| 05-10-2024, 11:36 AM | #1 |
Rep 243
*** Best Tune for N52, MY09 125i?
Hey 1Addicts crew,
REF: 125i Stock: Engine --> 160KW (214eHP) / 270Nm Wheel --> 136rwKW (181wHP) 130i Stock: Engine --> 195KW (261eHP) / 315Nm Wheel --> 165rwKW (221wHP) Not sure how active these forums are... but just wanted to pick every1's brains! 1) What's the best bang for buck Stage1 Tune for the N52 nowadays? Ideally with some Dyno results to show! ![]() I've searched some older posts on this forum and a couple of names came up:
2) My understanding is that Aussie E82 125i (are like the Euro spec ones and) all have the 3 Stage Manifold, does that mean we can get awesome gains (up to ~130i levels) with just a ECU Remap (N52 valvetronic)? 3) Can I just do an ECU Remap or do we need to also upgrade both exhaust headers and higher flowing cats? 4) Do you guys know any1 in Sydney who is able to help? Thanking you in advance. Appreciate all your input!
MY09 E82 125i M-sports --> | Black/Black | Rims: 18" 261s | 130i Tuned with BimmerLabs | Flowdesigns Splitter kit with front lip extensions | CF spoiler | CF M-Tech diffuser | Blacklines 63212225282 | Black Dual Slat Kidney | Xenons: D-Series 6000k LED | AE: NovSight 6000k LED |
| 05-10-2024, 05:09 PM | #2 |
Rep 371
Hi jkho,
I used Active Autowerks for mine but I hazily recall everyone started using something else not long after. Bimmer Works maybe? I have no idea if you can still get tunes from any of these places. I installed mine remotely with a laptop and there were no shops in WA at the time who could do it for me. Sydney may be a different story. The Australian 125i is intentionally restricted, presumably so it didn't get too close to the 135i, so all you need is a tune to unlock it to 130i spec. I did headers and front pipe with high flow cats at the same time, but that was only worth about 6hp before the tune. Good luck - I really enjoyed my 125i while I had it. |
jkho65.50 |
| 05-11-2024, 05:06 AM | #3 |
Rep 224
is it auto or manual?
I have a 125i and did a bimmerlabs tune. Was free from the site. Need a laptop that has inpa and connects to the car and the obd cable. Flashes the engine ecu to 130i spec.
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it...."
Ferris Bueller ![]() |
jkho65.50 |
| 05-12-2024, 05:24 AM | #4 | |
Rep 243
ooh nice; did you ever do a dyno run before and after the tune? If yea, what sorta numbers did you get with Bimmerlabs? Did u load the 125i or 130i one? Easy to do? Sorry heaps of questions, I'm not familiar on the process... new to all this!
| 05-12-2024, 07:11 AM | #5 |
Rep 224
so i also have an auto.
i loaded the 130i file. what i found was that there was a miss match between the gearbox and the engine, the revs would be out. so you have to tune the gearbox to 130i spec too. while you can tune the engine with a generic obd cable, you cannot use the same cable for the gearbox, you have to update the cable or use a bimmergeeks cable or icom cable. https://www.1addicts.com/forums/show....php?t=1754063 https://www.1addicts.com/forums/show....php?t=2037462 have a read through those thread regarding the gearbox update.
jkho65.50 |
| 05-12-2024, 07:54 AM | #6 | |
Rep 243
Hey Mban, Cheers for ur reply! What car u driving nowadays? Miss the 125i sometimes? Saw that you hit 220wHP/164wkw (with ARMA Speed headers and high flow cats <200 cell Magnaflow>) on the Dyno@Advan, which is pretty much the 130i Coupe we were all chasing! ![]() Sorry for all the newb questions, still learning... hoping to pick your brain --> So best bang for buck gain would be to do just do an ECU flash? If that's all I'm doing, I'm keen to find the best one to get Am I correct in saying that all these listed tunes would alter the valvetronic maps and make use of our 3 stage manifold? Saw that you were deciding between AA, EvolveR amongst others:
Appreciate the input mate!
| 05-14-2024, 01:54 PM | #7 | |
Rep 243
Did ya get a Dyno before and after the tune? I'll pm ya later to pick your brain if that's cool? Thx bro ![]()
| 05-15-2024, 07:20 AM | #9 |
Rep 243
169W, nice! Bang on 130i numbers
![]() Is that just from the Tune...stock config or with additional upgrades like intake, exhaust headers, high flow cats, etc?
| 05-27-2024, 01:18 AM | #10 |
Rep 28
golfer23rm - I've been trying to flash the 130i tune onto my 125i, however I'm facing some issues with INPA, the pre-flash "communications verification" step (battery dot = on, ignition dot = off) despite following the Bimmerlabs/various E90 flash instructions and using the Bimmergeeks cable. It can still read codes / code history so that's confusing.
