      06-30-2021, 05:17 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
4461
Drives: M3
► APEX | New 17×9” track fitment for BMW 1 Series
NEW APEX 17×9” TRACK FITMENT FOR BMW 1 SERIES
The E82 1 Series is a fantastic platform that has become increasingly popular among performance driving enthusiasts due to its ideal size, driver engagement, and affordability. Like many BMWs, the 1 Series in stock form is plagued by understeer, which means the car does not respond to steering input as much as the driver would like due to a lack of front-end grip. As a result, the car washes out away from corner apex, veering off the intended and ideal driving/racing line. The good news is there are many ways to mitigate understeer, and one of the easiest and most effective methods adopted by racers is to increase front-end grip by installing wider front tires as part of a square wheel/tire configuration.
A square configuration uses the same wheel and tire specifications on all four corners of the vehicle, which translates to a more neutral handling experience and allows front-to-rear and left-to-right rotation for extended tire life. This is a huge benefit for enthusiasts that find themselves at the race track often, as the cost of consumables like tires, brake pads, etc., can add up quickly. More savings means more seat time!
Still, there’s a problem: the 1 Series is at a massive disadvantage over other BMW chassis that commonly use square configurations such as the E36 and E46 due to unusually tight clearances under fenders that lack much of a flare. For wider wheels and tires to fit correctly, uniquely high wheel offsets must be used. We all know there are plenty of wheel options for the aforementioned 3 Series chassis, but because 1 Series wheel specifications aren’t useful for any other BMW model, the industry has ignored this niche application. Now for the second time, APEX has decided to develop wheels optimized specifically for the 1 Series chassis – this time with an emphasis on a lightweight 17” rotatable square fitment. We’re excited to introduce our new ARC-8 17×9” ET52 wheel.
FOR 1 SERIES OWNERS, BY 1 SERIES OWNERS
This new fitment is designed to support 245/40-17 or 255/40-17 tires at all four corners. The 52mm offset is optimized for the rear of the car as a direct fit, and like the E36 and E46 generation 3 series, the front utilizes spacers to clear the suspension. The spacer size required ranges from 12mm to 18mm depending on the tire size/model and aftermarket suspension used. These topics are covered in more detail below.
ARC-8 17×9″ ET52 – 255/40-17 Nitto NT01 – 15mm spacers – TC Kline Coilovers
Motorsport-oriented coilovers with camber plates are a requirement for this wheel and tire setup to work properly as we are using all available real estate under the front fenders. We define motorsport-oriented coilovers as coilovers with a slim silhouette equipped with short linear springs (Ex. JRZ, MCS, TC Kline, Ground Control, etc.). Aftermarket coilovers or height adjustable sleeve kits known to reduce front wheel clearance like KW V1/V2/V3/CS, Bilstein PSSS9/10, Ohlins R&T, etc. cannot be used unless the spring configuration is modified.
Please note that M3 control arms alone will not generate enough camber for this wheel and tire fitment to work. Upgraded control arms extend track width and add negative camber by kicking the bottom of the wheel and tire outward; however, they do not pull the top of the tire inward away from the front fenders, which is required to prevent rubbing under suspension compression. These tires can fit properly with camber plates installed and aligned in the -3º to -4º range (similar to what E36 and E46 chassis use). This requirement should not be considered a barrier, as negative camber plays a vital role in extracting the most performance and longevity out of your tires. These specs are desirable for track cars regardless of whether or not your wheel fitment requires it.
The rear fitment is easy and does not require any modifications; however, we recommend between -1.8º and -2.5º of camber to compliment the front alignment specs.
Note that this wider fitment and offset create a larger scrub radius. Anytime you go wider than normal you’re much more likely to like rub against the plastic fender liners, especially at full lock and along the plastic grill for the intercooler. Also, it doesn’t like the little triangle of plastic, which ideally would be shaved down. This is accepted practice in the E36 and E46 communities. No one is fast on the track with zero inner liner rubbing.
WHY 17×9”?
About ten years ago, we released a bolt-on 18×8.5” front, 18×9.5 rear staggered fitment that remains popular within the 1 Series community today, and its been excellent for enthusiasts who prioritize rear-end grip and enjoy the look of 18” wheels. For more hardcore track enthusiasts, the downsides were the running cost of wide 18” tires, increased wheel weights (rotational mass), and the inability to rotate. For these reasons, we prefer a lightweight 17” square configuration that can support 245/40-17 and 255/40-17 tires, which are typically plenty wide for the power and weight of the 1 series.
