      04-21-2015, 05:18 PM   #1
$iriu$black
Drives: 2012 BMW 128
Exclamation Upsizing from 205/50 to 225/45 for a 128i (FRONT WHEELS)
Just as the title says, I wanted to know if this is doable. The Fronts are 205/50 on the 17x7 wheel and rears are 225/45 on 17x7.5 207M wheels. I have four of the 225/45 and would want to make it a square setup for the summer.
I think it would be alright, though the tire shop I have an appt this weekend says otherwise. I just wanted to know what opinion the community has about this. If not, I guess I'm stuck with the RFTs for now.
Tires I will be using are Advan S Drives 225/45/17.
I hope you guys can help out. Thanks in advance.
      04-21-2015, 09:56 PM   #2
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
I have 225/45 17 on my 17x8 et40 square winters
So for you it should be a more square shoulder. Check to see if it is safe to have a 225 on a 7 wide front.
I would Google and pay attention to Miata or Subaru forums. They have a lot of tire talk
      04-22-2015, 08:18 AM   #3
John_01
John_01's Avatar
Drives: E90 325i, E82 135i
I don't see a problem with 225/45 on a 7" rim. The tire manufacture lists this is ok, so I think it's strange the shop refused.
There will be extra sidewall flex due to the slightly narrower rim, but that wouldn't stop me.
      04-22-2015, 08:30 AM   #4
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
The shop is mistaken. 225/45R17 is no problem on the front of the 1 series.
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      04-22-2015, 08:41 AM   #5
MightyMouseTech
MightyMouseTech's Avatar
4338
Just check the tires on Tirerack. Will tell you exactly if it is doable or not. Takes 10 seconds.
Edit: Directly from Tirerack's website:
225/45R17
91W SL 300 AA A
7-8.5"
http://www.tirerack.com/tires/tires....=yes&tab=Specs
So yes, they can safely be installed on a 7" rim. The tire shop has no idea what they are talking about.
Also, the S-Drives are not an ADVAN.
      04-22-2015, 10:42 AM   #6
Black Prinz
Drives: 545i-128i-X3x35i-M2C
I run that size tire on mine; formerly on the original 256 wheels (17*7), with no problems; now on 17*7.5
The Black Prinz | 09E82N51 | BMW 3-Stage Intake Manifold | BILSTEIN B12 Pro-System+ | ///M Control Arms | ///M Bushing kit | ///M Strut Brace | DINAN Camber Plates & Rear Shock Mounts | ECS Performance Trailing Arms | aFe Magnum Force Intake System [Dynamic Air Scoops+Stage 2 CAI] | BMW Performance Exhaust | BMW Performance Brakes | GOODRIDGE G-Stop SS | DEPO V2 | Style 220M reps |
      04-22-2015, 10:46 AM   #7
$iriu$black
Thanks to all the responses so far! I did that Tirerack check and the manufacturer did list that size to take 7in wheels minimum so I guess they just wanted to "watch their backs" and not be liable for any damage since they're going out of the OEM specs.
My next Q is this, will this not cause any rub in the liners at the bottom or even on the suspension as it's going to be wider than usual?
I breathed a sigh of relief that I can do this without putting myself at risk. Thanks again guys!
      04-22-2015, 10:58 AM   #8
Vigilante375
Drives: 2012 AW 6M 135i
Pretty sure you'll be fine with 225s not rubbing anything.
      04-23-2015, 02:46 AM   #9
John_01
John_01's Avatar
People have fitted 225/40/18 on front offsets ranging from ET40 to ET49. Your 17x7" ET47 front wheels will be fine.
      05-03-2015, 10:05 PM   #10
Olgeezer1
You're going to like your 225 square setup on the 128. I have this setup on stock staggered 263 18" wheels and like it much better than the stock 215/245 setup. I think squared 225's is the ideal tire choice for the 128.
      05-03-2015, 10:55 PM   #11
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
I have square, 7" OEM rims and I run 225/45/17 front and back. As shown above "Rim Width Range" is the tirerack spec you're looking for. The S.Drives will fit.
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19
      05-05-2015, 02:12 PM   #12
$iriu$black
Thanks to all the advice. I did push through with this and now run 225/45 square on staggered wheels (207M) for my 128. It feels a bit more planted and has good turn in on corners.
I was wondering though if next summer I can run 245/45 (Yokohama S-Drive again) at the rears (7.5in wheel). Will that be too much? I checked and the narrowest wheel you can put it on is 7.5 so I think it's safe to say that it's still doable. Anybody here done that on their car?
      05-06-2015, 01:19 AM   #13
John_01
John_01's Avatar
245/45 is a larger diameter than the 225/45 stock size. It is 25.6" diameter vs 24.9" for the 225/45. Its still possible to fit on the rear rims. It will look quite chunky and slightly lift the rear of the car. The 245/45 on 7.5" is a bit too much and probably Not a performance upgrade in my opinion. Maybe you can consider 235/45/17 instead. Its doubtful whether 235 on the rear is an upgrade or not, but at least its in proportion with the staggered wheel sizes.
      05-06-2015, 07:41 AM   #14
Gary@TireRack
Moderator
245/45R17 is too tall. 245/40R17 would be a correct diameter match, but is recommended for use on wheels 8"-9.5" wide.
      05-06-2015, 07:46 AM   #15
$iriu$black
Originally Posted by Gary@TireRack View Post
+1
^agreed on both accounts. I'm guessing 235 profile would be more functional than 245. I definitely don't want to raise the car higher in the rear or mess up the efficiency by putting more weight at the drive wheels.
