      03-13-2014, 10:56 AM   #1
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Exclamation N51 Owners, Important Topic
We all know it is a bit of a pain the the N51 SULEV version of the N52 engine has less potenial power and all that. Frankly, not that big of a deal. What is important, and I hadn't really thought to look into until now, is the long term of SULEV cars.
For the E46, the SULEV version has a completely different fuel tank from the normal E46 fuel tank that is "Evap Emissions Free". The downside of this tank is that the fuel pump is integrated into it, instead of seperate and easy to change like a normal BMW fuel pump. The tank itself is also stainless steel instead of plastic. The net result is that when your fuel pump fails on a E46 SULEV, you have to replace the entire fuel tank/rear system, to the tune of ~$6,000-$8,000.
"Ah ha!" you must be thinking, "Surely they didn't do that again!"(or so thought E46 owners after E36 subframe issues). The answer is, I don't know yet. On a whim this morning on the train on the way to work I looked up identical production month/year 128s with the N51 and N52 and they do have different fuel tanks. The N51 version is more than 3 times the price of the N52 unit. It also appears that there is a secondary "Fuel regulator" for the N51 that requires a crossfeed through the gas tank to the N51 fuel pump.
My take, outlook not so great. I would investigate this immediately if I was a N51 owner.
      03-13-2014, 11:15 AM   #2
128
Drives: 2013 Lemans Blue 128i ZMP 6MT
Aahhh ST|G!
If you lived in California, you'd have a 15 year/unlimited mile warranty on your N51's emission system. That includes the stainless steel lines, fittings, tanks and pump, as this was done to cut evap emissions to get the SULEV rating! This is what I was told when I requested for an N52 and was told all cars ordered here will be N51s, but don't worry because you have a 15 year warranty on the fuel system. That warranty is only valid to Cali residents. Nevertheless, I hear you and I'm glad I ended up with an N52N by some twist of fate!
Narayan
PS: Maybe it was 150K miles and not unlimited. But 15 years for sure. Can anyone with a Cali N51 confirm this?
      03-13-2014, 11:20 AM   #3
TheSt|G
TheSt|G's Avatar
Originally Posted by 128 View Post
Aahhh ST|G!
Narayan
It was 15 years on the E46 as well, but people have been known to have issues with the claims...
      03-13-2014, 11:20 AM   #4
128
Okay it looks like 15 years/150k miles...
en.wikipedia.org/wiki/Super_ultra-low_emission_vehicle
en.wikipedia.org/wiki/California_AB_1493
      03-13-2014, 11:27 AM   #5
128
Is this a problem everywhere or only in states that originally didn't require the N51?
      03-13-2014, 11:38 AM   #6
The Dowager Countess
Drives: 128i M sport.
there's not much we can do about it.
      03-13-2014, 11:59 AM   #7
TheSt|G
TheSt|G's Avatar
Not sure on the specifics as I never went through it myself. Just about it not being covered and the car being effectively totaled as a result.
Awareness is always good. Also helps new buyers steer away from the N51.
      03-13-2014, 12:13 PM   #8
128
Steering away from EPS, turbos, run-flats, no dipstick and now this! Not long term strategies! I've already given in to run-flats and no dipstick. In 5 years it will be EPS and turbos for sure
      03-13-2014, 12:27 PM   #9
TheSt|G
TheSt|G's Avatar
Yeah, its not great.
At least run flats are fixable.
      03-13-2014, 12:54 PM   #10
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
What is there to investigate?
Suck it up. This is coming from a N51 owner. Ish happens
      03-13-2014, 01:02 PM   #11
TheSt|G
TheSt|G's Avatar
I'd probably start by pulling up the rear seat cushion and seeing what the fuel pump situation looks like. Takes about 3 seconds.
      03-13-2014, 01:19 PM   #12
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
Could be worse.
N52
Repair kit, fuel pump/fuel level sensor 16147163298 $330.93
Plastic fuel tank 16117074463 $401.68
PLASTIC FILLER PIPE 16116768785 $137.92
N51
Delivery unit, right 16147194207 $330.93
Repair kit for flange cover 16117194201 $42.41
Retainer 16117162168 $11.49
RIGHT FUEL LEVEL SENSOR 16117248295 $95.86
Plastic fuel tank 16117190559 $1,393.43
only in conjunction with
-- Repair kit for flange cover 16117194201 $42.41
-- Repair kit, fuel tank 16117194202 $62.44
Filler pipe 16117200463 $357.66
      03-13-2014, 01:23 PM   #13
TheSt|G
TheSt|G's Avatar
Could be worse.
