      05-22-2017, 10:14 PM   #1
Katkarot
Drives: 2010MDX 2012135i
135i front brake caliper bolts - 10mm HEX or Torx T55?
Help guys,
On many DIY for 135i and E90 front brake pad change, they said to use 10MM HEX/Allen key to remove the caliper bolt.
When I tried 10mm HEX key, it doesn't go in. But I got a T55 and it fits and I also noticed the star indents too.
Any body got technical specs on the front Caliper bots? Is it 10mm HEX or Torx T55? I don't want to strip it by using the wrong size tool.
Thanks in advance
http://www.1addicts.com/forums/showthread.php?t=263962
      05-23-2017, 08:01 AM   #2
MDORPHN
Drives: AW 1M
1Ms have different calipers than 135s so you're unlikely to get an answer here.
1Ms have the same brakes as E9x M3s.
Neil
