      02-26-2011, 01:23 PM   #1
guyp
Drives:
negative Camber possible ?
135i had no ajustements. is it different on the 1m ? How do you get -2,5 negative camber ?
what is the expected maximum tire width with the perfect 18 inches wheel offset on stock suspension ?
thank's
      03-01-2011, 08:29 PM   #2
guyp
Drives:
CAN we fit a 285mm in the bac of thé 1m? CAN we place a 10 inch wheel with a 35mm offset?
About in the front ? Width ?
      03-02-2011, 11:56 AM   #3
Ohcrap
Ohcrap's Avatar
Drives: 2011 135 M-Sport
thank's
My guess is that you'd need camber plates to get that kind of camber, check out Bimmerworld.com or HPA for options. Although, if you're going that route, you may want to consider pairing w a good set of coilovers (I assume you want camber adjustment for weekend trackdays or autoX).
As for rear wheel width, I'm guessing you could fit 11's w/out issue but you'll have to wait on your car to be sure (comes w 10's). If it rubs, you could always have the quarters rolled...eeeek. But then...why? It already comes w staggered figment and good tires, so unless you're planning a major power upgrade, I wouldn't risk scewing up your car :- )