N52
N51
It was the labor more than the parts that make the difference, as to get the fuel tank out you need to drop everything. Once again though, if this can be done from the back seat, that would be fantastic.
Just wanted to give N51 owners a heads up on an issue they will run into ~100k(or less if they run the tank dry frequently).
      03-13-2014, 01:38 PM   #14
Kgolf31
Kgolf31's Avatar
460
Regardless of my tank - I run to 1/4 and start finding gas stations to fill.
Anyways, I'll pop the seat and do some investigating
      03-13-2014, 02:04 PM   #15
Pothole
Pothole's Avatar
Netherlands
14
Drives: E88 125i, RR sport 3.0tdv6
Keep it up with the informative stuff stig!
BMW E88 125i - Tunex Tuned@ 228whp - Cyba Scoops - Performance Kidneys - Performance Exhaust - Performance Intake - BMW Strutbar - 3d Design Carbon Diffuser - Blacklines - Golf Tee - FK Coilovers - Klutch SL14
      03-13-2014, 02:09 PM   #16
TheSt|G
TheSt|G's Avatar
Yup, running them dry is a bad decision with any flavor of engine.
Curious to see the results, though the other half is going to be that aforementioned piping betweent the two units.
      03-13-2014, 02:14 PM   #17
Fume
Drives: '19 Porsche 718 Cayman GTS
Well that sucks. Washington state supposedly doesn't provide extended warranty on emissions components. I want to keep this car a long time so I might get hosed when/if the fuel pump fails. Hopefully that's not something I'll have to worry about for another decade.
New Car: 2019 Porsche 718 Cayman GTS | Stock for now
Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA
      03-14-2014, 08:39 AM   #18
bozola
Unloved BMW Addict
bozola's Avatar
Drives: Z3 Coupe, 3 318Ti
1999 Z3 Coupe  [10.00]
1998 318Ti  [0.00]
1998 318Ti  [10.00]
2008 128i  [9.00]
I3 here I come
      03-14-2014, 02:51 PM   #19
Black Prinz
Drives: 545i-128i-X3x35i-M2C
2 Repair Instructions > 16 Fuel Supply System (N51) > 12 Fuel Transfer, Sensor For Gauge > 1 RA Removing And Installing_replacing Fuel Filter With Pressure Regulator (US Cars W
16 11 048 Removing and installing/replacing fuel filter with pressure regulator (US cars with N51 engines)
Fuel filter and pressure regulator cannot be replaced individually
on US cars with N51 engines!
The fuel tank must be replaced if the pressure regulator is faulty!
In about 8 years ...
Son, see that BMW in the driveway, it's yours ...
Really, ... all you got to do is replace the fuel tank.
The Black Prinz | 09E82N51 | BMW 3-Stage Intake Manifold | BILSTEIN B12 Pro-System+ | ///M Control Arms | ///M Bushing kit | ///M Strut Brace | DINAN Camber Plates & Rear Shock Mounts | ECS Performance Trailing Arms | aFe Magnum Force Intake System [Dynamic Air Scoops+Stage 2 CAI] | BMW Performance Exhaust | BMW Performance Brakes | GOODRIDGE G-Stop SS | DEPO V2 | Style 220M reps |
      03-14-2014, 03:09 PM   #20
TheSt|G
TheSt|G's Avatar
Got a link to that just so everyone has confirmation?
      03-14-2014, 06:12 PM   #21
128
http://forums.edmunds.com/discussion...mw-3-series/p6
According to this, it may have been true that the fuel tank may be sealed with the pump, FPR etc at one point in time, but that fact may have changed from the M56 to the N51?
      03-14-2014, 06:42 PM   #22
Kgolf31
Kgolf31's Avatar
460
Every car has its niche on an expensive replacement item. For the N51 it may very well be the fuel tank.
The S54s need rod bearings after hard tracking...and that isn't an inexpensive fix, yet people still do it. Suck it up and move on, IMO.
