      04-27-2024, 11:40 AM   #1
imported_mega
Drives: various bmw's
Drive shaft prop shaft rear seal replacement
Is there any way to replace the drive shaft rear joint grease boot
I really don't want to buy a whole drive shaft just to replace a little seal that's leaking grease. If I have to I'd rather spend money on an axle for a M3 LSD
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      05-07-2024, 05:38 AM   #2
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
If you're talking that little flexi bit just ahead of the diff, no. It's not serviceable.
Not sure what they go for now but I bought a complete upgraded driveshaft for about $500 made with 1350 u-joints.
      05-07-2024, 07:04 AM   #3
imported_mega
kind of sad that a 3 $ seal destroys a 1300 $ axle, I have not found a source for that seal
RVTed the hell out of it while I wait on parts that may take a long time to get as they are custom.
I have a ford super 8.8 waiting on mount/bracket and custom axles, it will have a standard driveshaft with yolks. Not sure if I'll have the tail of mine welded up or an entirely new axle made
      12-13-2024, 03:02 AM   #4
derekitoymd
Drives: 2010 135i a/t
Mine too has this problem.
Have ypu flund a solution to this?
      12-13-2024, 06:12 AM   #5
imported_mega
Yes I fixed it I had to order a seal from the Ukraine and then Rvt to install it
BMW rear gimbal dust cover (11553453300, 1 155 345 330 007, 1155345330007)
UAH 860.00
Delivery cost: UAH 650.00
*Total amount to be paid:* UAH 1510.00 *(€34.5)*
Thank you for choosing us.
SHEM-Group
