| 09-13-2013, 02:23 AM | #1 |
Rep 72
1M, second set of brake discs died
Hello,
the first set died on the 15k run started beating like hell, then i installed the new one OEM brake discs with new pads Endless MA45B Endurance and brake fluid motul, i did 10 laps on nurburgring and again started beating Please advised not very expensive and good brakes discs, which do not overheat so much, saw 1M and M3 on the Nurburgring with installed performance friction brakes, what can you say about them? |
| 09-16-2013, 04:19 AM | #3 | |
Rep 72
and i always cooling down brakes before the parkingwhich discs can you advised? |
| 09-16-2013, 04:27 AM | #4 | |
Rep 72
I think it's because of the new endless pad too hot for these disks, that's why new discs died so quickly, now I do not know what disks install next ![]() |
| 09-16-2013, 10:29 AM | #5 |
Rep 9
| 09-17-2013, 08:11 AM | #6 |
Rep 9
Do you have problems that the ABS-system comes in to early with the DS2500 ?
Best to change front and rears ? or front only ? Is there a (big) improvement changing the brake fluid to ... ATE type 200 ? Castrol SRF ? |
| 10-01-2013, 11:56 PM | #8 | |
Supreme Allied Commander
4780
Rep 58,142
Drives: F80 M3
| 10-02-2013, 05:32 AM | #9 | |
Rep 72
you talk about these one? http://www.1addicts.com/forums/showt...mance+friction if yes then on the next week I will be installing them, the guys from Nurburgring advised them to me, they use PFC disks with endless pads in their BMW RS-M3, and said that there no problems with this disks. |
| 10-02-2013, 11:30 AM | #10 | |
4780
Rep 58,142
Drives: F80 M3
| 10-02-2013, 12:01 PM | #11 | |
Rep 11,785
depends on how much you need to stop..... ![]() Absolutely, unquestionably, Castrol SRF is a superior fluid. See the label on the side of each and look up the terms wet and dry boiling point. note that the WET Boiling point of SRF nearly exceeds the DRY boiling point of ATE Typ200. that means that even thoroughly thrashed SRF exceeds fresh ATE. |
| 10-02-2013, 02:32 PM | #13 |
4780
Rep 58,142
Drives: F80 M3
| 10-05-2013, 03:10 AM | #14 |
Rep 72
| 10-06-2013, 02:38 PM | #15 | |
4780
Rep 58,142
Drives: F80 M3
Just make sure the pad is free of any grooves and perhaps use some sand paper to remove some material so you have a fresh surface to perform your bed-in. |
| 10-07-2013, 03:23 AM | #16 | |
Rep 549
I'm planning to get the Endless CCRg to front and I'm not sure with the rear ones. Will use the stock rotors and will see how it works. PS AD08 and RS-3 tires. PTF st.2+ |
| 10-07-2013, 12:47 PM | #17 | |
Rep 72
And one important thing don't install Endless pads only on front, because a lot of work on the front, I made this mistake, you need to put on the back too some ME20. |
| 10-07-2013, 01:51 PM | #18 |
Rep 11,785
looks like a whole lotta people that need to step up to some real brake pads in this thread.
instead of this " endless" company.. or Ferodo 2500s which are a pad for street and novice drivers... go with .. - Performance Friction 01 or 08 - Hawk HT10, HT,14, or any of their DTC pads - Ferodo DS3000 |
| 10-07-2013, 01:55 PM | #19 | |
![]() 311
Rep 2,898
Also make sure you're running proper brake fluid (ATE 200, Motul RBF600, etc.). Neil |
| 10-07-2013, 07:29 PM | #20 | |
Rep 442
| 10-08-2013, 12:42 AM | #21 | ||
Rep 9
| Bookmarks |
