12-23-2008, 12:23 AM | #1 |
Supreme Allied Commander
3856
Rep 54,414
Drives: F80 M3
BMW Rear Guide Rod Kit - Better traction and handling
*Original guide rods were made to deflect under load, a bad thing for good handling and traction(in of the the product images you can see where the stock 335i guide rod can deflect and bow under cornering and acceleration loads)
*Aluminum guide rods are made of all aluminum, a lightweight component thereby reducing wear and tear on other, more critical parts (rear subframe, control arm bushings, etc) Each guide rod weighs just over 1.5 lbs making for a total of ~3 lbs for both parts (stock guide rods weigh 2.1 lbs each or 4.2 lbs for both). A weight savings of over 1.2 lbs from the rear suspension. *Bushing with a rubber material at one end is replaced by a sealed joint for deflection and noise free operation. Bushing deflection is unwanted because it leads to excess suspension movement. This is bad for handling and traction due to constant alignment changes. Plus, any power from the engine can take longer to get to the ground because it has to windup the bushing first. The traction link is no brainier. You will have better traction and braking and more stability and you will feel this under acceleration. The traction link is actually a tuned spring so it is designed to deflect a lot under load which is really bad for the suspension control. This is the most important link to replace. Retail: $412.80 $359.13 Order here: http://www.hpashop.com/BMW-Rear-Guid...kit-e9x-m3.htm We now have the TRW version of these guide rods. $445.89 Order here: http://www.hpashop.com/BMW-Rear-Guid...de-Rod-TRW.htm Last edited by HP Autosport; 01-31-2022 at 02:30 PM.. |
12-23-2008, 01:52 PM | #2 |
Rep 1,565
Going through the rear suspension you'd be shocked to find out that some of those pieces you can flex with your hand. Very very soft stuff. These Viagra rods should really help out our race car!
Cant' wait! |
12-23-2008, 07:32 PM | #3 |
Good life
130
Rep 1,937
is this direct bolt on? How hard is install? Any extra components needed?
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
12-23-2008, 07:44 PM | #4 | |
3856
Rep 54,414
Drives: F80 M3
Simple hand tools will be all you need. No additional components are needed, unless you feel like doing the upper links too! http://www.hpashop.com/product.sc?ca...3&productId=60 |
12-23-2008, 09:08 PM | #5 |
Rep 621
Hmm, seems like a worth while upgrade, but ~$400?? Why so much compared to the upper links and front suspension parts?
Is it possible to get a package deal if you got the following: Front lower wishbone kit + Regulating rod Front tension rod kit Rear subframe bushings Rear guide rod Kit Rear upper link kit ???
12-23-2008, 10:42 PM | #6 | |
3856
Rep 54,414
Drives: F80 M3
12-25-2008, 08:07 PM | #7 |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
I'm a bit confused at your offerings for the front suspension on your website. It just seems like there are three things priced at 3 different levels that talk about the same thing. I'm assuming the $450 front control arm kit is the combination of the front wishbone kit and the front tension rod kit? I'd be very interested in a big package deal.
It seems that I am feeling the need to really invest in this car and be happy with it. My only problem with the car right now is all suspension related.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
12-25-2008, 08:31 PM | #8 | |
3856
Rep 54,414
Drives: F80 M3
Sorry for the confusion. I have listed the tension rod kit and lower wishbone kits by themselves, then the two together. Some people choose to piece meail and some wanted to do both while they are at it. Rear kits are also available. Harold |
01-05-2009, 08:23 PM | #9 |
Rep 1,265
Has anyone installed these yet? If so, is it really that noticable or would getting swaybars be a better first choice for suspention upgrades? I don't really wanna do springs/shocks or coilovers but would like the car to do some autox a little better. Thanks
-Brian |
01-05-2009, 11:57 PM | #10 | |
3856
Rep 54,414
Drives: F80 M3
You may also want to check on E90post for reviews on these guide rods as many sets have sold since they were available from our web store. |
04-05-2012, 02:29 AM | #11 |
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
Hey Harold, would the components be compatible with the E88?
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
04-05-2012, 12:47 PM | #12 |
3856
Rep 54,414
Drives: F80 M3
05-25-2012, 02:04 PM | #13 |
3856
Rep 54,414
Drives: F80 M3
BMW M3 rear guide rods
These are good in stock and ready to ship!
08-07-2012, 03:35 AM | #14 |
Rep 22,992
I bet a lot of people don't even think of replacing those flimsy soft link with these M links.
08-07-2012, 10:46 AM | #15 |
3856
Rep 54,414
Drives: F80 M3
08-28-2012, 11:02 AM | #16 |
Rep 382
Are these the same as rear sway bar links? Thanks
2011 Space Grey 135i Sold
06 GTO , 06 WRX, 59 Bug AV cars and Coffee www.facebook.com/Avcarsandcoffee/ |
08-28-2012, 12:53 PM | #17 |
3856
Rep 54,414
Drives: F80 M3
08-28-2012, 02:16 PM | #18 |
Rep 382
Ohh, I guess I havent been under the car and looked at then rear end yet. Thank you
12-03-2012, 01:51 AM | #20 |
3856
Rep 54,414
Drives: F80 M3
12-23-2012, 09:06 AM | #21 |
Rep 22,992
since we were talking about this kit here... http://www.1addicts.com/forums/showt...1#post13198987
