      08-09-2018, 01:46 AM   #1
KRAMCLASSIC
Philippines
46
Drives: 2012 135I 6MT AW/RED
Manual trans fluid application question
Is it okay to use Pentosin 75W80 MTF2 Synthetic Manual Transmission Fluid for our transmissions? I originally bought 2 liters for my e46 m3 I used to own but I sold the car and still have this. Any thoughts?
12 135i: DINAN S3, ARM 7" FMIC, MADDAD MIDPIPES, REMUS EXHAUST, INJEN INTAKE, ARM CP
      08-10-2018, 07:51 AM   #2
JimD
JimD's Avatar
368
Drives: 128i convertible
My transmission is different than yours but I think that is too thick. I would look on redline's website and see what they recommend for your transmission. If they recommend one of theirs that is equivalent in viscosity, then it should be OK.
      08-10-2018, 11:17 AM   #3
Thunderguts
Thunderguts's Avatar
785
Drives: 2009 128i Sport MT
Sure, why not? Look at it this way, what are you going to do with the oil otherwise?
Try it out and see if you like the way it shifts. It's not going to hurt the transmission. If you like the way it shifts, you're done. If not, try something else. You're not out any more money and it only takes about 30 minutes to change the oil.
Tonight I'm putting in the 4th oil my gearbox has seen in a month. Just keep at it until you're satisfied.
      08-10-2018, 01:55 PM   #4
KRAMCLASSIC
Philippines
46
yup good point and the viscosity looks to be the same both at 75W80, so looks like I'll give her a try. thanks for the feedback.
      08-10-2018, 02:38 PM   #5
Our cars came with Pentosin 75W80 MTF3 no MTF2. Now BMW uses MTF5 & 6 I believe. The MTF3 has been superseded to MTF5, the last time I checked at my dealer.
MTF3 for a N54 135i...
https://www.realoem.com/bmw/enUS/sho...diagId=23_0926
MTF5 for the current F80 M3/M4's...
https://www.realoem.com/bmw/enUS/sho...diagId=23_1224
I use Redline's ATF-D4 in my manual trans 135i. You can also use their D6 or MTL fluids in our manual transmissions as well.
Originally Posted by Thunderguts View Post
Sure, why not?
Errr... well... you could screw up your transmission by using the wrong spec oil. There is a reason why BMW recommends certain fluids.
Oil does have a shelf life. After a few years of sitting on the shelf... the additives in the oil will start to separate out of suspension. I wouldn't use old oil in my lawn mower, much less my pride and joy. But that's just me.
Dackel
      08-10-2018, 04:09 PM   #6
Thunderguts
785
Dackel
Fair enough, if you know a legitimate reason not to use it, don't use it. Manufacturers recommend a lot of things, often using thinner oils to boost MPG. That doesn't mean it's bad, but there could be better aftermarket options. Of course there are many things you could put in your transmission that will damage it, but I don't think his Pentosin is one of them. I guess if it's been on his shelf for 12 years, it might be time to get some new oil.
Dackelone10588.50
      08-10-2018, 07:26 PM   #7
KRAMCLASSIC
Philippines
46
I sold my M3 about a year and a half ago so I'd say about 2 years old for the Pentosin oil I have. Any one know the actual shelf life?
      08-10-2018, 09:18 PM   #8
Thunderguts
785
I would bet half the gear oils on the shelf at the local auto parts store have been sitting there for more than a year.
      08-11-2018, 10:06 AM   #9
Arrow Bobistheoilguy.com
Thunderguts
I think you should ask the real crazies over at Bob the oil guy, oil forum. But I think the shelf life is about five years or so.
https://www.bobistheoilguy.com/forum...s.php?ubb=cfrm
...does synthetic oil go bad ?
https://myengineneeds.com/does-synth...l-ever-expire/
https://www.google.de/search?rlz=1C1...w=1093&bih=508
      08-16-2018, 07:57 PM   #10
JimD
JimD's Avatar
368
I used an old quart of BMW brand oil in my lawnmower then I couldn't find anything else in the house. Seems to work fine. I don't change the lawnmower oil, the engine is too cheap and the change process too much trouble. I just dump more in when it's low. But it doesn't seem to burn or leak the BMW oil like it did the cheaper stuff.
      08-17-2018, 01:35 PM   #11
KRAMCLASSIC
Philippines
46
LOL! I guess you would expect these oils to be of the best quality and even for other applications, it outperforms the cheap oils. I'm leaning towards giving it a try since I have it, I figure if its good for an M3 Trans it couldn't harm our 1 series trans.
