      06-18-2018, 09:00 AM   #1
Alfa75
Drives: 128i
Intake cam inconsistently out of timing
2008 128i, completely stock and well maintained. Started it up for the year and took it out for a drive to get gas. On the way back, the engine started stumbling uncontrollably after accelerating from a high load/low rpm (pre-downshift on autobox) and a giant cloud of smoke came out the tail pipe and CEL was on. I pulled over, shut off and restarted. It ran perfectly the whole drive home, until I put in in park and it started stumbling again. I connected my scanner and ran some diagnostics (see attached) and found that the intake cam was completely out of alignment.
I was planning on changing the valve cover gasket anyways so, while I was in there I confirmed that the intake cam was truly out of timing. I set everything to TDC, reset the cam positions, replaced the vanos solenoids with new, removed cleaned and reinstalled the vanos check-valves/filters on the side of the block, and threw in a new set of plugs while I was in there. I ran every self test that my scanner could including the DCT all of which passed. For good measure I've also replaced the intake cam sensor. It started up and ran perfectly. I then ran two consecutive oil flushes with fresh filters and finally I changed the oil with a quality synthetic and mann filter. I did all of this with intent of cleaning out any sediment from the cam phasers.
Now it runs perfectly 90% of the time but intermittently it exhibits the same symptoms under a load but the CEL clears itself after a restart and the codes don't store.
      06-26-2018, 08:50 AM   #2
Alfa75
Drives: 128i
Possibly resolved
Upon further research it seems as though the front cam bearing can wear out on these engines rather easily and cause issues. I don't necessarily care enough about this car to pull it apart and inspect but I've heard great things about Liqui Moly Cera Tec Friction Modifier. I am usually completely against additives but at this point it worth a try. I added it and drove it for a week straight including a drive through New England this weekend. It acted up twice on day one and hasn't since and I added it 7 days ago. Might be worth a shot for anyone else with this issue as a band-aid. Be fair warned, it looks like liquid rust!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      07-05-2018, 08:35 AM   #3
Alfa75
Drives: 128i
Not resolved
The issue is back, unsurprisingly. If I keep the rpm below 3,300 its not an issue, or rev fast by it then it generally doesn't act up.
      07-05-2018, 12:54 PM   #4
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
I think this may apply to you (N52).
      07-06-2018, 08:38 AM   #5
Alfa75
Drives: 128i
Thanks iminhell1! That aligns perfectly with what I'm experiencing.