Did you flash your car recently? If so, hoping you may have a specific guide available? Bimmergeeks no longer has downloads available, and what I've been using is refusing to work even after hours of troubleshooting. jkho - I am also a Sydney based E88 125i owner looking to get a tune (ideally 130i tune). Have you had any luck? Have you been in contact with any of the tune vendors (e.g. Celtic Tune via Zadtec)? Last edited by mikekilo; 05-27-2024 at 01:29 AM.. |
jkho65.50 |
| 06-14-2024, 10:22 AM | #11 |
Rep 243
BimmerLabs Experience - tuning my MY09 E82 125i
URL = https://bimmerlabs.com/help
Video = My Car: Aussie Auto BMW MY09 E82 125i (Euro spec, comes with 3 stage manifold and DISA valves) Where do I get my RSA Delete and Tune Files from? Jump onto Bimmerlabs, create a Project and input your car details, including the last few digits of your VIN. For my Project/VIN:
Some reading to get you prepped: https://www.e90post.com/forums/showthread.php?t=1035058 https://www.e90post.com/forums/showthread.php?t=1736657 Install, setup and checks BEFORE you Flash:
Are you READY to flash??
Timing:
After the batch files run successfully:
Result and my thoughts: My butt-dyno says the car feels faster. Especially the torque, less struggle at the low RPM range and gets up to high RPM MUCH quicker... This is exactly what I've always wanted; a 130i Coupe Achieved by unlocking that N52 goodness and getting up to (or at least closing the gap to) the E87 130i Hatch! I'll put her on the Dyno when I'm at Advan next, hoping to get a ~20-25 gain; should jump from 120rwkw to about 145rwkw thereabouts! PS> Before any haters go off on a tangent about Dyno numbers... worth noting that they all are setup/configured differently, I'm just using prev Advan Dyno results I've observed on this forum as the baseline. Hope some1 stumbles across this thread/post and finds it useful! Good luck; do at your own risk and YMMV PS> For an AUTO, I was going to also do the GM1912 Transmission update, but my Amazon KDCAN cable doesn't read the EGS Module. Not affliated, but do yourself a favour a buy the BimmerGeeks Pro Cable! For the 1series E82/E88 (both 125i and 128i), the one you want is marked as E8xN52B30O1 ECE+RdW (where the 01 I believe denotes the optimal transmission when 3SIM and both Upper/Lower DISA Valves are installed). You need to confirm you're HW# first using INPA. (HW = Identification screen and ZB = User Info Field screen... note these down!)Ref: https://www.1addicts.com/forums/show....php?t=2028726If you have HW# = 7614313, the file you want is 7614241; should be located where your datens are: SP-Daten\E89\data\GM1912\A7614242.0da
Last edited by jkho; 08-03-2024 at 06:38 AM.. Reason: Added some reading material, GM1912 and extra checks/tips |
| 07-09-2024, 07:53 AM | #12 | |
Rep 243
Glad we were able to get your car flashed successfully, it's a different beast now huh? Your car pulls pretty hard, the diff update prolly helped too! PS> Imagine you didn't have the additional E88 weight ![]() Any1 in Sydney needing help to unlock some of that N52 goodness, hit me up! . .
| 08-02-2024, 07:00 AM | #13 | |
Rep 28
I've just filled the car with 98RON (replacing the prior 94RON E10) and it seems to have improved low RPM performance as well. FYI there is someone in the USA that dyno'd at 160kW+ with an auto, in excess of your 140kW or so. I'm thinking it's due to the differences in dynos? (https://www.1addicts.com/forums/show....php?t=2029477) |
| 08-03-2024, 07:27 AM | #14 |
Rep 243
Bimmerlabs - Advan Dyno Results!
My car was pretty much a stock auto 125i, with various aesthetic upgrades.
