View Poll Results: Do you want a plug & play wheel setup?
YES. I like the EmPower wheels pictured. 35 44.30%
YES. I want the PnP setup, but I don't like this particular wheel. 34 43.04%
NO. I don't want/need a wide "grippy" wheel/tire setup. I like the OEM. 10 12.66%
Voters: 79. You may not vote on this poll
      07-25-2008, 12:31 AM   #1
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
POLL: Who wants a plug & play 255/275 wheel/tire setup?
I've been talking to D-Force wheels trying to get them to manufacture the EmPower wheels with a 135i specific offset. The exisiting 18x8.5 +40 wheel is already green light for a "no rub" 255/35/18 front setup. However we really need a plug and play solution for the rear of this car.
The 18x9.5 +43 rear wheels you see in the pictures "fit", but under hard cornering the tire will rub. Even with some minor fender rolling you can't get these to be 100% interference free.
If D-Force (or anyone) makes at 18x9.5 +60 offset, this will be a plug and play solution for a 265/35/18 or 275/35/18.
So, if you guys like the wheels and would be interested in this, please cast your vote and post your interest. These would most likely be offered in the silver w/ polished lip you see in the pictures and an anthracite w/ polished lip.
Thanks guys!
The pic below is the 18x8.5 all around. What we're going for here is the 18x8.5 front, 18x9.5 rear staggered setup which will allow us to run a 275 or possibly a 285 in certain brands. Tires like shoes run a bit wide/narrow from manufacturer to manufacturer.
      07-25-2008, 09:34 AM   #2
TazioNYC
Drives: BMW 135i
I'd definitely consider a plug and play EMPower set-up.
      07-25-2008, 11:18 AM   #3
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
A plug-n-play 18" setup would be great and the EmPower wheel is OK, but I don't like the polished rim. I want a wheel in anthracite/gunmetal without a polished rim--like the LTW-5.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      07-25-2008, 11:44 AM   #4
PA135i
PA135i's Avatar
Drives: 08 135i 08 CR-V
what is plug and play?
      07-25-2008, 11:56 AM   #5
ucbsupafly
Drives: 2008 BMW 135i
Umm... You mount the wheels/tires and you go. No modifications or spacers necessary.
      07-25-2008, 12:30 PM   #6
driftdriven
Drives: BMW 135i
I want that front lip!!!
      07-25-2008, 12:46 PM   #7
BerkTechnology
223
Drives: Fast
"Plug and play" would be a setup that you just mount your wheels and go.
Currently if you want to run a wide setup you have to do some rolling/modifying to get the tires to clear the fender. Or you just have to live with some rubbing of the tire on the body of the car.
      07-25-2008, 12:52 PM   #8
BerkTechnology
223
Drives: Fast
You can contact V-Fiber. They are the ones who are making the full 4 pc kit. You can buy the kit piece by piece, or the whole kit.
info@visionautodynamics.com
877-4-AEROKIT
Hi Mike,
Were you the one who had the 17x9 LTW setup on 255's?
      07-25-2008, 04:01 PM   #9
mikeo
Santa Fe Concorso
mikeo's Avatar
Originally Posted by BerkTechnology View Post
Hi Mike,
No, that was larryn, I'm the other, handsome, moderator ;-)
My setup was BBS RG-R 17x8 et40 and 17x9 et42 in Diamond Black finish. Surprisingly, the fronts cleared the brake calipers by 3mm, but the rears only have ~1mm on my 135i, not enough for heat expansion IMO.
      07-25-2008, 04:29 PM   #10
jtsherri
jtsherri's Avatar
Drives: TBD
2008 135i  [10.00]
Voted yes for pictured and SUBSCRIBED.
      07-26-2008, 04:48 AM   #11
ARCHER
Drives:
looks good to me , plug and play is what i also want and have asked on the forum if any one knows of any such wheel , with no luck .Voted yes.
      07-26-2008, 08:50 AM   #12
WAY
Drives: Fast ones
Wow this would make an awesome track setup. How heavy are these wheels?
      07-26-2008, 07:10 PM   #13
timt
Reader, Rare Poster
timt's Avatar
Drives: F80 M3 Black (2015)
I have been combing the forums for someone to simply say that they have a plug-and-play wheel/tire combo for the 135i that will support the most rubber on a pretty standard car. Seems the easiest question in the world, yet I can't find a thread to answer it.
