02-27-2012, 01:03 PM | #1 |
Rep 839
Drives: BMW 1M VO
USB plug in glove box
Anyone got any info on this USB plug? I've used the one under the arm rest for playing music through a USB stick or the iPhone but don't have too much info on the other one.
I did manage to copy some music from a USB stick to the internal hard drive on the 1M through the glove box USB but that's it. I tried hooking up an external HD but it wouldn't recognize it. Any thoughts/ideas/info? |
02-27-2012, 01:06 PM | #2 |
Rep 1,998
It is for just what you did.. to download music into the car... but you cant go the other way as the car encrypts it.
also it doubles as a service port for the Navigation maps... this is how the maps are loaded into the car at PDI and at updates.
02-27-2012, 01:10 PM | #3 |
Rep 812
I thought you could copy your music library back off - I'm sure I read about making a backup of the disk in the manual...?
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
02-27-2012, 01:17 PM | #4 | |
Rep 1,998
anybody chime in and set the record straight???
02-27-2012, 01:33 PM | #5 |
Rep 799
Where is this USB port exactly? I always assumed it was near the valet switch, but I can't find it.
There's an option for backing up your hard drive... so it's a two way copy. I think it just mentions it cannot play encrypted music (IE: Old Apple DRM format. The new stuff is fine) |
02-27-2012, 02:17 PM | #6 |
Rep 839
Drives: BMW 1M VO
If you open your glove box and peak your head in, you'll see the USB plug on the top side.
02-27-2012, 10:21 PM | #7 |
Rep 43
I use it to power my iPhone 4. It works well and the cord is hidden and out of the way. The I drive also recognizes it just as it does when the under center console USB plug is used. All is good.
04-19-2012, 02:59 PM | #9 | |
Rep 3,070
Anyone has photos of this plug? |
04-19-2012, 03:13 PM | #10 | |
Rep 121
04-19-2012, 08:16 PM | #15 |
Rep 3,070
Thanks a lot. No, I don't have it. The location is right there, that little box like plastic place but no plug inside. Like the valet lock or the trunk opener
08-12-2014, 02:24 PM | #16 |
Moderator
29381
Rep 13,098
To all those with a EURO spec 1M: does any of you have a USB port inside the glovebox (to be distinguished from the USB and AUX port under the armrest between the front seats) ?
My SATNAV requests to import navi itinerary files via the USB port inside "the glovebox". I suppose the system means "under the armrest". US spec 1M glovebox:
///M is art ↔ Artemis
08-12-2014, 04:35 PM | #18 |
Rep 208
that port is also used to update bluetooth and phone firmware. just go to http://www.bmw.com/update enter your vin and it will give you software updates. Then just copy it to usb and update your bluetooth and phone firmware.
FIRSTM143.50 |
08-12-2014, 04:53 PM | #19 |
Moderator
29381
Rep 13,098
For downloading an official software update for communication and entertainment, fill in the last 7 digits of the VIN of your car at this webpage of the official BMW website:
http://www.bmw.com/com/en/owners/con...re_update.html For an update of SATNAV maps, check at your dealer for the latest version. My query is not related to an update. A forum fellow kindly prepared a couple of navi files of itineraries for a forthcoming trip. I would like to import/load these into my SATNAV.
FIRSTM143.50 |
08-13-2014, 05:59 AM | #21 |
Moderator
29381
Rep 13,098
UPDATE. I checked inside the glovebox and effectively found/discovered the USB port. Once I plugged in the USB stick in that USB port and clicked "Import journey (USB)", it started to download the itineraries which a forum fellow had kindly prepared (bar with increasing percentages). Subsequently the imported journeys appeared in the SATNAV menu. Checked these and these all work. Good job.
Conclusion: my mistake - I was using the wrong USB port for importing the SATNAV itineraries (inside the glove box = correct USB port | under the armrest = incorrect USB port).
FIRSTM143.50 |
08-13-2014, 08:21 AM | #22 | |
Rep 4,021
Drives: F32 Coupé
