      09-29-2018, 07:43 PM   #1
MAMSport
MAMSport's Avatar
87
Drives: '13 128i M-Sport coupe
Koni Special Active
Are these really the best of both worlds? I'm looking for a DD combination on my 128i M Sport. Koni Sports seem like a waste of time. Have to remove the rears to adjust (or pay double for the externally adjustable version). Fronts would be difficult to adjust under the end caps for the OE aluminum strut tower bar.
With Bilstein B6 and B8 front left struts being largely unavailable, there aren't a lot of options without adding springs that drop the ride height. That really isn't an option for a DD in Massachusetts - can you say snow plow?
I know these Special Actives are very new, so I'm kind of waiting for some reviews. At the same time, I'd like to get the suspension sorted out and aligned prior to swapping to my winter set up.
      09-29-2018, 09:36 PM   #2
MightyMouseTech
MightyMouseTech's Avatar
4338
Did they just give a new name to the FSD?
      09-30-2018, 07:40 AM   #3
ShocknAwe
1Addict
ShocknAwe's Avatar
3233
Drives: E82 Mutt, M57 Truck
Why not just get koni yellows.
2010 135i 6MT Jet Black
      09-30-2018, 07:48 AM   #4
MightyMouseTech
4338
For the fronts, get the 1M strut brace. Allows adjustment of adjustable fronts easily.
      09-30-2018, 06:49 PM   #5
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
Yes.
      10-10-2018, 06:18 AM   #6
mermade
Drives: m5
The changes from FSD to Special active are as follows from what I could get out of Koni
New special damper with Gen 2 frequency selective damping (FSD) tech
Dampers available seperately where as FSDs were sold as a kit
Cheaper retail price
Colour change
      10-10-2018, 12:38 PM   #7
Cavpilot2k
Chief Warrant Officer
1025
Drives: like a damn lunatic
I have Koni Yellows and have no problem adjusting fronts (have tightened them up twice since installation) with stock bracing.
As for rears: I just did plenty of research on the most popular setting and set them before installation. Haven't found any reason to want to adjust them now.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK
Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff
      10-10-2018, 02:24 PM   #8
gjm120
Drives: 2013 128i, 2021 230i
Yea if you have a short adjusting knob it will slip under the strut brace.
Can I ask where did you set the rears?
My apologies if I've asked you before
      10-10-2018, 02:38 PM   #9
Cavpilot2k
1025
I got all 4 from a place called AutoAnything.
They come with the short adjustment knob.
      10-10-2018, 03:06 PM   #10
gjm120
Question was Set not Get the rears.
      10-10-2018, 03:11 PM   #11
Cavpilot2k
1025
Ah, I see.
The general consensus was either 2/3 of a turn or 3/4 of a turn, depending how stiff you wanted. My car is a DD on Boston-area crappy streets, not a track machine, so I think I went with 2/3 (I don't recall at the moment, but I'll look in my notes and try to find out what I did.
      10-10-2018, 03:29 PM   #12
gjm120
Ah, I see.
thanks. I'm going to be replacing my lower mounts sometime soon which will be an ideal time to re-adjust. Currently set at somewhere at just softer than the mid point between firm and soft.
      10-18-2018, 05:08 PM   #13
MAMSport
MAMSport's Avatar
87
This got thread jacked quickly. I have Special Actives ready for installation and will update once completed.
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      10-19-2018, 09:12 AM   #14
blue135
Drives: 2008 135i Convertible
Anxious to hear your reactions. Looking to put them on my E88.
      10-19-2018, 08:57 PM   #15
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Are you taking any anti rust precautions?
      10-21-2018, 12:35 PM   #16
fast1eddy
fast1eddy's Avatar
Drives: 2008 135i Lemans Blue
2008 135i  [0.00]
  [0.00]
Got them in yet ? Very anxious to hear the results.
      10-21-2018, 08:13 PM   #17
FLATBMW
FLATBMW's Avatar
34
Drives: E82
Lightbulb
FYI Koni forgot to include hardware for the rear and the OE BMW bottom rear strut nut doesn't fit Koni. I did some research and the rear bottom nut size is an awkward 10M-1.0 known as ultra fine! My local auto parts stores didn't have the 1.0 only 1.25 and 1.50 but my local Ace hardware had everything, told the dude with a huge beard I was looking for a 10M-1.0 for a strut and boom that was that, cost a couple bucks for several of them. I would pick up a few of these nuts before starting the install.
      10-23-2018, 11:56 AM   #18
TURBO8
Drives: 2011 135i
I installed Koni Special active shocks and struts on my E83 X3. All I can say is Meh
      10-24-2018, 02:38 PM   #19
fast1eddy
fast1eddy's Avatar
2008 135i  [0.00]
  [0.00]
That's disappointing to hear. I also have an X3 I thought might benefit from this technology
      10-24-2018, 09:49 PM   #20
MAMSport
MAMSport's Avatar
87
Going in tomorrow! Give me a couple days to evaluate before I report back!
      10-26-2018, 07:14 PM   #21
MAMSport
MAMSport's Avatar
87
So, the new Special Active struts and shocks have been installed, and the car received an alignment to 135 is specs. I don't know if there is a difference between those and 128i sport suspension settings?
My initial impression is that they are a bit stiffer than the OE sport suspension shocks and struts. Over simple stuff like tar strips, I can hear the tire impact but barely feel anything. This is a bit of an improvement over the factory pieces.
More complex bumps/irregularities are more firmly damped with only one oscillation per impact, not the feeling of 'bounciness'. The term 'buttoned down' would be a good explanation of how I think the suspension now feels. Very happy so far, might be a touch firm overall (and might soften slightly after break in?). One thing I can't explain is that the car feels flatter in corners. I wouldn't think the shocks would contribute to this, but maybe stiffer prevents some weight shift?
      10-27-2018, 03:53 PM   #22
andrey_gta
andrey_gta's Avatar
Which springs did you use? Stock 128i Msport/Sport? Are they the 2011+ springs?