But here's some which might affect the numbers:
Point of Reference (all figures are at the wheel) I didn't do a run b4 the Tune... but from what I've observed on similar DynoDynamics (Advan/BMRAutowerkes):
[*] Auto = 114.1kw (seems a bit low, let's use 118kw... so 158.24hp; aka ~186.16hp on DynoJet) [*] Manual = 128kw (171.65hp; aka ~201.94hp on DynoJet)
Ref2 = https://www.1addicts.com/forums/show...0&postcount=66 My Results? See attached. DynoDynamics run after the Bimmerlabs Tune = 139.5kw (187.07hp; aka ~220.08hp on DynoJet) That's an increase of 21.5kw (28.83hp); so roughly a gain of ~18.22% Next Steps? Dunno if it's worth doing Headers and high flow cats... but I'll give it another run on the Dyno once I: ▪︎ tune the EGS *** DONE ▪︎ install AFe drop-in air filter ▪︎ install a proper axle-back free flowing exhaust... Hoping to somehow nudge another 5kw or so to put it bang on 130i numbers!
Last edited by jkho; 08-09-2024 at 09:02 AM.. Reason: Edited, added Stock references and also converted KW to HP and ~DynoJet figures for our Friends overseas |
| 08-03-2024, 07:30 AM | #15 | ||
Rep 243
98Ron is the only way to go bro, your 125i deserves the best right??! Quote:
From what I've come across, DynoJet generally reports about ~15% higher numbers compared to DynoDynamics: https://www.1addicts.com/forums/showthread.php?t=891688 If you compare the numbers from this thread; 404 / 353.5 = 14.2857%
| 08-04-2024, 02:12 AM | #16 | |
Rep 28
The bottleneck, and where power can be gained, is at the headers. Headers will also change the exhaust sound (generally louder and "motorsport" sounding). RHD N52 Brintech headers netted 13kW gain without a tune: |
jkho65.50 |
| 08-04-2024, 02:24 AM | #17 |
Rep 243
I was updating my post, just as you added yours.
Was considering Headers and high flow cats... but dunno if it's worth the $$$... Are you thinking of doing these mods Kilo??
| 08-04-2024, 03:13 AM | #18 | |
Rep 28
As is, the car's *just* slow enough to be able to enjoy WOT for a couple seconds without getting into immediate trouble with our low Australian speed limits. If I get bored of the car, I may move to N54/N55/LS in ~3 years or so ![]() EDIT: Discovered Chinese aliexpress headers. $500-600 shipped, and I'm now interested. https://www.aliexpress.com/item/1005003623706153.html Last edited by mikekilo; 08-04-2024 at 03:42 AM.. |
| 08-04-2024, 05:35 AM | #19 | |
Rep 243
Need verification first... I think I saw on another forum, maybe E90/E92 and they had good reviews/results from Exhaust Header purchases from China? EDIT: review here, which also mentions "HZ Racing" https://www.e90post.com/forums/showt...ht=N52+Headers Pleb question... would this be a self installation (looking at your skills Kilo!), exhaust guy or mechanic?
Last edited by jkho; 08-04-2024 at 05:57 AM.. Reason: Added review of N52 Headers by HZ Racing, from E90 forums |
| 08-04-2024, 06:36 AM | #20 | |
Rep 28
Self install should be possible. Looking at doing this towards the end of the year if we can figure out the below and it still makes sense. Things to figure out below, might need to speak to an exhaust shop: 1. Potential mechanic question - how will the car respond to the headers with it's current Bimmerlabs 130i tune? Coding required, retune required, etc? 2. Quality of headers (should be covered in your link, though I haven't read through) 3. Any adaptation/modification of headers required to fit? E.g. confirmed RHD fitment, no drilling, cutting needed etc 3.a. Cost for exhaust shop to fit headers, if fiddling required 4. Confirmation of our existing exhaust setup. Should be two cats in headers, no second cat (unlike USA market). 5. Cost for exhaust shop to supply and fit a high flow cat in, post headers 5.a. Determine if 1 or 2 cats needed if fitted post headers |
jkho65.50 |
| 08-07-2024, 12:16 PM | #21 |
Rep 243
Updated my Dyno Results post with kw to hp conversion (including approx DynoJet numbers) for any Friends overseas that stumble onto this thread!
kilo3407 How's ur research going? For continuation, post the link to your Headers and High Flow Cats Thread once it's ready ![]()
ZHPizza337.50 |
| 08-11-2024, 09:04 AM | #22 | |
Rep 28
| Bookmarks |
