| 11-06-2018, 09:35 PM | #1 |
![]() 62
Rep 59
N54 Water Pump Removal - easier
Hello,
I don't know why, but it seems many people are removing a lot of things to remove the water pump. If you'd like to remove it without removing the stabilizer bar and or your steering box... Here's how I do it 1. Remove pre-catalyst Both (there is also a bracket to be removed that holds them together to the transmission) 2. Remove the radiator fan and the front turbo duct (from turbo to air filter box) 3. Not sure (don't remember if you have to) ... Intercooler and pipe from both turbos to intercooler removal 4. Unclip power steering hose from steering box 5. Drain engine coolant from water pump hose 6. remove pump and/or thermostat I have made lots of "How to" videos. I have created a Youtube channel where you can find them https://www.youtube.com/channel/UCrf...f2b4-fZVKDUi-w Here is the water pump video link Here is the thermostat video link Last edited by QuebecDIY; 12-11-2018 at 09:58 AM.. |
| Bookmarks |
| Tags |
| 135i, 335i, thermostat removal, water pump removal |
