      05-01-2018, 07:44 AM   #1
NonoxX
France
24
Drives: 2010 135i DKG FBO
Rear end vibrations on 135i
Hi,
A few weeks ago, I started noticing strange noises on my 2010 E82 N55 DCT 135i. It may be worth noticing that it is now FBO.
I started getting relaively strong vibration from the rear end when accelerating, while driving over 80 km/h (50 mph). I get absolutely no noise while cruising at the same speeds. Only when accelerating.
I had a look under the car and couldn’t see anything. I checked the following items and they seemed OK:
  • Flector
  • Driveshaft Central Carrier
  • Output shafts (no sensible play)
  • Suspension arms silentblocs
  • Rear carrier silentblocs
I have no idea where to investigate further... Did anybody already have that kind of issue? Most cases I saw were flector failure. But here it seems not..
      05-07-2018, 03:18 AM   #2
NonoxX
France
24
I think I finally found the culprit...
      06-18-2018, 08:25 AM   #3
NonoxX
France
24
Hi, my 135 just received brand new tyres, and it did not fix the vibration / shaking issue on the 135i.
Has anybody further ideas?
      06-20-2018, 01:28 AM   #4
skimm343
Drives: 2009 135i
I had a very similar vibration on my 09 N54 after installed m3 subframe bushings. Vibration at high speed but only under acceleration. In my experience there's two possible hypothesis that could explain the vibrations.
1. When I installed the M3 bushings I F'd up and didn't pay attention to the clocking orientation of them. There's dots that are supposed to be pointed forward. I had the left side 90deg off from the right side. Fail. This "could" have created a stiffness difference between the left and right side of the car. Under load (acceleration) the rear subframe could possibly rotate very slightly relative to the body and mess with the angle between the drive shaft and diff causing the vibration.
2. When I bolted the subframe back to the body I didn't check to ensure the hole thru holes in the subframe bushings were concentric with the threaded holes on the body. This could also lead to a slight angle in the drive shaft where it meets the diff and create vibrations.
Once I realized I messed up the bushing clocking (item 1), I replaced the bushings with new ones and made sure the clocking was correct. Also I obsessed about getting the thru holes in the bushings to be concentric to the body treaded holes to ensure the subframe was square to the body. After doing this the vibration went away!
Not sure if you've worked on rear subframe recently, but that could likely have something to do with it. Also, if you decide to loosen & retighten anything up with the rear end I would highly recommend getting an alignment afterward.
      06-22-2018, 05:35 AM   #5
NonoxX
France
24
That's interesting. I did not work on the rear subframe recently. However, I do have Powerflex Black subframe bushing inserts since a while. Could they have gotten old, and therefore cause such vibrations?
      06-28-2018, 01:58 AM   #6
NonoxX
France
24
So... I've had a look at my subframe bushings yesterday: everything seems fine, mounted properly and torqued to specs.
Had a second look at the guibo and drivershaft carrier. Both look ok (no defect in the rubber), the driveshaft carrier did not show any noticeable play.
The differential has a significant oil leakage where the driveshaft comes in. This for sure has to be fixed. Could it be a reason for my vibrations or is it just a consequence or even a coincidence?
      12-09-2018, 04:04 AM   #7
Zombie_Head
Zombie_Head's Avatar
Drives: E30 325i 4-Door
I had no idea, what those blue dots on the bushings indicated, thank you for this, i thought it was just for production of the bushings quality control :/ looks like i need to do the RSFB again...damn it.
Regarding the hols in the bushings to be concentric to the body threaded holes, im not clear on what to look for/check for this, do you have a pic or can you describe this better?
I will just drop the whole rear frame this time around, need to replace the rear sway bar anyways, LSD will be installed next month.
      12-23-2018, 11:37 PM   #8
juld0zer
Your diff is rooted. A bearing/the bearings have failed, causing the differential to float around in the housing. It sounds like a flat tyre and howls above 50kmh.
Get the car onto a hoist or securely raise the rear on stands and chock the front, get the rears spinning up to the noisy speed and have a look at the pinion (input) and output flanges. The last one i dealt with had failed carrier bearings and it also had oil leaking from one of the output seals. The output flange oscillated.
      01-04-2019, 09:33 AM   #9
NonoxX
France
24
Hi, I tested extra things.
I had the opportunity to swap my diff with a similar one: result is negative. The symptoms are exactly the sames with both diffs.
