      09-24-2018, 07:38 PM   #1
AbsolutZero
Drives: E82-LCI 135i DCT
Wheel Alignment Recommendations (N55 - 135i) - Melbourne
Just replaced the run-flats with MPSSs (225 / 255) and need an alignment. Any recommended workshops in Melbourne?
I'm running stock suspension - has anyone experimented with set-up / any recommendations?
Looking at replacing rear sub-frame bushings soon as well, but I've read that you don't need an alignment after that.
      09-27-2018, 06:00 AM   #2
arrowskartax9
Drives: 2022 X5 30D M SPORT
What part of Melbourne are you in?
      09-27-2018, 04:34 PM   #3
JBT2
JBT2's Avatar
Drives: 2015 435i
I replaced the suspension at 164,000km with MCA Street Essentials which gave, amongst other things, front camber adjustment.
I won't be bothering with rear subframe bush replacement now as the new suspension has fixed all the vagueness ills.
Check the state of your bump stops - the car rides on them and they are probably stuffed due to our roads. My fronts were toast and most of the rears were missing/destroyed.
      09-27-2018, 05:57 PM   #4
AbsolutZero
Heidelberg, but happy to travel most places for a quality job.
      09-27-2018, 05:59 PM   #5
AbsolutZero
Coilovers are on the list as well. Cheers, I'll check them but I doubt they're too stuffed given it has only done 42,000km
      09-29-2018, 01:18 AM   #6
arrowskartax9
Give The guys at Tyrepower Nottinghill a call.
Martin does the wheel alignments and is very good. He does a lot of BMW's
9560-9433
Tell him Chris from Falken Tyres sent you.
