      04-26-2019, 11:13 AM   #1
spitfire148
spitfire148's Avatar
29
Drives: bmw e82
2008 1 series  [0.00]
need help e82 chimes/gongs
do you know how to reset or change the sound the car makes when an alert appears I.E low fuel, no seat belt or fault tones.
after putting an aftermarket cd player in my car the nice bmw chime noise has changed to a really annoying high pitched beep does anyone know how to set this back to default or what could have happened. it now comes from the back of the head unit instead of out the speakers.
i have a 2008 e82 1 series 120d
Erisin ES3840B head unit
everything works on the new head unit, reverse cam,bluetooth, cd player, touchscreen all othr sound through speakers etc i just wish the alert tones were the normal bmw chime from the speakers.
any help or suggestions appreciated
      04-26-2019, 11:53 AM   #2
gjm120
Drives: 2013 E82 128i , 2021 F22 230i
I'm about sure there is a way to code the alert out completely so maybe a tone change is possible.
Try posting your query in the E90 forum coding section.
E82 - BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
F22 - Stock M Sport, 6MT
      04-26-2019, 12:13 PM   #3
spitfire148
29
Drives: bmw e82
Sorry are the E82 and E90 the same for coding ? my car is a 1 series E82
      04-26-2019, 01:17 PM   #4
gjm120
Yes. If you get an answer that says what you want can be coded, you probably could get someone to help you locally.
      04-28-2019, 11:08 AM   #5
spitfire148
29
Drives: bmw e82
So ive been looking for hours and cant find any mention of coding these out, to be honest I dont really want them turned off I want to figure out why they have stopped working and try get them back
      04-28-2019, 02:28 PM   #6
gjm120
I've coded out my idrive warning screen and tone. I know that isn't the exact same thing, but, point is there is a lot that can be done with coding. I'd really ask on the E90 coding subforum. I've gotten a good bit of help there - some of the frequent posters on there really know coding and programming.
      04-28-2019, 06:07 PM   #7
spitfire148
29
Drives: bmw e82
Thanks. i created a new post in the E90 forums
gjm1202279.00
      04-28-2019, 07:13 PM   #8
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
I think that option was under the factory menu.
      04-29-2019, 05:07 AM   #9
spitfire148
29
Drives: bmw e82
thanks but there is only 3 options within canbus for bmw on my version 2 for bmw mini and one for bmw union there is no other mention of chimes in the factory settings so not sure what else it could be. the version of software mine has (latest) the factory code is different also 3368
      04-29-2019, 12:30 PM   #10
iminhell1
C2H5OH
iminhell1's Avatar
It's under the voice tab.
      04-29-2019, 01:51 PM   #11
spitfire148
29
Drives: bmw e82
what one do you think it is ?? ive just tried setting sys to 0 but the alert tone is still there
      04-30-2019, 02:11 AM   #12
iminhell1
C2H5OH
iminhell1's Avatar
sys is what it should be.
Have to hit apply then exit. it will restart and apply the setting.
      04-30-2019, 09:11 AM   #13
spitfire148
29
Drives: bmw e82
No sadly not, set to zero, saved, rebooted keys out car back in and still get the alert tones from the back of the head unit when doors open etc
      04-30-2019, 12:41 PM   #14
iminhell1
C2H5OH
iminhell1's Avatar
Well then I'm not sure.
Yours is acting different than mine.
