside Bmw $775
  4. exide dealer gold coast - $265
The exide product is an AGM and 88ah , it seems crazy cheap ?
Any advice or other comments welcomed
Its also due for the Airbag and battery link recall
      09-07-2018, 08:27 PM   #2
Ric in RVA
Bergspyder
Ric in RVA's Avatar
Go to Exide. Buy battery. Buy bluetooth adapter and Carly. Code car to battery. Takes 2 minutes.
Those prices are insane.
Ric in RVA
      09-07-2018, 08:42 PM   #3
JBT2
JBT2's Avatar
Drives: 2015 435i
Wow! Those prices seem high.
Bought mine (genuine spare part Exide) for $298.70 with club discount from Westside BMW in Nov 2016.
I removed the old one and fitted the new. Took about 30 minutes.
Coded by RX Automotive - complimentary for being a regular customer.
      09-08-2018, 07:22 AM   #4
johnny135
The Exide AGM is the go. Got my Exide SSAGM77 for about $300 delivered. Already had obd and otg cables for MHD, bought Carly and coded and registered myself (original battery was not an AGM)
Varta batts seem to be a lot more expensive if you want them, Exide does the job.
      09-11-2018, 06:26 PM   #5
ansch
Drives: SGM 135i
RACQ.
You get a discount if you're a member and they do the install and coding for you.
https://www.racq.com.au/cars-and-dri...battery-finder
$280 for our cars
+ 3 years warranty
      04-10-2019, 01:35 AM   #6
racer_x
racer_x's Avatar
13
Drives: When He Has To
Hi Guys,
I am just looking for the symptoms of a dying battery an E82 135i.
Every now and then it does not want to crank at all... This is especially true when the engine is hot. Or when it's cold early in the morning. I assume that's when high cranking amps are needed.
Once it cools down, I can get it started on 1st or 2nd try.
My car is an MY09, does not have iDrive, and I'm not seeing any errors on the dash display.
Is this the battery on its way out? Or is it the alternator?
Car has about 85,000 kms and I suspect this is the original battery!!
Thanks for your help.
      04-10-2019, 04:44 AM   #7
Brule
Drives: 2007 335i e92 6spd man
Sounds more like high pressure fuel pump failing.
My 2007 battery lasted to 2014 there pretty good oem batteries.
Sympton of low battery
Battery symbol on dash
Rally slow cranking over
Not able to unlock doors with button on key
Just a ticking souns coming from alternator when trying to start
      04-10-2019, 04:48 AM   #8
Brule
If its not cranking at all then cranking later its not the battery.
Could be alternator but if its not firing straight up its got more issues then alternator.
Start by checking codes if possible.
      04-10-2019, 05:09 AM   #9
My1er135i
Drives: 11 E82, Deep sea Blue 6 speed
Originally Posted by 135BANDIT View Post
Hi All,
  1. Mline bmw - $756
  2. GC bmw - $650
  3. Wside Bmw $775
Hey there I got mine replaced in Central California for about $475ish from Bmw dealership.
      04-10-2019, 05:11 AM   #10
racer_x
racer_x's Avatar
13
No battery symbol on dash and I don't have a code reader.
It was in for the battery cable recall 4 or 5 years ago now but it has been flawless since. Can it be something loose?
Can anyone recommend a good workshop in Sydney's East?
      04-10-2019, 08:05 PM   #11
vtl
vtl's Avatar
Drives: 2008 BMW 135i MT
Originally Posted by racer_x View Post
Hi Guys,
Do you mean nothing happens at all when you press the starter button? Even a low battery will at least click the starter solenoid
Probably the starter motor, not an uncommon failure on these cars, usually the starter solenoid on it gets stuck and another attempt later and it fires up no problems. Does it crank strong when it does start?
      04-10-2019, 08:13 PM   #12
racer_x
racer_x's Avatar
13
It's intermittent. Yes when it refuses to start I get zero cranking. When it does start, it fires from 1st or 2nd crank. And no battery warnings.
Interesting about starter solenoid getting stuck. Might explain the zero cranking issue.
Looking at service records, the car is on its original battery / starter motor.
Would any of this leave any codes behind?
      04-10-2019, 08:41 PM   #13
vtl
vtl's Avatar
Wont be any codes, from your description definitely sounds like the starter motor. At the very least doesn't sound like a dead battery.
      04-10-2019, 08:43 PM   #14
racer_x
racer_x's Avatar
13
Thanks @vtl. I'll book it in for a check next week and report back.
      04-14-2019, 06:48 AM   #15
DR-JEKL
Drives: Space Grey E92 335i 6MT
flat battery experiences in my two occasions have always resulted in the cluster dropping out and nothing happening when i hit the start button
      04-15-2019, 12:39 AM   #16
racer_x
racer_x's Avatar
13
Turns out battery was on its way out. A new battery has been installed and we're all good to go again.
The auto lock / unlock feature has stopped working though, so need to go back and have that recoded.