Also, I removed my powerflex inserts and once again, it didn't change anything... Except that my rear axle is now floaty.
The flector and driveshaft center bearing have been changed. Could that be a symptom of a misbalanced driveshaft?
I've now driven more than 10000km with that problem and it didn't evolve much, though it remains worrying.
      01-05-2019, 06:57 AM   #10
drwillb
BMW Fan
drwillb's Avatar
Drives: e30 M3, e30 M3, e46 M3
You might be overlooking an obvious sign. The picture above shows excessive wear on the tire edge. Is that from tracking the car or is your alignment way off? How about a wheel bearing?
      01-05-2019, 09:41 AM   #11
NonoxX
France
24
My alignment has quite a lot of negative camber on the rear (2° which is still OK according to BMWs specs).
I don’t track this car but drive it hard regularly.
Do you think a wheel bearing could lead to that? When the car is on jack stands there is no play that I can feel.
Edit: are there some tests I could do to confirm that? I don’t get the characteristic noise of a dead bearing while changing directions.
      01-05-2019, 11:02 PM   #12
SayHack
SayHack's Avatar
Drives: 2008 BMW 128i
2008 BMW  [0.00]
As suggested you need to raise your car on jack stands (make sure its nice and secure). Then what you do is "drive in air"....or better yet have someone drive while you check under. Have this person give gas and press the break at the same time to mimic acceleration/load. My advice would be not to lay directly under the car but maybe take a look kneeling down on the side of the car (for safety reasons). My guess is there might be play in the driveshaft (maybe from u-joint ? ) . Good luck and please keep us posted.
      01-11-2019, 08:52 AM   #13
houtan
houtan's Avatar
812
Drives: 2011 135i
2011 135i  [9.85]
Any updates?
      01-11-2019, 09:03 AM   #14
ShocknAwe
1Addict
ShocknAwe's Avatar
5381
My car had done this a few times when wheels get bent. Tire can look fine. Took major balancing efforts and problem resolved.
Just another idea if you haven't specifically addressed that.
2010 E82 1 Series M Clone
      01-24-2019, 04:12 AM   #15
NonoxX
France
24
Hello everybody,
I dropped my car to a local shop, an indy BMW specialist. He told me that there is nothing to worry about. It is some fair amount of vibration due to the extra power the FBO provides in conjunction with the age of the various silentblocs.
Nonetheles he advised me to replace the rear subframe and diff bushings, more as a preventive action.
I don't think my rims are bent, as I already tried multiple sets of rims.
      02-14-2019, 05:58 AM   #16
Subaero
France
Drives: 2009 135i MT (N54)
Hi NonoxX,
I think I've got a similar issue on my 135i.
but it's not constant! some days, the car suffered a strong vibration (above 110-120kmh), and proportional to the speed, and some days, almost nothing ...
I am interested in your trouble shooting
      03-13-2019, 09:48 PM   #17
galifardo1971
Peru
Drives: 2009 BMW x6 5.0
Originally Posted by Subaero View Post
Hi NonoxX,
I have the same problem, my rear tire went down and then i had to fix it, then started to vibrate a lot, tough that was balancing, but then balanced 4 tires, same thing, still vibrations in the rear, thinking bent wheels or tires.. advice please, thanks
2012 135i n55
Active Autowerke FMIC and DP, Injen Intake
      03-28-2019, 05:47 PM   #18
IF not a bent or out of round tire... make sure the heavy spot of the tires(blue and white dots on the tire sidewall and valve stem) aren't aligned. They should be 180' apart from each other. IF not have a tire shop break the tire's bead and rotate the tire from the wheel. Reballance and recheck.
But I think another area is to check the center driveshaft bearing for wear. And also your axle drive shaft CV joints. You could have some pitting inside on of your CV joints.
An old trick on older cars was to swap the drive shafts from left to right so the CV joint axle's rotate in the other direction. This is only a temporary cue as over time the pitted CV ball bearings will wear groves inside the CV's. But it's something that you can do.
I would also check your differential out. Use a long screw driver up to you ear and listen for any bearing noises at speed.
G.L.
Dack
      03-28-2019, 06:18 PM   #19
SayHack
SayHack's Avatar
2008 BMW  [0.00]
Originally Posted by NonoxX View Post
Hello everybody,
You might want to take it to another shop , just saying lol. It is NOT normal , people push 500+ hp with no vibrations....your mechanic probably doesn't know what is wrong so he concluded that it is "normal"
