      04-23-2018, 10:31 AM   #1
hunterl41
hunterl41's Avatar
Drives: 2011 1M
2011 BMW 1M  [10.00]
new shoes PSS 255 285
After spending most of the winter looking through various tire fitment threads, I decided to go with a 255/35/19 front and 285/30/19 rears. Using the 1M safety car as fitment reference, I was initially going to go with Pirelli pzeros, but as luck would have it Michelin recently started carrying 285s as they are OEM sizing for one of the MB black series cars. So I went with pilot super sports instead. Still have a couple hundred miles to fully break them in, but my initial feelings have been extremely positive. There's less road noise, more planted feel in the rear, and no rubbing front or back. In the looks department it looks meatier and more aggressive without looking out of proportion, or too large for the wheels.
All suspension is stock. Previous owner had PS2 in the front and PSS in the rear with OEM sizes.
Here's a few quick shots from the morning commute.
      04-23-2018, 06:21 PM   #2
Juggernaut135i
Juggernaut135i's Avatar
Drives: BMW 135i Stage 2
2008 BMW 135i  [0.00]
Wish I could fit 285s on 135s
BMW 135i Active Autowerke Charge Pipe, BOV, Intercooler
AFE stage 2 intake
Macht Schnell Downpipes
BC Racing coilovers
M3 control arms
      04-24-2018, 07:38 AM   #3
griz31
griz31's Avatar
Drives: 2020 BMW 330xi
I went back and forth between 275/35 and 285/30 (as you’ve probably seen in my other thread). Glad the 285’s are working out! Keep us updated on how they are - I’m particularly interested in track performance if you get out there.
      04-24-2018, 09:32 AM   #4
E30 Racer
E30 Racer's Avatar
Drives: '11 1M, '09 335i M Sport
Would also be interested in hearing how pronounced the effect of the smaller rolling radius of the rear tires is (i.e., on effective gearing).
      04-24-2018, 07:38 PM   #5
dnizzle
Drives: 1m
do you mind posting more shots of the front wheel/tire? how is the gap now?
Thanks!
      04-25-2018, 11:07 AM   #6
hunterl41
hunterl41's Avatar
Drives: 2011 1M
2011 BMW 1M  [10.00]
Thanks!
I'll take a few more this weekend.
dnizzle23.50
      04-25-2018, 11:36 AM   #7
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Drives: VO 1M #739/740
Why 285s in 30/19 versus original size of 35/19?
      04-25-2018, 11:38 AM   #8
hunterl41
hunterl41's Avatar
Drives: 2011 1M
2011 BMW 1M  [10.00]
285/35 have been known to rub, especially with a passenger in the car. the lower profile gives a bit more clearance.
      04-26-2018, 10:30 AM   #9
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Originally Posted by E30 Racer View Post
+1
Not to hijack, but I am running a square setup 275/35-18 on the rear which is about 1/2 inch smaller diameter on the back. The added gearing is definitely noticeable, second gear is a hoot! My speedo reads about 7% low. My stock wheels have been used with 275/35-19 on the rear and that actually made the speedo perfect. The factory tires read a little low.
My factory wheels are going to get refinished, and I am planning to keep using 255/35 front and 275/35 rear.
      04-26-2018, 10:32 AM   #10
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I tried 275/35-19 in the rear last year and had to exchange them. They rubbed horribly. They would probably work with stock ride height and lots of negative camber. I am 5mm low and was running -1.7 camber.