When the 1 Series was much newer, few people were willing to add camber plates to their cars for track duty, so we were forced to compromise and offer narrower wheels than ideal (8.5” front). Now that the car is older and more affordable, more owners are willing to perform the necessary modifications to accommodate a more aggressive wheel and tire fitment. We see this type of progression with all vehicles we serve.
TL : DR FITMENT NOTES
• 12mm – 18mm front spacers required depending on tire size/model & suspension type
• Motorsport-oriented coilovers and camber plates required
• Recommended alignment settings: -3º to -4º front, -1.8 to -2.5º rear
• Recommended tire sizes: 245/40-17 or 255/40-17
BRAKE CLEARANCE
Whether you are looking to mate up a set of wheels to a current brake system or just planning for the future, understanding brake clearance is vital in making an informed wheel purchase. The ARC-8 17×9” ET52 will clear the massive 6-piston OEM Brembo BMW Performance caliper found standard on the 135i, as well as a variety of aftermarket BBK options.
17” TIRE AVAILABILITY
You can have the perfect wheel specifications for your car, but they are of no value to you at the end of the day if there aren’t desirable tires to pair them with. Luckily in a 17” diameter, there are lots of great options to choose from no matter your experience level. We took the liberty of listing notable tire options from relevant tire categories and highlighted some of our favorites. If we missed any notable options, just let us know, and we will edit the list.
Extreme Performance Summer Tire Suggestions:
245/40-17:
• Yokohama Advan A052 (200TW) – APEX staff favorite
• Hankook RS-4 (200TW) – APEX staff favorite
• Dunlop Direzza ZIII (200TW)
• Falken Azenis RT660 (200TW)
• Goodyear Supercar Eagle 3 (220TW)
• Toyo Proxes R1R (200TW)
• BFGoodrich G-Force Rival S 1.5 (200TW)
• Continental Extremecontact Force (200TW)
• Nexen N Fera SUR4G (200TW)
255/40-17:
• Nankang NS-2R (180TW)
R-Compound Tire Suggestions:
245/40-17:
• Goodyear Eagle F1 Supercar 3R (100TW)
• Toyo Proxes R888R (100TW)
• Nankang AR-1 (100TW)
• Pirelli P Zero Trodeo R (60TW)
255/40-17:
• Nitto NT01 (100TW) – APEX staff favorite
• Maxxis RC-1 (100TW)
• Toyo Proxes RA1 (100TW)
• Pirelli P Zero Trofeo R (60TW)
Semi-Slick Tire Suggestions:
245/40-17:
• Hoosier R7 (40TW) – APEX Staff favorite
• BF Goodrich R1S (40TW)
• Hoosier A7 (40TW)
• Toyo Proxes RR (40TW)
255/40-17:
houtan806.00
Fakemike373.00
Dieselboy502.50
99937.50
      07-01-2021, 09:34 PM   #2
houtan
houtan's Avatar
806
Drives: 2011 135i
2011 135i  [9.85]
Thanks for the informative post and continuing to release options for the e82. I love my arc 8s!
      07-02-2021, 01:21 PM   #3
wootloops
wootloops's Avatar
376
Drives: 2013 E92 M3 Lime Rock Park
Just pledged on the GB. Really appreciate you guys coming up with a track focused option for the e82.
      07-02-2021, 04:28 PM   #4
Expert@ApexWheels
4461
Drives: M3
Thanks for the kind words and support! The E82 is a fantastic chassis to be used on track and we're very excited to offer another purpose built fitment!
-Ian
      07-06-2021, 08:24 PM   #5
imported_mega
Drives: various bmw's
ohh in for a set what length swift springs should I convert to for front clearance? I'm using et42 17x9 now and they rub after pulling quite a bit, I might be able to pull them in more and fit 255s if I can get the spring perch up above the tire.
i'm running miester r zeta crd coilovers
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      07-06-2021, 09:52 PM   #6
Phloozy
Drives: BMW 128
have you test fit 245 R7s? curious how much rolling/pulling is required with these? I am rolled as much as i can in the rear and rolled flat in the front. Awesome either way! Just need a 17x9.5 and 17x10 now :P
      07-06-2021, 09:53 PM   #7
Mach3M3
Drives: 2011 E82 128i
In for the group buy
      07-07-2021, 02:29 PM   #8
Expert@ApexWheels
4461
Drives: M3
Thanks for your interest! We unfortunately don't have much experience with those coilovers. What size front spacer are you currently using? As you mentioned, if you can raise your ride height or move to a shorter spring to get the spring perch up above the tire, you should have a lot more room to play with.
