      06-18-2017, 08:30 PM   #1
JimD
JimD's Avatar
410
Drives: 128i convertible
Oil capacity of N52
I have a 2009 128i convertible with the normally aspirated n52 motor. Even though it is not my daily driver it is out of warranty by both years and miles, at about 55K miles. I change every 5K miles because it is plenty often enough, it takes me about 9 months to put on 5K miles, and it is easy to remember. My last oil change, I learned something interesting.
I only had one 5qt of Castrol 0-40 European and had always found the level almost over full after adding around 6 qts. So I tried dumping in the 5 qt and checking the level. It was right at the mid-point. I try to keep a quart in the trunk but I plan to keep using a 5 qt for oil changes with the option to put a bit more from the quart in the trunk if I need to.
Using only a 5 qt cuts the cost for the oil change to a little over $30 ($10 for a Mahle 816 filter and a little over $20 at Walmart for the oil).
      06-19-2017, 02:02 PM   #2
davidk
Drives: 2018 X3 M40i, 2018 M2
The oil capacity of the N52 engine is 7 quarts, which is what mine gets each oil change, along with a new filter. Keep in mind if you purchase oil from BMW, they now sell it in liters, not quarts.
Dackelone11331.00
      06-22-2017, 11:53 AM   #3
amg6975
amg6975's Avatar
865
Drives: '12 M1.5
6.5 - 6.6 liters or 7 quarts.
Dackelone11331.00
      06-25-2017, 06:19 AM   #4
juld0zer
6.5L is the official spec for S/N5x RWD petrol engines.
Dackelone11331.00
      06-25-2017, 06:44 AM   #5
MightyMouseTech
MightyMouseTech's Avatar
4393
Why would you think it was "over fill" when only adding 6 quarts?
Dackelone11331.00
      06-25-2017, 07:31 AM   #6
6.9 quarts or 6.5 liters for the N5x six cylinder engines.
The oil dipstick isn't that accurate as you think. I bet after an hour or two's of driving your oil level gauge will read low with just five quarts of oil in the sump.
Buy seven quarts and just dump them in. End of story. IF you really can't afford two extra quarts... you have bigger problems coming.
Dackel
      06-25-2017, 08:29 AM   #7
JimD
JimD's Avatar
410
I am fully aware of the literature saying it will hold almost 7 quarts but according to my oil gauge it will not hold that much. I have driven it multiple times now with only the 5 quart added and it has gone down a little from the mid point but is still well within the green zone.
I was doing oil changes from multiple 5 quart containers previously. That makes it a bit hard to judge how much of the second container you used but I was adding about 6 quarts and the oil gauge read at the top of the green zone - nearly over full.
I am not going to overfill my motor with oil because you guys think it is a good idea. I will trust my gauge at least when it tells me something defendable. While a completely dry engine might take 6.9 quarts you can't ever get all the oil out during an oil change. Somewhere around 6 quarts is more realistic, I think, and a 5 quart got me on the oil gauge, safely in the green zone.
      06-25-2017, 08:54 PM   #8
brytom
Level 1 BMW Tech
brytom's Avatar
Drives: 2010 | N52K | 6MT
I am a dealer tech. N52, N54, N55 in the E82/E88 all take 6.5 liters or 6.9 quarts. Maybe it didn't drain it all or the sensor isn't reading right.
Options: Sunroof delete, Sport Package, Xenon
Mods: M Performance Suspension, BMW Style 197 Wheels/ PSS Tires, M Sport Steering Wheel
Dackelone11331.00
jemfff12.00
      06-26-2017, 11:16 AM   #9
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
2270
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
The oil sensor takes like 3 full drives to reset to the new level anyway.
I usually buy 2 5qt jugs. 6.5qts go in for the first oil change, then I keep that last 3.5qts. 1-2 qt is usually for minute top-offs during the 7-9k mi between both BMWs, and then I'll still have that last 1.5qt for the next oil change, where I'll only have to buy 1 5qt jug.
Dackelone11331.00
      06-27-2017, 02:00 PM   #10
The only true way to check how much oil is in our cars is to drain it and measure it. Running around with only five quarts of oil might be "ok" on your oil e-dipstick... but it is low! All it will take is some good high G cornering and your poor engine bearings will be the first to know you are low on oil. But hey... your e-dipstick says its ok so it must me. Not!
This is why I always change my own oil. I know how much I put in... and I am good. I've seen techs not change oil filters or put in all the engine oil... only to give themselves a "free" oil change. Not me. I always do all my own service. And like I said... IF you are so cheap not to understand how much oil BMW says to fill in the engine... or IF you are trying to save a few bucks... pay now or pay(more) later. There is a reason why the lights on the dash are called "idiot lights".
