      05-16-2009, 02:07 PM   #1
Schneller!
Schneller!'s Avatar
Drives: 2008 328xi & 2010 X535i
DIY - Fix your cupholder!
The little spring-loaded latch on my third cupholder broke the other day, so I did some research...: http://www.1addicts.com/forums/showt...ight=cupholder
Seems like this has happened to a lot of people, and the only fix from the dealer appears to be to give you another springloaded latch that will undoubtedly break again...here's my solution which seems to be working...Sorry for no pics, but it should be easy enough to explain
Materials I used:
- Set of small jewelers screw-drivers
- Spring bar (a.k.a. "watch band pin")
- Snub-nose snips (commonly used by Telco-professionals)
- Tiny sharp nail (small drill if you have a bit small enough)
1. (I am assuming that the latch is already detached from the assembly) Remove the small metal bar that holds the spring onto the latch and set the spring aside.
2. Using the jewelers screw-driver (small drillbit?), adust the size of the holes in the latch to allow the spring bar to pass through.
3. Assemble the latch by passing the spring bar through the holes (latch and spring). Basically, you're replacing the original bar with the spring bar.
NOTE: If you look at the underside of the housing area the latch affixes to, you will notice two "nubs" protruding from each side and one in the middle. DON'T MESS WITH THE ONE IN THE MIDDLE.
4. Using the snips, shave/cut the nubs down to flush with the housing area. Then, (as close to 'center' as possible) carefully use the tiny sharp nail (drill bit if you're lucky) and force an indention where the "nubs" used to be. The housing is now altered to guide the ends of the spring bar in place.
5. Now reassemble using the same method you would replace the spring bar in your watch with; making sure to properly seat the spring over the "nub" in the center of the housing.
...and that's it! I know I didn't find an extra 50 HP or anything here, but it was REALLY annoying to have no useable cupholder in my 4000-mile-old car. Driving the 1er makes me thirsty.... Lemme know if anyone has any questions/comments...
Model: 135i Coupe/Alpine White/Black Leatherette/6 Speed/PDC/premium hi-fi/i-Pod/USB Adaptor/AluminumTrim/M-Sport Package/NAV system/Lead foot
      05-16-2009, 05:55 PM   #2
voerman
Member
Drives: '19 530e
Absolutely brilliant - works like a charm.
This is the way BMW should have designed it in the first place.
Thanks for the DIY.
Lou
      07-17-2012, 03:01 PM   #3
DylPickle85
Child of God
Drives:
Spring Bar size?
Great guide! Pics would be a nice edition on Rev 2
Regarding the Spring Bar, can you advise on the exact size/length? There are a lot of options, and want to be sure the size I get fits the part well.
      07-19-2012, 01:08 PM   #4
fixation88
Drives: '08 135i
Pictures please
      07-19-2012, 07:37 PM   #5
GaryS
Drives: 2009 135i 6MT
2009 135i  [6.50]
I predict you will not get any pics, considering the OP hasn't posted here in three years.
      07-24-2012, 08:27 AM   #6
BostonBeemah
BostonBeemah's Avatar
Armenia
77
Drives: AW 135i 6spd
pics please!! mine broke for the second time yesterday lol
2010 AW/BLK 135i VM 6465 Single Turbo, JB4 + MHD, VRSF CP & Tial, Big Tom, Fuel-It PI + Stage 3 + Return + Ethanol Sensor, BMW PE, MFactory LSD, Spec 3+ & MFactory SMFW, RB External PCV
Best stock turbo 12.5 @ 19.46 spinning all the way down
RIP 2008 AW/BL 135i
      07-24-2012, 12:18 PM   #7
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
just cut it up and make it a phone mount
      07-25-2012, 07:10 AM   #8
Schneller!
Schneller!'s Avatar
...blast from the past...
wow... guess I am still subscribed to this. Sorry folks, no pics and I no longer have the car. Wife and I had a kid (#2 on the way) and now we have an X535i and a 328i. Anyway...
I just bought a watch repair kit that had 5 - 10 different sized watch band posts and then just forced it to work...
good news is - it worked flawlessly until I traded in the car. Good luck
Suprgnat3377.00
      08-29-2019, 02:34 PM   #9
AngelesCrest
Wow this is and awesome fix!!! I’m into watches so I had a ton of 20mm spring bars so I just sanded flat the two nubs and drilled two small holes where those nubs were, slid in the spring bar and bam it’s better than OEM!!! Thanks for this fix!!
dtla1832.50