We haven't tested the R7s yet in those sizes, however the 255/40-17 NT01 we have tested has a section width of 10.35" compared to the 10.3" section width of the 245/40-17 Hoosier R7. It shouldn't be too hard to fit.
Glad to hear it! Feel free to ask if you have any questions about the process.
-Ian
      07-07-2021, 06:40 PM   #9
Phloozy
Drives: BMW 128
-Ian
Awesome! Well I am in so I will let you know!
      07-08-2021, 11:20 AM   #10
spidertri
spidertri's Avatar
685
Drives: 11 128i | 21 X5 40i
2011 BMW 128i  [0.00]
Is this wheel size going to be kept in stock in the future or is this a limited run? Just thinking about spares or replacement wheels being needed possibly.
11 128i slicktop
19 Alltrack S
21 X5 40iX Msport
      07-08-2021, 02:47 PM   #11
Expert@ApexWheels
4461
Drives: M3
This wheel fitment will not be a limited run of wheels and we do intend to keep them in stock beyond the initial production for the Group Buy, but it is a niche fitment for a single chassis so the wheels will not be produced as often as our more versatile fitments. We will base production on demand so if the wheels are a consistent seller for us, they will be produced more regularly.
If you would like to order a spare wheel or two with the group buy order to lock in the discounted pricing, please send us a DM on GangUp. We can manually add additional wheels to the orders once the Group Buy has been finalized.
-Tom
spidertri684.50
      07-10-2021, 03:09 PM   #12
Dmak
Drives: 09 135
Whats the weight of the wheel?
      07-10-2021, 11:12 PM   #13
415
Drives: 2011 M3
17.2 lb
      07-12-2021, 12:54 PM   #14
Expert@ApexWheels
4461
Drives: M3
415 beat us to the punch but yes the weight per wheel will be right around 17.2 lbs.
-Tom
      07-16-2021, 09:25 AM   #15
Phloozy
Drives: BMW 128
-Tom
What is the lead time on these? I have never done an an apex group buy but I am already in this one. Are the wheels ready and will ship once its closed or is this waiting to end before they get started? Silly reason but I have more events this year and can either buy 225 hoosiers that fit my current setup or 245s that will fit this set when they come in.
      07-16-2021, 01:45 PM   #16
Expert@ApexWheels
4461
Drives: M3
Thanks for joining the Group Buy! The deal officially closes on 7/27 at 11:59pm Pacific. The wheels needed to fulfill the group buy orders have already been produced and will be shipping by mid August. After the deal ends, we will begin collecting full payment and processing all orders ASAP.
-Ian
spidertri684.50
      07-18-2021, 12:47 PM   #17
AndyW
AndyW's Avatar
Looks awesome. How can I confirm it will fit with my 355mm stoptech st-60 bbk?
      07-19-2021, 01:54 PM   #18
Expert@ApexWheels
4461
Drives: M3
We have a 355mm Stoptech ST-60 template on file. If you can confirm that the attached file is the same kit that you are running currently, I can request a clearance check with our engineering team and let you know if the kit clears. Please let me know!
-Tom
      07-19-2021, 08:44 PM   #19
AndyW
AndyW's Avatar
-Tom
Yes! Those are my fronts. My rears are Stoptech ST40 345x28's. Pretty sure those will fit regardless, but can you confirm those also? Document number for the fitment template for those is 98-165-24F1-00. Thx!
Best,
Andy
      07-19-2021, 10:58 PM   #20
bender128
bender128's Avatar
85
Drives: BMW 128i Coupe
2015 BMW M3  [0.00]
Would be very interested in an 18x8.5 group buy!
      07-20-2021, 12:13 PM   #21
spidertri
spidertri's Avatar
685
Nice, we made it to 15 pledged.
11 128i slicktop
19 Alltrack S
21 X5 40iX Msport
      07-20-2021, 12:16 PM   #22
Expert@ApexWheels
4461
Drives: M3
We have the template for the rears as well. I've requested a test against these wheels for both kits from our engineering team and will reach out when we have results to let you know! These tests can take us a few days so please bear with us.
No Group Buys are planned for our 18" ARC-8s at the moment. We are mainly using GBs for new product launches currently and with our current low inventory of 18x8.5 ET45s it doesn't make sense to discount them.
-Tom
