      02-13-2016, 01:43 PM   #67
swagon
swagon's Avatar
Drives: F80 6MT
Nice; enjoy the new sounds! I still find myself watching 125/128i's w/ PE on YouTube even after two years with a 135i.
      02-18-2016, 02:40 AM   #68
squidge
Drives: 1997 Porsche 911
I've been on paternity leave for the past two months; going back to work in 13 days. Figured I should knock things out on the car now as I won't have spare time like this again, so I ordered a final round of goodies.
OZ Leggera HLT 17x7.5 +45 and Michelin PSS in 225/45/17 square (~40lbs each!)
M3 front control arm kit
Whiteline rear subframe inserts (given the stock bushings are so new, opted to skip the full M3 upgrade for a year or two)
Burger CDV
Me being me, I agonized over wheel and tire width, vascillating between 225 and 235. Here's what decided it for me:
The tread widths are the damn same, and the 225 has the optimal diameter. Even the section widths would've been very similar with the same measuring rim width -- the 225 would've gone up to around 9.3" section width given a 0.5" wider rim (per http://www.tirerack.com/tires/tirete...jsp?techid=200). Given that, I went for the 17x7.5" +45 wheel instead of the 17x8. I guess it might keep me from going 245 some day, but I don't think I care.
And I wanted the BBS RF but the Leggera HLT seems like an excellent alternative for me at ~40% of the cost, near identical looks, let me have 17s, and uses HLT tech which puts it squarely between cast and forged in quality.
In other news, I put about 50 miles on the car over the weekend. Loving the PE so far, and I can't wait to get this other stuff installed and then just enjoy it all.
      02-18-2016, 05:53 AM   #69
Ric in RVA
Bergspyder
Ric in RVA's Avatar
My used PE comes tomorrow!!!!! Installing this weekend.
Ric in RVA
      02-18-2016, 10:49 AM   #70
squidge
Nice! Enjoy it.
      02-21-2016, 01:24 PM   #71
squidge
Wheels are on! I'm really happy with the fit and appearance. I've only driven it a couple miles, but roll-on acceleration feels improved, and the chirp from 1st to 2nd is gone, so there's clearly more straight-line traction despite dropping from 245 to 225. Hoping to get to some twisty roads later today for some gentle break-in driving.
The OEM center caps are about 2mm too large for these wheels, so I've ordered OEM roundel decals to overlay on the OZ center caps.
      02-21-2016, 01:32 PM   #72
Ric in RVA
Bergspyder
Ric in RVA's Avatar
I have a metal lathe.... and a milling machine.
Anything you need "adjusted" be happy to help.
Ric in RVA
      02-21-2016, 01:58 PM   #73
squidge
Well the caps are all plastic, so it'd have to be on the wheel side (or maybe a custom made cap). Probably not worth the effort, but thanks for the offer!
      02-21-2016, 02:57 PM   #74
3002 tii
3002 tii's Avatar
2288
Drives: Z4 M, X5, GX460
2 months paternity? Do you work for Facebook or Netflix??! lol
Follow for latest mods
      02-21-2016, 03:04 PM   #75
squidge
Silicon Valley benefits are no joke... makes up for the cost of living!
      02-24-2016, 04:02 PM   #76
squidge
Bam! These 58mm convex decals were perfect. Around $40 shipped on eBay.
http://www.ebay.com/itm/351477383699...%3AMEBIDX%3AIT
      02-24-2016, 04:41 PM   #77
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Nice find!
Inertia is the enemy!
      02-24-2016, 04:58 PM   #78
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
Well done! I don't really like the look of non-OEM center caps, unless you've got something really bling like HREs.
Any pics of the decals on the car?
____________________________
      02-24-2016, 05:26 PM   #79
Ric in RVA
Bergspyder
Ric in RVA's Avatar
Sure those are BMW motorcycle tanks stickers....Great idea!
Ric in RVA
      02-24-2016, 05:31 PM   #80
squidge
The retaining clip on the center caps has to be installed from behind, so I'll add them this weekend when I do the control arm swap and rear subframe bushing inserts. Probably take some photos next week after I get an alignment.
I'm excited to see the finished product!
      02-24-2016, 05:39 PM   #81
squidge
Also, the 313M wheels in 18x7.5 with 215/40/18 and 18x8.5 and 245/35/18 weighed in at 46.6 and 50.0 pounds respectively. Subtracting out tire weights, that's 46.6 - 24 = 22ish and 50 - 27 = 23ish pounds. Rough estimates considering tread wear and TireRack's non-exact weights.
Not super svelte, but not quite boat anchors either. Good balance for OEM wheels.
      02-24-2016, 10:32 PM   #82
squidge
How concerned should I be about a five mile drive on my new tires to get to the alignment shop after the control arm swap?
      02-24-2016, 10:39 PM   #83
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Fronts, a little. IIRC fe1rx has a post stating the number of turns on the tie rods to get you back in the ballpark.
      02-24-2016, 11:07 PM   #84
squidge
Yeah, I read that over. Ten turns on each side to get it close, IIRC. I can't imagine that five miles of driving with it a few degrees out of whack is going to mess the tires up in a lasting way though, right? Not worried about it being tricky to drive.
      02-24-2016, 11:15 PM   #85
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
uh oh. The post I read said 3.5 turns out.
http://www.1addicts.com/forums/showp...89&postcount=4
      02-24-2016, 11:18 PM   #86
squidge
I just found that too. Thanks. After reading a bit more, I think I'll measure the toe before the swap using the string method and then try to replicate that measurement afterwards. Sounds like 3.5 full turns will be a good ballpark though, if plan A doesn't work out.
      02-25-2016, 01:29 PM   #87
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Never noticed that before, so the thread width is the same for a 235 tire ..damn what the point? I wanted to do 235 square in pss
      03-15-2016, 10:45 PM   #88
squidge
Finally got a follow up photo of the roundel emblems on the Leggeras. The weather's been crap in NorCal lately and I've been waiting for sunshine before cleaning the car. Really happy with the end result here.
