06-13-2011, 10:02 PM | #1 |
Rep 4,053
Alpine HID AE DIY?
Hey.. does anyone know if the diy for the Alpine HID H8 AEs are the same as the E90/E92?
Links below: and I would think it would be a bit different since our engine bays are a bit different.. anyone have the diy they can show me? |
06-14-2011, 11:17 AM | #2 |
Rep 2,229
both vids are for a M3 so it'll be totally different for the 1, since the E9x's are more similar to the 1 series a DIY for those models will help you better. when i had hid ae's i used this DIY, and really helped me http://www.e90post.com/forums/showthread.php?t=363033 and the vid below...
of course the only thing different would be the headlight housings, if you bought the kit with headlight covers that have grommets installed already then it'll be pretty much self explanatory. if not then you have to notch the headlight covers, which is covered in this DIY vid... |
06-15-2011, 12:22 PM | #3 |
Rep 1,664
Drives: E82 N55 DCT
Got my 8k's today... thanks for the DIY!
06-15-2011, 01:12 PM | #4 |
Rep 4,053
Very nice.. I am probably going to do mine this weekend.. to lazy on weekdays and to busy lol..
So just took a look at the install video.. first I must say I have a headache now.. the camera was shaking so much that you can't get a clear picture of anything lol.. Second off I couldnt tell which is the positive and neg cable since he skipped that part.. Also I have a few pieces that he didnt show on his video.. one is the I guess is a cylinder like the covers for the bulbs? I checked the E90 install diy and they dont even have that piece.. I'll probably take a photo.. I got my kit used.. did the new kits come with install instructions? Last edited by M3Newbie88; 06-15-2011 at 01:55 PM.. |
06-15-2011, 03:33 PM | #5 | |
Rep 1,664
Drives: E82 N55 DCT
The guy in the video sounded like he was out of breath the whole time, and yeah, the shakiness was annoying. Not sure about the negative and positive cable. I checked the E90 DIY link, and it shows the positive and negative, but it doesn't look like anything I have, so I'm not sure. The clear cylinders over the bulbs come off as well as the white ring around the bottom of the bulb. No instructions with a brand new set.
06-15-2011, 03:51 PM | #6 | |
Rep 4,053
06-16-2011, 08:07 AM | #7 |
Rep 1,664
Drives: E82 N55 DCT
I installed them last night and it took me about 2 hours or so. The N55 is weird, because it doesn't have a ground, so that kind of threw me off. Then when I plugged the whole wiring harness together, I realized that it must not need one. I had a black cylinder piece too, but it has like wires running into it that were sort of epoxied inside. Both sides of the N55 have a ton of room, I had no problems with putting the covers back on. I will take some photos this weekend. They look awesome! Night visibility is greatly improved. They are really white with a slight blueish tint when the car is unlocked or just started up.
06-16-2011, 09:37 AM | #9 |
Professional Rookie
35
Rep 533
Drives: 2016 M4
I installed HID angel eyes last night too. As bogart said there is plenty of room. I used some of the threaded mounts that are for the car to be RHD on the passenger side, and the driver side has the same for my grounding. We zip tied everything to other stuff versus taping or velcro just for easy removal if needed.
No code for my kit
2016 MGM/Sakhir M4 DCT | M-Adaptive | Not Stock for Long |
06-16-2011, 12:56 PM | #10 | |
Rep 1,664
Drives: E82 N55 DCT
No codes for mine either.
06-16-2011, 01:42 PM | #11 | |
Professional Rookie
35
Rep 533
Drives: 2016 M4
There is a main power input that is fused, that is then sent to a regulator. The regulator gives juice to both ballasts and ignitors. The regulator has a ground wire. The HID kit should basically power and ground itself independant of the stock light wiring and only grab signal from the stock wiring. Since stock wiring is for halogen that needs less voltage, it may likely fail if required to provide voltage needed for HID.
06-16-2011, 05:01 PM | #12 | |
Rep 4,053
Ya my car is a 2008 so the passenger side is super tight like in the diy video!! and damn 2 hours.. what where you installing downpipes lol.. jk |
06-16-2011, 05:19 PM | #13 | |
Rep 1,664
Drives: E82 N55 DCT
Lol... I was taking calls and answering texts in between, and I really took my time, so it was probably more like 1 hour max with no distractions. Kind of weird, but it has become my favorite part of the car.
06-16-2011, 07:22 PM | #14 |
Rep 4,053
I guess pictures are worth a thousand words..
Here are 3 parts I have questions about (yellow, green and orange).. where would each of these connect too? Thanks for the help for the guys who already installed this. 1. Entire Setup (blue is neg, red is positive) 2. Yellow 3. Orange 4. Green Just wanted to be sure because the videos weren't clear.. |
06-16-2011, 10:11 PM | #15 |
Rep 4,053
so I found out from looking at the GB thread that the green section I circled is the ground fix for the passenger side.. anyone can tell me where the yellow and orange plugs go?
06-16-2011, 10:24 PM | #16 |
Rep 1,664
Drives: E82 N55 DCT
Mine looked a little different, but I'm going to try my best based on locations of a few items on mine... worst case scenario, you get a ground wrong, circuit isn't completed, and won't work until you fix the grounding, ya know?... so
Blue = Positive (Power) if on passenger side Red = Negative (Ground) for passenger side... if on passenger side Yellow and Orange = Plug into one another (red to red, black to black) Green = Negative (Ground) for driver side... if on driver side Hopefully that makes sense. You probably already know this, but make sure you don't touch the bulbs at all if at all possible, and handle the black base with gloves (I used the mechanix gloves that you can get at any parts store). Also, when you remove the clear plastic cylinders, you may have to make an adjustment to the orange gaskets around the base of the bulbs. I had to stretch mine down and around the lip at the base... if that makes sense.
06-16-2011, 11:25 PM | #17 | |
Rep 4,053
I love forums.. hopefully there are no issues with my install on the weekend lol.. and I hope it won't take me a long time lol.. |
06-16-2011, 11:25 PM | #18 |
Rep 69
Drives: 10' 128i Alpine white
I got light bulb error too. It appears just only 15 sec every time i start up the car.
I think i connect every wire correctly. My kit doesn't have ground wire too. |
06-16-2011, 11:40 PM | #19 |
Rep 782
06-16-2011, 11:51 PM | #20 |
Rep 69
06-17-2011, 12:00 AM | #21 | |
Rep 4,053
But of course if there is a resolution from Alex@Alpine then thats even better. |
06-17-2011, 07:03 AM | #22 |
Rep 1,664
Drives: E82 N55 DCT
I will PM you guys his # when I get into work this morning.
