      02-11-2017, 04:32 PM   #1
Lone Patrone
Drives: 2010 135i
How to open trunk after disconnecting battery leads
How do you open the trunk if I accidentally closed the trunk after I disconnected the battery terminals? I was removing the rear seats when I accidentally closed the trunk after disconnecting the battery terminals. I have access to the inside of the car, but I don't have access to the trunk. I tried jump starting the car, but could not get the car to start nor the trunk to open.
Any guidance anyone can give is appreciated. I'm trying to get this done this weekend.
Thanks,
Pete
      02-11-2017, 06:43 PM   #2
Lone Patrone
Drives: 2010 135i
I Got It Open. Thank You To Xjan For The Advice About Removing The Passenger Side Rear Speaker And Then Feeling Around For The Cable That Connects To The Latch In The Trunk. Once You Find The Cable You Will Need A Pair Of Long Pliers To Grab The Cable And Pull It With Enough Force To Pop The Rear Seat Latch And Then You're In. I Tried Everything Before This. I Spent Three Hours Looking For A Solution Before Coming Across Xjan's Solution.
Thank You Xjan.
Never Disconnect The Positive Lead On The Battery If There Is A Chance You Will Close The Trunk. Only Disconnect The Negative Lead.
Bmw Please Be Advised That Your Cost Cutting Lead To This Issue. Put A Manual Key Hole Trunk Release Back On The Trunk. This Is Border Line Dangerous And Just Silly.
      02-12-2017, 06:25 AM   #3
ShocknAwe
1Addict
ShocknAwe's Avatar
5381
In the future it's just easier to open the driver door, pop the hood, and connect a power source to the underhood leads. Then just use the trunk button from the driver seat. Do not try to start the car.
2010 E82 1 Series M Clone
MParallel1045.50
      02-16-2017, 05:04 PM   #4
Jorgensen54
Jorgensen54's Avatar
Drives: 2008 AW/AG 135i 6MT
2010 doesn't have a keyhole?
      02-17-2017, 05:15 AM   #5
ShocknAwe
1Addict
ShocknAwe's Avatar
5381
No, 2010s don't have trunk keyholes. However, they do have driver door keyholes so the method I mentioned works flawlessly as long as you can connect your front leads to a power source.
      02-17-2017, 12:02 PM   #6
Jorgensen54
Ridiculous. I apologize on behalf of BMW
eeghie330.00
      03-26-2017, 02:15 PM   #7
UR25IO
UR25IO's Avatar
Drives: 2011 BMW 135i M-SPORT DCT
Use a jump starter- turn the jump starter on connect the positive on then the negative. All located in the enginebay. Pop the boot then remove thee jusmp starter
      03-29-2017, 10:39 AM   #8
fatarayyy
fatarayyy's Avatar
36
Drives: Smg 135i '10
In my case, there's a child seat fastener located between two back seats, you remove the foam and then remove the hard plastic box that held by button and then you can move your hand around and unlatch the back seats if you'd like or release the emergency handle it's green color and It's a cable so not electronic
      05-10-2017, 10:38 AM   #9
titsataki
Drives: 2015 X3,2013 135is convertible
I think I went through this a couple times but I have it down now.
First item is put a towel covering the trunk lock so it does not lock.
But if you get locked out (I did).
No Key access for the trunk.
Connect the engine bay positive and negative to another 12 volt source and that would allow you to open the trunk.
Pics attached.
Nick
PS:
You can trickle charge from the posts in the engine bay. (I do)
I would not jump the car from the posts in the engine bay. (never had to)
      05-11-2017, 06:48 PM   #10
ShocknAwe
1Addict
ShocknAwe's Avatar
5381
I always put my seats down when working on a job with the battery disconnected. That way if the trunk gets closed, I can just climb in and reconnect it. Have had several helpful people close the trunk on me thinking they were being nice over the years.
      05-12-2017, 07:16 AM   #11
jaye944
Drives: a
2x4
never fails
      05-29-2017, 06:27 AM   #12
juld0zer
Roll the lock latch using a pen or small key or small screwdriver. Also works for programming, coding, flashing - roll the lock on the driver door before turning on the ignition.
Just dont forget to 'open' the door/boot before you slam the lock against the striker!
      06-22-2017, 11:55 AM   #13
amg6975
amg6975's Avatar
865
Drives: '12 M1.5
This. Takes 2 seconds to pop the seats and make a definite way to get the truck reopened.
      07-04-2017, 01:26 AM   #14
6MT_Addict
6MT_Addict's Avatar
322
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
+1
Even if you just give the release lever a tug to unlatch the seat before hand. 10 seconds and it saved a lot of hassle
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      07-21-2017, 11:58 AM   #15
dh58
haha this happened to me. titsataki has given you the solution. Just power up via the terminals in the engine bay
      09-11-2017, 01:19 PM   #16
One28Goat
Drives: 2011 128i
With the battery fully disconnected this doesn't work. It didn't for me :/. Other people have reported the same issue. My solution was perhaps... unique. http://www.1addicts.com/forums/showt...3#post22006473
      11-17-2020, 05:07 AM   #17
edd133
Drives: BMW 125i 2009 Coupe (05/2009)
My car lost power last night....just dead? Couldn't access boot to get my work stuff out..no keyhole on my 125i e82 coupe, its electric access only...wtf!!
Spent most of today trying to get in while waiting for battery to charge...(20hrs later)..Couldn't Jumpstart it no matter how much I tried..full battery did nothing???
Rear seats don't have release button in the cabin? Not even on the seats somewhere..
So I.....
1/ removed driver side rear shelf speaker, tore through the foam layer found the rear seat release cable and maneuvered it to release the seat...reached in to the boot and opened the other half of the rear seats (60/40 split seats).....
2/ I then climbed into the boot and because there is no trunk release cable visible in this particular bmw????....I removed the trunk lid liner..... found the trunk release cable and opened the boot.....(it was under the trunk lid cover passenger side...taped to the trunk lid???
Problem was a loose terminal on the battery module....thats why battery would charge but the car could not receive power even though its actually connected....