      06-28-2017, 06:11 AM   #11
juld0zer
Willing to bet it's the latter.
At least it's not a turbo motor with the separate oil cooler. I've gotten inconsistent drain quantities over several oil changes. I've even gotten more than 6.5L out once
      07-03-2017, 10:45 AM   #12
6MT_Addict
6MT_Addict's Avatar
322
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
^^ +1. I drain mine and add 6.00-6.25L and it generally sits at 3/4 full - full. Then I drive for a few trips and add a small volume of oil as needed. You'll never drain ALL the oil, but it should be pretty close. I don't recall offhand which side of the pan the drain is, but if you use ramps and it's not at the rear of the pan, you won't get all the oil from it.
It is VERY unlikely you'll have a liter or more of oil in left in the engine though, unless you have some sort of blockage at the drain or something.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      07-03-2017, 11:58 AM   #13
The oil cooler(on 135i's) and oil cooler lines also can hold a few liters of oil. Just one more reason to change your oil more frequently.
      07-04-2017, 01:21 AM   #14
6MT_Addict
6MT_Addict's Avatar
322
This would be in addition to the sump capacity though, right? Being as all N series engines have the same capacity.
Dackelone11331.00
      07-04-2017, 05:37 AM   #15
Yes. I only mentioned the added oil that sits inside the oil cooler and lines - in addition to the 6.9 quarts in the oil sump/pan.
      07-04-2017, 01:20 PM   #16
andysantoro
Drives: 09 135i M Sport
I assumed the stated capacity included the volume in the cooler and the lines. When I bought my car it had a Dinan oil cooler installed which I believe is larger than stock. I asked Dinan if I should add extra, and they told me not to worry about it. I use 7 Qts and it shows full on the sensor.
      07-05-2017, 04:04 AM   #17
When you drain the oil in the oil pan... the oil that's trapped inside the oil cooler and lines DO NOT empty out.
      07-05-2017, 11:32 AM   #18
andysantoro
Yeah you are right, which seems consistent with what Dinan told me, and the earlier mentioned info about the N52s having the same capacity despite the lack of an oil cooler
      07-06-2017, 01:24 PM   #19
Bimmer-Bob
Bimmer-Bob's Avatar
Drives: 2010 128i
OP, how much are you saving putting in 5 quarts instead of 7? IMO you'd be much better off putting in the full 7 and extending the OCI a bit (5K seems way too short).
____________________________
      10-30-2018, 08:04 AM   #20
JimD
JimD's Avatar
410
I've done several more oil changes and all have been consistent. I've tried raising the back end of the car too so it was level and it made no difference. On my car, adding 5 quarts gets me to the minimum end of the green range on the display. Since that is not where I want to be, I add six which takes me to the maximum end of the green range.
I am well aware of the dangers of too little oil. But too much causes issues too. I see no harm in adding 6 quarts and checking to see where you are but I would not add 7 without checking first. If your engine likes that amount, fine. Mine would be over full by a quart. That is enough to do damage. At least it would be overfull according to the gauge.
I am not trying to save money by adding less. I am just trying to add what the car says it needs. My 5 quart comment was a convenience thing. But I buy multiple 5 quarts and then have some for the next several oil changes. I also keep a quart in the trunk but I have never had to add oil between oil changes. But I am changing at 5K intervals - again for convenience.
      10-30-2018, 10:37 AM   #21
02Pilot
Malcontent
02Pilot's Avatar
188
Drives: 128i
Pretty standard practice to add a quart when using a street car (i.e., one without oil pan baffling) on the track. I doubt very much that one additional quart is going to cause any issues; you'd be hard-pressed to see the level in the pan high enough in use - especially high RPM use - to catch the crank and cause foaming.
Life's tough. It's tougher when you're stupid. -John Wayne
      10-31-2018, 07:17 AM   #22
JimD
JimD's Avatar
410
I hope 1 extra quart doesn't result in the crank finding the sump oil. I guess you've done it and not seen signs. I also guess you think your engine may starve for oil if you don't add the additional quart. I doubt that on a BMW.
The crank hitting the oil is one possible effect but even without that it can raise the pressure inside the crankcase resulting in oil getting past seals. That would be especially true at higher rpm when the pressure inside the crankcase is elevated anyway.
I think 6 quarts in a 180 cubic inch engine is quite a bit of oil. With a properly designed sump, which I assume I have, I think the engine should never run out. I've owned several cars with bigger displacement engines and less oil in them and they were fine.
