      05-30-2018, 10:13 AM   #1
Throne54
Throne54's Avatar
Drives: 2009 E82 135i M-Sport N54
Android Based Head Unit
Looking at adding in a nice android based head unit with touch screen and all that fancy stuff so I can run my MHD and JB4 right from the car.
What kits are you guys using sorry if this was posted before.
**Note: I tried one kit before which didn't fit the 1 series so back to square one.**
Thank you in advance,
2009 135i N54 M-Sport | VRSF 7" FMIC | VRSF Chargepipe | HKS BOV | BMS DCI | JB4 w/ two-step/anti-lag | MHD | BMS Oil Cooler Upgrades | VRSF Downpipes |
IG: Throne54
      05-30-2018, 07:01 PM   #2
low135
Drives: E88 135i
Look up the Xtrons units for the e82. I've seen a number of people recommend them. I think that's what I'm going to do
      06-08-2018, 08:40 AM   #3
Throne54
Throne54's Avatar
I did look into them and ordered one they had listed for the e82 and talked to their support team got the unit and it didn't fit.
I just found one that does fit made by www.carnaviplayer.com i sent pictures and they confirmed a fit.
IG: Throne54
      06-08-2018, 12:17 PM   #4
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
So you bought this and it didn't fit?
http://xtrons.com/pa7781bp-7-hd-digi...t-for-bmw.html
Then you did something wrong.
I have it and have for about 6 months now. It fits as it's designed, the same way all the china radios do, over the dash ... vs inside like the factory unit does. It's not an ideal fit but it does the job.
That other one you're looking at is also a china radio, few generations older though. Just with updated software.
      06-08-2018, 12:36 PM   #5
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
433
Drives: 15 GSM 435i GC
I've read that these Xtron units don't work if you have the Professional Hi-Fi audio system. Something about the amps.
2008 AW 135i - Sold
BAN_M2C4185.00
      06-09-2018, 08:28 AM   #6
NDion80
NDion80's Avatar
Drives: AW 2012 135i M sport
I thought it was just if you had logic7 sound but I could be wrong. It would be nice if someone could confirm.
      06-09-2018, 08:46 AM   #7
BAN_M2C
BAN_M2C's Avatar
4185
Drives: 991.2 Porsche GT3, BMW E46 M3
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
Was looking at them but most people that have installed them have done it on NON Harmon Kardon equipped cars.
I would most likely do it if it supported the Harmon Kardon system.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      06-12-2018, 08:46 AM   #8
Stubbie Blue
Drives: 2012 135i Coupe
I have a 2012 135i coupe with factory amp but no nav. I'm putting in a Joying 8" single DIN Android 8.0:
https://www.ebay.com/itm/Joying-Newe...B/332500447559
With a Best Kits BKBMW3 dash kit and PAC RadioPRO RP4.2-BM21 smart harness.
I did a test fit and it fits fine. Doing the wiring today.
      06-16-2018, 10:00 PM   #9
Afernandez0131
Drives: 2011 128i
Looking at swapping my Professional head unit
Has anyone seen a single din converted into a double din?
      06-16-2018, 10:01 PM   #10
Afernandez0131
Drives: 2011 128i
Were you able to get the wiring done? If so, how difficult was it? I just bought my 128i today.
      06-17-2018, 09:21 AM   #11
Stubbie Blue
Yes it was easy and this was the first time I've ever done this. I'll probably do a full write up thread later. The unit is great with Android 8.0, full Google Maps, 'Ok Google' voice recognition, etc.
The reason I chose this single DIN over a double DIN was because I wanted the screen to be placed as high as possible without covering the air vents. Also, double DIN dash kits may require some cutting of the plastic behind the dash.
      06-19-2018, 02:54 PM   #12
HondaGoneRogue
433
Yeah, Logic 7 = "Professional" = HK System.
I don't think there is a level between Logic 7 and base audio systems. I could be wrong tho.
2008 AW 135i - Sold
      06-19-2018, 02:56 PM   #13
HondaGoneRogue
433
And you retained the function of the subs under your seats? Door/seatbelt chimes are still normal levels with the stereo up?
2008 AW 135i - Sold
      06-19-2018, 09:21 PM   #14
Stubbie Blue
Yes all the speakers work including the under-seat subs.
However, there was a problem with the chimes due to the PAC RadioPRO smart harness. It's meant to connect to the chime speaker in the kick panel above the pedals. When I did that, I did get the chimes at normal volume levels, but my Park Distance Control stopped working and there was also an intermittent beep every couple of minutes or so (might be indicating a system error). So I disconnected the speaker because it was getting annoying.
      06-21-2018, 11:32 AM   #15
HondaGoneRogue
433
Good to know. Thanks!
2008 AW 135i - Sold
      10-17-2018, 11:12 PM   #16
Eszbi
Drives: 135i Coupe 2011
A little tangent
Has anyone else found their system tempermental?
mine sometimes doesnt start when i start the car (black screen)
90% of the time the steering wheel controls don't work
1% of the time it all works.
i dont know how to fix it to be consistent.
can anyone can help with this?
      10-18-2018, 06:50 AM   #17
JimD
JimD's Avatar
368
Drives: 128i convertible
The attached file is a good summary of 1 series audio options through 2011. I think 2012 and 2013 have the same options as 2011. Note that the base system is different for 2008/2009 versus the later models.
But the top level system, for all years, has the signals converted to optical. That could make aftermarket systems significantly more complicated. That technology is common to other bimmers, however, so good input may be available on the 3 series forum (or others).
      11-19-2018, 12:38 PM   #18
X2 Monstah
X2 Monstah's Avatar
Drives: 2018 X2 XDrive 28i M Sport
I ordered the system from carnaviplayer. Shipped today.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather
Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!)
      06-07-2019, 11:40 PM   #19
Corky876
Drives: 2012 135i
How did this work out for you? I am looking at the Car Navi Player and Xtrons.
      12-08-2020, 11:41 AM   #20
Jwal
Drives: E46 325iT
Also interested in the Xtrons vs Car Navi Player vs Belsee
Searching for a manual 128i
