| 02-09-2016, 03:10 PM | #1 |
![]() 9
Rep 50
Drives: 2011 135i 6mt
Location: Rhode Island, Arizona or somewhere in between
Any way to run cornering lights full time?
Does anyone know if there is a way to run these lights along side the headlights? Would run them as "fog lights" though i've never seen anything on how to get this to work. No idea if it would be a wiring or coding project.
| 02-09-2016, 03:31 PM | #2 | |
![]() ![]() 4393
Rep 6,202
| 02-09-2016, 05:14 PM | #3 |
![]() ![]() ![]() ![]() 125
Rep 751
This is something I was wondering too, didn't see it in the icarly coding options
| 02-09-2016, 05:17 PM | #4 |
Rep 22,992
When you are in reverse they both come on. So I would think you could code the headlights that you were always in reverse. ?
| 02-09-2016, 11:52 PM | #5 |
![]() 9
Rep 50
| 02-11-2016, 11:34 PM | #7 |
![]() ![]() ![]() ![]() 322
Rep 910
Drives: 08 135i M Sport 6MT, 15 X3 35i
You should be able to. If I remember right all you have to do is tell the car what bulb to use for the daytime running lights. Ie AE, cornering, ambers, etc.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles ![]() |
| 08-05-2016, 08:34 AM | #9 |
1Addict
5381
Rep 9,254
Carly has the option to set what lights you want as your DRL. Can set lows, highs, corner or AE, or combinations of the above IIRC. Gotta set the values equal across all keys and options but it works.
2010 E82 1 Series M Clone
Hydra Performance augmented OEM+ |
TGel157.00 |
| 08-09-2019, 06:42 PM | #10 |
C2H5OH
4482
Rep 2,183
I bookmark things and come back when a solution appears ...
So I used ProTool to do some work. Under the FRM stuff there is a voltage option. Under there you can fiddle with stuff. Not sure what I did but now my cornering lights come on with my high beams (adaptive lights). So I'm going to say something in there can do this. |
| 03-30-2020, 10:35 PM | #11 | |
![]() 9
Rep 50
Hmm
Only six cross country trips so far in my 135...
| 07-09-2020, 01:29 PM | #14 |
![]() 55
Rep 222
| Bookmarks |
| Tags |
| cornering lights |