Sure, there are lots of mentions of 18" x 8" Volks and similar to go around, but that is leaving a lot of potentially fit-able rubber on the table. A Volk 8" on the front and 9" on the back with the right offset would be fine, but doesn't exist from what I can tell. You can get the Superleggera setup like that but it is heavy. The lighter wheels are all 18"x8" all around.
I like the look of these wheels quite well, actually. I've seen some I like a little better, but the pricing on these is also quite good and good quality ratings.
In short - I'd buy these in a heartbeat if they were available today. I'm probably willing to give myself another two months to buy wheels/tires since I won't get track time before that. The run flats have to go soon, and wheels get purchased then too.
Yes, make them and let us know how to buy them asap!
~ TimT 2015 M3 F80 Black with DCT and Adaptive Suspension
Previous (all 6MT): Dinan 135i, E46 M3, 2007 Porsche GT3, 2012 Cayman R, 2003 Carrera 4S, 2001 Gemballa Boxster S, and some Audis.
      07-26-2008, 08:18 PM   #14
sebaflex
sebaflex's Avatar
61
Drives: E46 M3
seems like a great idea but...
since theyre gonna be track wheels, why not try and make those "plug and play" sizes in the LTW5 wheel design... it is waaaaaay easier to clean a 5 spoke wheel than the EmPower's Mesh design..
just a suggestion
      07-26-2008, 08:40 PM   #15
InsaneSkippy
InsaneSkippy's Avatar
79
I'm down for any plug and play wheel setup!
      07-27-2008, 10:36 AM   #16
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
You should start a new poll and see the response for having the LTW-5 in a proper offset.
I would be on it in a heart beat! The rims look great and are light enough for track/street work.
Do it!!!!!
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      07-27-2008, 01:20 PM   #17
timt
Reader, Rare Poster
timt's Avatar
Why would these need to be "track wheels"? They look fine for every-day too, have a nice lip, good color (goes with my silver), and I was of the impression they are plenty strong. 18" is certainly as big as I'd ever want on a street wheel/tire combo anyway.
If the poster is right about taking that much rubber plug-and-play that is awesome. None of the other wheel buys seem to think that much rubber and wheel width will quite fit without rolling or or suspension work. But seemed borderline so...
Price would be the one factor to visit, but that is competitive I imagine. Work out a deal with good tires and TPMS already mounted and we're golden So demanding...
I am ok with a grey or silver LTW-5 as well. I am quite a bit less worried about the style/look that the simplicity, assurance of work, weight, and rubber.
      07-27-2008, 03:11 PM   #18
Darth One
drunk poster
Darth One's Avatar
Drives: M4 GTS | E46 M3
i do like it too, but am wondering if there could be any other style options...?
      07-28-2008, 03:10 AM   #19
BerkTechnology
223
Drives: Fast
I've weighed one of the 18x8.5's on our shipping scale, tipped the scale at 18lbs IIRC.
You'd have to ask the wheel manufacturer. D-Force Wheels in this case.
Although we've driven on these wheels in speeds in excess of 145mph, they don't have to be a track only setup at all. Mighty fine looking street rollers if you ask me. About the brake dust issue that others have talked about, yes they are a bit more difficult to clean than a 5 spoke. But I have a soft spot for a clean looking mesh wheels. You just have to take the extra 10 minues to clean the wheels when you wash the car.
The wheels are very reasonably priced and I would consider them lightweight for a cast wheel.
I imagine that the pricing would be right in line with the current sizes available; right around $300 per wheel.
We are not a wheel/tire shop though. We're just putting this info out there so us 1er owners have a proper wheel tire setup.
The offsets on the 1er are so unusually high that no performance wheels exist yet, unless you go cu$tom. The only other cars that I know of that use offsets this high are the S2000 & Corvette. All of the wheel companies had to make specific wheels to fit those vehicles so we could stuff decent sized rubber under there.
One of my other favorite wheels.... darn good price you have them up for as well.
      07-28-2008, 08:06 AM   #20
holo777
Drives: 135i Conv
If you are looking at making plug and play options I know alot of people would love a wheel that would allow running 245s all around without stagger rims. Theres less grip than this but it would make it a more streetable setup to me. So I think the poll needs another opetion
      07-28-2008, 08:46 AM   #21
larryn
Awesome.
      07-28-2008, 03:10 PM   #22
BerkTechnology
223
Drives: Fast
There are a number of wheels already that fit the bill for a 245 non-stagger setup.
The D-Force EmPower's in question are non-stagger compatible in a 245 setup. Order all 4 wheels in 18x8.5 +40, wrap them in your choice of 245/35/18 tires.
