      01-06-2015, 09:50 AM   #1
hau_nguyen91
hau_nguyen91's Avatar
196
Drives: YMB 17 M3
Michelin Pilot Super Sport!!
I got an oil change yesterday at the dealership and they said I need to replace 2 of my rear tires for 820$ on the stock runflat tires which is super expensive for me.
I immediately hop on tirerack.com and order the Michelin non-runflat that I always wanted to get on the 135is for awhile now.
It was very hard to choose between the AS3 and SS but I went ahead with the SS since it have more stars? LOL
Anyway it out for delivery today already!!
Thanks TIRERACK FOR getting this out in less than 48 hours between ordering and delivery!! Can't wait to ride this 135is on a non-runflat!
      01-06-2015, 09:56 AM   #2
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Welcome to the club! ��
2014 M5 6MT
      01-06-2015, 10:17 AM   #3
135ivert
Drives: E88 135i,E70 X5M,E93 M3
Are you replacing the fronts too? I learned the hard way that you want to replace all 4 when switching from the runflats.
      01-06-2015, 10:49 AM   #4
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Just FYI. When in installed my winter wheels in November, I found that my rear PSSs needed to be replaced at only 8600 miles. Fronts look great and have approximately 70% tread remaining. The car has never seen a track, or been autocrossed, never used the launch control, and DTC is never disabled. Michelin warranty won't cover the replacement rear tires because the wear patter is uneven.
So enjoy the car but we ready and able to replace the rears before 15K miles!
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE
Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension
      01-06-2015, 11:36 AM   #5
hau_nguyen91
196
Drives: YMB 17 M3
I am replacing ALL four but after getting the PSS..seem like there more positive review on AS3 instead of PSS
      01-06-2015, 11:38 AM   #6
hau_nguyen91
196
Drives: YMB 17 M3
Wow..are you serious? why am I now just hearing about this?
What tires do you recommend that last 20K ?
      01-06-2015, 12:56 PM   #7
fcman
Drives: 2023 G87
I would have you alignment checked. My PSS have seen 8k miles, many hard launches, 6 autox events (and I drive hard), and I never drive with DSC on. The rears easily have 60% life left. Not even close to the wear bars.
      01-06-2015, 02:57 PM   #8
gap
Drives: 2008 135i
My rear PSS are at 20,000 and are getting close to needing replaced. Totally depends on how you drive. Below 40 degrees they loose a lot of grip so I am getting a set of Apex wheels to run PSS in the warm months and mount A/S3 on the stock wheels for the cold months.
      01-06-2015, 06:56 PM   #9
SHFT
SHFT's Avatar
Drives: '08 135i 6MT
My PSS are at the 4/32 line with 12k on them currently. Should get 16k out of them I'm hoping.
aFe, UUC, Macht Schnell, Bilstein, Swift, REMUS, ETS, BMS and some other shiii...
      01-06-2015, 07:20 PM   #10
Overpar56
Proud AARP member in good standing
Overpar56's Avatar
Drives: Me nuts
I've seen you drive. I've tried following you. Flames shot from the rear tires.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver.
      01-06-2015, 07:20 PM   #11
It doesn't mater what tires you have... our cars will burn thru the rears in 8K to 18K. That's the price we pay for owning a small powerful rocket.
PSS's are the way to go. They are such a great tire!
      01-07-2015, 12:02 AM   #12
MarkkyyMan
MarkkyyMan's Avatar
Drives: 2010 BMW 128i
+1 on PSS
      01-07-2015, 11:35 AM   #13
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Apparently it's not the alignment, it's the factory camber settings coupled with how I drive. Alignment was done by the dealer at 2K when the PSSs were installed, again at 10K when the PS was installed, then again at 13K when the PSSs were removed and needed to be replaced.
Have you looked at the wear bars on the inside shoulder of the rears? I'll post a photo of mine later.
EDIT: photo attached of rear PSS at 8.6K miles.
      01-08-2015, 06:49 PM   #14
Matt Z
Drives: 2011 328i Sedan 6MT
2014 X1 sDrive  [8.67]
2011 328i Sedan  [10.00]
2009 135i Coupe  [0.00]
Just put a set of PSS on my car last weekend. Much better than the Run Flat tires so far. They're very quiet too. I also have them on my E90 and I've put almost 40k miles on them so I agree its how you drive which dictates their lifespan!
2014 Glacier Silver Metallic X1 sDrive
2011 Space Grey 328i Sedan - 6 Speed
2009 Crimson Red 135i - 6 Speed
2013 Le Mans Blue Metallic 135is - 6 Speed SOLD
1989 Schwarz 325i - 5 Speed SOLD
Dackelone10538.50
      01-08-2015, 08:12 PM   #15
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Only because I didn't want to get rear-ended by the AARP member behind me driving a car manufactured with crappy brakes...
      01-09-2015, 09:19 AM   #16
3002 tii
3002 tii's Avatar
2282
Drives: Z4 M, X5, GX460
Get the car aligned NOT at dealer. Factory alignment still sucks and getting it realigned to those same settings won't improve tire wear.
Follow for latest mods
Dackelone10538.50
      01-09-2015, 09:24 AM   #17
Yes. And tell the shop you are more concerned with tire wear than handling.
      01-09-2015, 04:59 PM   #18
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Interesting. I will need to look around for a better solution. In the spirit of full disclosure: TurnInConcepts http://turninconcepts.com (the shop that installed my BMW Performance Suspension) did the alignment at 5K miles, and they did bias the settings towards handling rather than tire wear. However, when checked by the dealer at 8.5K, they found it was still well within factory specs, so it's not as if they got carried away.
      01-09-2015, 05:28 PM   #19
3002 tii
3002 tii's Avatar
2282
Factory "specs" gives a really wide range of what's considered acceptable. For better tire wear, I would go hair toe-in for the back, with -1.0 to -1.5 camber. Front, I would go -0.5 to -1.0 camber and 0 toe. You can up the negative camber up front even though it might lead to premature wear since they'll still outlast the rears and you plan to replace all 4 at once. If you're ok with swapping only 2 at a time and want most tire longevity stick with the lower camber settings.
Bimmer TV125.00
      05-11-2017, 11:46 AM   #20
csween86
DSC OFF
csween86's Avatar
Drives: 2011 135i, N55, 6MT, MPK
After owning my 135i for over 7 years, I finally ditched the run flats... Best decision I ever made! The Michelin pilot super sports beat the OEM Dunlops I had in every aspect! The Michelin pilot super sports are definitely quieter, but not as much as I expected from other people's posts. Where they really shine to me though is how soft and smooth the ride is, and how well the weight seems to transfer in and out of turns. I run over imperfections in the road now that I used to hear and feel, but can only hear now. The car no longer feels floaty when weight transfer happens. The tires are so sticky, but definitely pick up and throw around every little bit of gravel, lol. I recommend the switch for those who haven't yet! Also, I got AAA since I have no spare. Even after buying my membership, I still saved $200 compared to the Dunlops and the ride is so much better. You can take more advantage of the power your car has with these, and the tires will last longer!
      05-11-2017, 07:37 PM   #21
a4nut
Drives: 13 135is
I had the AS3s on my MINI and instantly wished I had gone with the SS. Too much flex and general lack of instant responsiveness compared with true summer tires. Probably go with PSS next spring g when it's time for tires.
Dackelone10538.50
      09-29-2017, 10:41 AM   #22
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
I was able to squeeze 30K miles out of the front Bridgestone RFTs and 28K out of the rears.
